Cooling system ultimate mod?
VisPacem
VisPacem is offline
PostPosted: Sun Feb 20, 2011 10:50 pm    Post subject: Cooling system ultimate mod? Reply with quote
I have been, I guess like most everyone else here, fighting the air bubbles, bleed the system headache since I owned my 2nd Vanagon. The first one was air cooled Laughing
Then I got to thinking, why not just add a "conventional" piece of equipment.
Example: on the wife's diesel ( Embarassed ) the radiator is "sealed" meaning no cap no access. Just a hose going to a tank with a pressure cap. No problem ever.
I did mod the Austin that had an "open" system, that is a 15lbs pressure cap on the radiator and when overheating occurred (a story of the past since my mod) coolant out in nature it went, the loss of coolant naturally resulting in more overheating Crying or Very sad
So, I installed a flat cap on the radiator, used the overflow hose to connect to an overflow tank with a pressurized cap (15lbs). So then, now whenever the coolant expands it goes into said overflow tank and eventually returns to the radiator.
My question being why not add a pressurized tank to the front of the Vanagon perhaps using the bleed valve with a hose to a tank with a pressure cap and voila?
I just came up with this idea for the Vanagon at 21:45hrs, so in case pictures are needed to clarify, I'll wait until daylight.
Any opinion for or against?
LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons)
paddyh
paddyh is offline
PostPosted: Sun Feb 20, 2011 11:18 pm    Post subject: Reply with quote
what is this "radiator" device you speak of?
81 A/C Westy
02 Impreza Wgn
hdenter
hdenter is offline
PostPosted: Sun Feb 20, 2011 11:38 pm    Post subject: Reply with quote
Well, this sort of system is already there. It's just in the rear. Adding a secondary tank up front won't solve the bleeding issue. Unless you have a hole or leak up front, that is not where the air is comming from. The top of the rad is just where the air collects since it is the highest point. What I could get behind is either an easier to reach/operate bleed valve that doesn't require removing the grill and/or a sight tube from the top of the rad to the bottom so that you could tell if there was air trapped in the rad. Either way, any expantion/contraction of the coolant should be handled by the rear coolant tank and the overflow tank. If you keep getting air into the system, look to see if the coolant cap is working properly and make sure that the hose from the coolant tank to the overflow tank is in good shape and doesn't have any holes. If that doesn't solve the problem, do a pressure test to see if you have any holes. Even with a "libby bong" it takes a lot of work to get every bit of air out of the system on my 1.9.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
randywebb
randywebb is offline
PostPosted: Sun Feb 20, 2011 11:47 pm    Post subject: Reply with quote
it's like the oil cooler that "air cooled" engines need, except it uses water
1986 2.1L Westy 2wd Auto Trans.
VisPacem
VisPacem is offline
PostPosted: Mon Feb 21, 2011 12:49 am    Post subject: Reply with quote
Rolling Eyes
radiator: Radiators are heat exchangers used to transfer thermal energy from one medium to another for the purpose of cooling and heating.
Device Question I do not see the word "device" anywhere in my post d'oh!
I guess images might be necessary. Though the modification would consist of a nipple always open, a small tank permanently behind the grill with a pressure cap. After all that could be called a "device" Laughing
As far as the tank with pressure cap in the back we all agree that it is, yes the same pressurized system,however it does not seem to do the job or we would never have to bleed now, would we?**
But instead of arguing ad infinitum, I am going to try it and .... Laughing
I won't tell naaaa Laughing Laughing Laughing
** I NEVER had to bleed the system on any car I have ever owned, as mentioned before, Gordinis, Fiat, Citroen, Astons, Triumph, Ford, Cadillac and lawmowers Laughing Laughing
I do appreciate the constructive information on what the cooling system is supposed to do, only aware it is definitely flawed, the system not the info.
Thanks Smile
vanis13
vanis13 is offline
PostPosted: Mon Feb 21, 2011 12:52 am    Post subject: Reply with quote
I'm liking this idea.
I'm thinking that a tube from the top radiator bleeder to a pressure tank/rad cap/exp tank would over time bleed out the air that gets trapped at the top of the radiator.
possibly the easiest way to try this with an extra vanagon tank(s) assembly just attaching the tube to the bleeder location. For those of us w/ round headlights there is (maybe enough) space next to the radiator.
so tell me why this would not work!
some thoughts -
depending on the pressure ratings on the front vs. rear caps, only the one that opens at lower pressure would work. but would the rear one even be needed?
how about putting a radiator cap fitting (that has exp tank fitting) in the upper radiator hose? there must be a reason every other car has the radiator cap at the top hose connection to the radiator.
vanis13
vanis13 is offline
PostPosted: Mon Feb 21, 2011 12:56 am    Post subject: Reply with quote
I've always figured it was because it was not at highest point in the system. Your idea would fix that.
MsTaboo
MsTaboo is offline
PostPosted: Mon Feb 21, 2011 1:14 am    Post subject: Reply with quote
It is the device for expelling the excess heat from the passenger heating apparatus after the van interior has reached 70-75 degrees even when external temperatures are below freezing. Razz
For the humor impaired both of the above are witticisms Rolling Eyes
http://www.merriam-webster.com/dictionary/witticisms
Currently:
Defend democracy, support Ukraine.
camerahunter
camerahunter is offline
PostPosted: Mon Feb 21, 2011 1:30 am    Post subject: Reply with quote
It might work but if you are having air problems there is something wrong with the system.
A properly working system requires nearly zero attention and no air bubbles whatsoever.
Thank you,
David
1984 - Daily driver
morymob
morymob is offline
PostPosted: Mon Feb 21, 2011 5:14 am    Post subject: Reply with quote
I agree, but in the 18 yrs and 5 WBXs, all with correctly operating cooling sys, my greatest problem solver is i run without a pressure system. Never know it was that way if i didn't tell.Gets rid of all those pesky drips, seeps and burst parts, my 1/2 cts.
paddyh
paddyh is offline
PostPosted: Mon Feb 21, 2011 9:37 am    Post subject: Reply with quote
lol, thanks for playing.
81 A/C Westy
02 Impreza Wgn
BlackDogVan
BlackDogVan is offline
PostPosted: Mon Feb 21, 2011 9:54 am    Post subject: Reply with quote
One word. Libbybong. Do it once, do it the best it can be done & if your problems persist you have another issue to figure out.
Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka...
GrindGarage
GrindGarage is offline
PostPosted: Mon Feb 21, 2011 9:57 am    Post subject: Reply with quote
Normally air in coolant = headgasket. These are closed systems once bleed no more air.
-cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com
vanis13
vanis13 is offline
PostPosted: Mon Feb 21, 2011 10:05 am    Post subject: Reply with quote
GrindGarage wrote:
once bleed
true, but I think this would let you get away with not getting the "perfect" bleed because it would sort it self out after a while.
vanis13
vanis13 is offline
PostPosted: Mon Feb 21, 2011 10:08 am    Post subject: Reply with quote
tangent questions -
would the whole filling/bleeding process be easier if we were able to fill at the highest point in the system - the top of the radiator?
what would the problem(s) be with moving/attaching the OEM tanks to the bleeder screw location?
danfromsyr
danfromsyr is offline
PostPosted: Mon Feb 21, 2011 10:18 am    Post subject: Reply with quote
while this statement is TRUE for a vanagon system working in perfect near new order.
it is NOT TRUE for many many being driven today.
any leak, any air migration would cause an unbalance to this style of "Draw back" system.
a leaky rear core, coolant goes out, air sucks back in.. and license plate coolant bottle remains the same level.
a seepign head gasket, or even one of the ~20 hose clamps will return a similiar effect..
think of it as a straw with a pin hole in it.. sucking in air.. and no where togo.. well sorta..
lastly hasn't Kennedy Engineering made a 'device' for the front rad to selfbleed in subaru swaps they sell.?
Abscate wrote:
Mike Robinson
Mike Robinson is offline
PostPosted: Mon Feb 21, 2011 10:31 am    Post subject: Reply with quote
I think having something like this would make bleeding easier and add a visual check
http://www.jagsthatrun.com/Pages/Parts_Cooling_LSI-tee.html
Lots of very cool coolant products. Excellent quality.
Mike
'82 Westy Diesel 1.9TD
GrindGarage
PostPosted: Mon Feb 21, 2011 10:34 am    Post subject: Reply with quote
mike nice setup. check terry's classifieds next week. Will be available for $89.95.
-cliff
91 Vanagon AUTO
Williamtaylor33
Williamtaylor33 is offline
PostPosted: Mon Feb 21, 2011 10:46 am    Post subject: Reply with quote
vanis13 wrote:
tangent questions -
would the whole filling/bleeding process be easier if we were able to fill at the highest point in the system - the top of the radiator??
that's what I do and it works well. I first put as much coolant as the system will hold in and then drive to the highway and back. (my driveways a mile long) and then park with the front end up in the air by parking on the pond bank by the house raising the front end. And I use alittle funnel that I made to fill thru the bleed screw. Usually takes a quart or so to top off the radiator. And then close the bleed screw and forget about it.
When I know it needs attention is when I hear air gurgling when I shut off the engine.
89 Bostig powered syncro westy
bluebus86
Banned
bluebus86 is offline
PostPosted: Mon Feb 21, 2011 10:53 am    Post subject: Reply with quote
Mine is stock system, filled with the libby van bong and no problems since.
if you got a probelm try a pressure test on the system, it may have a leak.
