Bolt size
locky
locky is offline
PostPosted: Mon Feb 14, 2011 5:24 pm    Post subject: Bolt size Reply with quote
What size bolt do I need for the top left engine mount?
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Feb 14, 2011 6:13 pm    Post subject: Reply with quote
If you are asking about the bolt that hold the engine to the transmission that by the oil cooler, it is 10mmx1.5 thread pitch and 70mm long.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Chas223
Chas223 is offline
PostPosted: Sun Feb 20, 2011 8:32 pm    Post subject: Reply with quote
17mm socket if that helps.
locky
locky is offline
PostPosted: Mon Feb 21, 2011 10:26 am    Post subject: Reply with quote
Thanks, I got it.
How about the rear body mounts. I know there is a bushing involved. Where can I get them? Is there an alternative that I can use from one of my local stores. Is the bushing necessary? And does anyone have a picture of the bolt/ bushing?
Thanks
Ron Domeck
Ron Domeck is offline
PostPosted: Sun Feb 27, 2011 11:37 am    Post subject: Reply with quote
I checked the rear body bolts and they are 10 x 45 but the head size is 15 mm. I don't think you can get a socket or wench in if they had a standard 17 mm head. Next best would be to use allen head bolts. Could not find the spacer yet to measure.
locky
locky is offline
PostPosted: Mon Feb 28, 2011 6:03 pm    Post subject: Reply with quote
Thanks Ron. Is the spacer necessary? Where exactly does it go. Does it slide over the bolt to take up the slack in the shock mount hole?
Thanks
