Chris Paterson Samba Member
Joined: February 21, 2010 Posts: 1068 Location: Newbury Park, CA
Posted: Mon Feb 14, 2011 3:27 pm Post subject: CV Clearancing Swing Pan for IRS Conversion |
Hey guys. I'm not an offroader but I knew you guys would know the answer. I've upgraded my swing axle pan to IRS by welding in the pivots with a jig. I don't have an IRS transaxle yet. I'm at the point in my project where I'm going to go and get the pan sandblasted and powdercoated. I've read that you have to clearance the swing axle frame horns to accept the CV joints off the irs transaxle. Without a transmission to bolt up can someone tell me where (measurements to the center point) and how deep I need to clear for some 100mm Bus CV's?
I do have my old swing axle transmission, can I use that to know where the axles will come out? I also bought some 4.25 ID steel tubing to cut a piece out and weld into the framehorn. Any help would be much appreciated! Also I think this will be a good post once some answers come along, since there isn't any info on the samba that I can find. _________________ - Chris
58' PGSG |
kbwakesk8 Samba Member
Joined: December 08, 2005 Posts: 1499 Location: Hacienda Heights CA
Posted: Mon Feb 14, 2011 4:38 pm Post subject: |
i don't think you have to. but all my baja' s a had 002 bus boxes. |
Posted: Mon Feb 14, 2011 4:41 pm Post subject: |
kbwakesk8 wrote: |
I'm pretty sure you do if you have a swing axle pan with a bug IRS transaxle in it. _________________ - Chris
58' PGSG |
Posted: Mon Feb 14, 2011 4:45 pm Post subject: |
i had a 61 pan i converted are you running a stock mounts? |
Posted: Mon Feb 14, 2011 4:49 pm Post subject: |
kbwakesk8 wrote: |
Yeah stock mounts _________________ - Chris
58' PGSG |
Posted: Mon Feb 14, 2011 5:17 pm Post subject: |
Hmmm... I haven't heard that... In Hot VW's they did an article on Swing to IRS Conversion (I don't have it with me at the moment) and in the first part they talked about welding in the pivots. Last month I believe, they said that they also need to clearance the frame horns for the CV's. I also found this article http://www.bajaclub.co.uk/PDF_Documents/IRS.PDF that explains the same thing on page 5. _________________ - Chris
58' PGSG |
Posted: Mon Feb 14, 2011 6:16 pm Post subject: |
Here's a type1 tranny with bus CV's (pulled from a thread on Kustom Coach Works).
58' PGSG |
Posted: Mon Feb 14, 2011 6:49 pm Post subject: |
never seen that
i have junk irs trans if you want to use on for mock up? |
Garner Samba Member
Joined: January 19, 2010 Posts: 128 Location: Columbia, MO
jeff1969 Samba Member
Joined: May 04, 2008 Posts: 69 Location: right in the middle of CA
Posted: Mon Feb 14, 2011 11:00 pm Post subject: |
the hot vws article stated 1/2" clearance |
Posted: Tue Feb 15, 2011 11:52 am Post subject: |
kbwakesk8 wrote: |
never seen that
Thanks man! But, you're a wee bit too far away for me to borrow it _________________ - Chris
58' PGSG |
Posted: Tue Feb 15, 2011 11:53 am Post subject: |
Great post! Thanks for the info. I'm hoping I can just put my SA tranny up and mark the center of where the axle comes out and use that... So I noticed in your thread on your swap that you changed the front mount... Is that something I'm going to need to do on mine? It's 63' pan... _________________ - Chris
58' PGSG |
Posted: Tue Feb 15, 2011 11:55 am Post subject: |
jeff1969 wrote: |
I just looked at the article you're right. It's for Bug CV's which are smaller in diameter just a bit. So I'm sure if I go just a little deeper it'll be good. But the problem is knowing where exactly to clearance without an IRS tranny for reference. _________________ - Chris
58' PGSG |
Posted: Tue Feb 15, 2011 5:09 pm Post subject: |
in the article they did have a irs trans to see where to cut. |
