jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Sat Feb 19, 2011 11:38 am Post subject: EVC pop-top struts/shocks for easier pop-top popping |
I get e-mails from time to time from people asking about stronger pop-top struts for their EVC, I don't know much about the EVC, and have never actually been inside of one but I'm sure it will be helpful for all the EVC owners to have a thread where they can relay their experiences with various strength struts for their pop-tops.
The stock struts are part number GSNI-3100-100, from [url=http://www.spdhardware.com/catalog/list.asp?id={FD677C08-6417-4A4C-9551-C52741324413}]here[/url], they have 100 pounds of force, any of the 3100 series will be the correct length for the EVC roof, the last number is the amount of force.
One guy told me that with nothing on the roof and 120 pound struts the roof just about pops itself, but he had to pull down a fair bit to get the roof down, but his shoulders can pull better than they can push so it works well for him.
As far as strengths of shocks for people with rocket boxes on the roof or the like I'm not totally sure, thats largely what this thread is for. I wouldn't go over 150 pounds of force as with nothing on the roof it would be quite a battle to get the roof down, and I'm not sure how the strut connects to the roof so 150 pounds might already be pushing the strength of the roof.
As far as boxes on the roof are concerned,if your box is not mounted to the roof yet you want to mount it a far back as possible so you will be lifting the extra weight the shortest distance possible.
Hope this helps _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3092 Location: ABQ NM USA.... Except when not
Posted: Sat Feb 19, 2011 12:26 pm Post subject: |
man if I had a euro (especially with roof cargo), I'd like a set of these locking struts -
http://www.spdhardware.com/catalog/list.asp?id={A818FF64-E51A-422F-A59A-4E2E52A3BDA2}
(must copy/paste link. it apperas the "{" characters affect positing. addind URL tag blanks out whole post)
GSEL Econo-Lock Gas Spring
The GSEL Gas Spring eliminates the need for a seperate safety rod or support in critical lift-assist applications. The shroud positively locks when the gas spring is fully extended protecting people and critical equipment from injury or harm in teh event of catastrophic gas spring failure due to excessive overload or misuse. The GSEL Gas Spring is simple to use, when the gas spring is fully extended a spring loaded locking shroud moves into place on the lip of the tube to prevent the gas spring from compressing. The shroud is released by applying thumb pressure to move shroud out of the way so the gas spring may compress. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Wed May 25, 2011 4:39 pm Post subject: |
jackbombay wrote: |
But Vanis 13 already posted a link to locking roof struts for $26, and they cost $40 from GoWesty... |
$40 for two, $25 for one.... |
