Ninamashr Samba Member
Joined: October 12, 2005 Posts: 1400 Location: City of Round Rock in the Great State of Texas
Posted: Fri Mar 04, 2011 9:13 am Post subject: |
blacktruck wrote: |
no wonder I can't get anything done.....no fusion welding gear
This project almost makes the tri power seem like old news.
One of the first things I check for updates on |
I'm very lucky to work at a machine shop that has all the gear available. FYI, the tri-power will be getting a make over in the next a few months, TT anyone? _________________ 1957 Karmann Kabriolet "Franky"
1957 Allstate trailer |
tommiebsmith Samba Member
Posted: Fri Mar 04, 2011 10:02 am Post subject: |
I know what is happening.. And I'm telling the world unless for a small one time fee I get some hush funds.. |
Posted: Fri Mar 04, 2011 10:06 am Post subject: |
tommiebsmith wrote: |
Holy crap, you found my playground. _________________ 1957 Karmann Kabriolet "Franky"
Danpa Samba Member
Joined: August 21, 2007 Posts: 1253 Location: Valparaiso, in
Posted: Fri Mar 04, 2011 5:39 pm Post subject: http://www.thesamba.com/vw/forum/viewtopic.php?t=451493& |
Since I'm a tool and die maker, I have to ask. Did you check the runout in the center of the shaft after you welded it?
By fusion welding do you mean like "thermit welding"? |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Fri Mar 04, 2011 11:13 pm Post subject: |
this is great to watch. i must say i'm very jelous as i have wanted to make one of these for several years. i just don't have the skills, knowledge or the tools.
a quick question. from the picture the holes in the shafts look to be out of alignment, any particular reason you did it that way? |
Posted: Sat Mar 05, 2011 7:01 pm Post subject: |
It fits and the shaft spin normally with no hangups. I'm kind of amazed at how easy the shafts spin. I can just grab the coupler at the bottom of the shaft and both rotors spin freely, no grabing, no tightening.
I'm glad I went with paint instead of anodizing, it looks so much better that way
Here a close-up of the sight glass, I can now see the gears spining in there and check the level of the oil very easily
Here a vid of the rotation. Look at the end how they stop at the exact same time, the pitch diameter is perfect. Can't wait to run this in a couple of weeks.
** Next is the bracket for the two coils. It will be attached to the shroud. _________________ 1957 Karmann Kabriolet "Franky"
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sat Mar 05, 2011 7:06 pm Post subject: |
I just wet my pants again.
Sweet... more pictures please. _________________ Glenn
Member #1009
#BlueSquare |
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Sun Mar 06, 2011 9:34 am Post subject: |
Any thoughts on having each distributor's curve matched or confirmed to its counter part? They should be identical but I would want to confirm. I'm sure Glenn would love to spin them on his machine. I'm checking daily for updates on this thread...very cool.
j. |
Posted: Mon Mar 07, 2011 7:48 am Post subject: Re: http://www.thesamba.com/vw/forum/viewtopic.php?t=451493& |
Danpa wrote: |
We did check the run out it was good @ about .002. Fusion welding is basically TIG welding without the filler. I think what helped keep the shaft straight was the machined pin. It was press fit and that locked it in place while the shaft was being welding in our welding positioner. _________________ 1957 Karmann Kabriolet "Franky"
Posted: Mon Mar 07, 2011 7:52 am Post subject: |
henry roberts wrote: |
The two holes are independent of each outer. The one in the middle is for the drive gear, the one at the end is for the dist coupler. That's just the way they ended up. _________________ 1957 Karmann Kabriolet "Franky"
Posted: Mon Mar 07, 2011 7:58 am Post subject: |
Low Bräu wrote: |
j. |
I PM'd Glenn a while back about this and I think he said that it's very difficult to get two distributors to match exactly since you really can only adjust the start of the curve and the maximum advance, he tried it once with a pair of distributors from a Carrera 4 cam engine and spent a lot of time just to get them close but not exact. _________________ 1957 Karmann Kabriolet "Franky"
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Tue Mar 08, 2011 6:24 am Post subject: |
Really cool, but the video I want to see is when the engine is running. I'm curious how it will sound. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
GTV Samba Member
Posted: Tue Mar 08, 2011 9:12 am Post subject: |
Maybe I missed it, but are the heads going to have twin plugs, as well?
Really great build!! _________________ EMPI Power Rules! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13953 Location: Southampton U.K.
GTV Samba Member
Posted: Tue Mar 08, 2011 5:16 pm Post subject: |
John Moxon wrote: |
MR COSMIC wrote: |
Maybe I missed it, but are the heads going to have twin plugs, as well? |
Yeah...you probably missed the topic title and the first post on page one. |
Doh! _________________ EMPI Power Rules! |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Tue Mar 08, 2011 7:39 pm Post subject: Me doh too |
MR COSMIC wrote: |
John Moxon wrote: |
MR COSMIC wrote: |
Doh! |
I saw the topic, and one shot of the combustion chamber side of the twin plug mod, but have searched the forums, and not found more detail. Are there more pictures/details of the twin plug heads--like where do you screw the sparkplug in?
Homer |
Posted: Thu Mar 10, 2011 7:43 pm Post subject: |
Well it's running. Still gotta set the timing right, adjust the idle, etc;. It's not noisy at all I was expecting a little bit of gear whine but there is none.
Ever wonder what happens inside a dizzy while accelerating, Here's your chance...
Over all I'm very happy with the results. It ran for 30 min with a few accelerations in between. I'll be pulling the dist to examine it for wear on the gears. Next in line is pulling the motor and drilling the heads for the additional spark plugs. _________________ 1957 Karmann Kabriolet "Franky"
Jake Martinez The VW Kid
Joined: February 06, 2009 Posts: 2120 Location: Wilmington, NC
Posted: Thu Mar 10, 2011 9:43 pm Post subject: |
_________________ 58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote: |
buslife wrote: |
10 inch narrowed beam |
Congrats, that's going to look like shit. |
Richard Roth Samba Member
Posted: Fri Mar 11, 2011 4:33 am Post subject: |
John, it scares me that you used the term "dizzies"
_________________ The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier |
