freakmonk Samba Member
Joined: February 22, 2010 Posts: 6 Location: Gainesville, Fl
Posted: Wed Feb 16, 2011 11:04 am Post subject: 90 Vanagon GL starts intermittently |
Hello, my problem is that It takes an avg. of ten turns of the key in the ignition to start the engine. Its an automatic. Any ideas of what my problem is? Thanks |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Wed Feb 16, 2011 12:47 pm Post subject: |
You'll need to post a lot more details. Does the starter motor turn at all or do you get just a "click"? I've had automatics with bad neutral safety switches where a similar thing would happen (just a click with each turn of the key until it would finally start right up). |
insyncro Banned
Posted: Wed Feb 16, 2011 12:56 pm Post subject: |
There is a switch in the shifter console in automatics that will not allow you to start in gear.
Test that switch...it may be going bad. |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Wed Feb 16, 2011 12:58 pm Post subject: |
Here are a couple of other questions to help with the troubleshooting:
How old is your battery and what is the resting voltage before you try to start it for the first time? These are important factors to try to troubleshoot your starting dilemma.
Does the engine try to crank over with each turn of the key, or do you sometimes get no feedback at all when they key is turned? I ask this because it could be that you have an ignition switch that is on its way out.
If you can get the van started, check the voltage at the alternator and at the battery posts as well to look for possible charging system issues. Be sure that all electrical connections at the battery are clean and tight.
The grounds are equally important, check the battery ground strap as well as the grounds coming from the front of the transaxle to the chassis and from the left (drivers) side of the engine to the body in the engine compartment. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
Posted: Wed Feb 16, 2011 1:47 pm Post subject: |
insyncro wrote: |
Ive noticed when I wiggle the shifter in park it will start. I also have a hunch my problem is related to the shifter because of this.
Do I have to remove the shifter console or something? Thank a lot. |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
Posted: Wed Feb 16, 2011 4:31 pm Post subject: |
Awesome, thank you. Did you have to replace the switch or did cleaning/adjusting fix it for you? |
stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Wed Feb 16, 2011 4:54 pm Post subject: |
I am asking the same question SCM have asked. Does the engine cranks every time you turn the key to the start position ? If it does, it has nothing to do with the neutral switch. It could be that it is not holding fuel pressure. Trying turning the key to on and listen to the fuel pump, when it stop, turn the key off and again on. Do this a few times to allow the fuel pressure to build up, then try to start the engine. _________________ Steve
87 Westfalia full camper 4 speed |
Posted: Thu Feb 17, 2011 2:51 am Post subject: |
Don't thank me, I just remember the post and did a SEARCH....deprivation is the one who took the time to post pictures.
FWIW-I just had to clean/adjust mine.
As always, your results may vary. _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
Posted: Thu Feb 17, 2011 3:39 pm Post subject: |
just sanded the contacts a bit and shes starting like a charm, thanks everybody |
