hippiepilot Samba Member
Joined: June 18, 2008 Posts: 455 Location: Sarasota, FL
Posted: Mon Feb 21, 2011 8:38 am Post subject: Throttle Body Removal/How to |
I have done the search, there seems to be more questions than answers, but does anyone have instructions on how to remove the throttle body? I checked the Bentley and it only has instructions on how to adjust components on the throttle body. More specifically how do you get the accelerator linkage/cable detached. I have a new one and would like to get installed today. Thanks in advance! _________________ 83 air-cooled Westy
91 Carat (daily driver)
http://www.changeisland.com |
masmasmas Samba Member
Posted: Fri Jan 02, 2015 10:42 am Post subject: throttle body removal |
a bit late, but I am about to disco the throttle cable in order to removal the intake unit, no idea how. I was thinking removing the center nut of the unit with the bent washer in order to release the cable. |
ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
Posted: Fri Jan 02, 2015 11:26 am Post subject: |
No, that's the main shaft of the throttle body, and you don't want to touch that.
The accelerator cable is a small (8mm) bolt close to the end of the cable.
I use a large pair of pliers or grips to hold the lower portion steady, and use a wrench to loosen the bolt head. Once it's loose, the cable can slip out.
Have you already removed the air filter box, AFM and S-Boot/elbow?
Another thing worth mentioning, you really should replace the throttle body gasket where it meets the air intake plenum. An old & tired gasket will probably leave you with a vacuum leak. _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
Socratic Dog Samba Member
Joined: September 14, 2018 Posts: 3 Location: Santa Cruz Mountains
Posted: Fri Sep 14, 2018 9:43 am Post subject: Re: Throttle Body Removal/How to |
Old thread, but I didn't come across this problem anywhere else. 10 years of engine dying/surging when cold, once it surges it runs fine. Got slowly worse over time. Several mechanics "fixed" it by replacing various sensors. Sometimes they even made it slightly better, for a short time. I adjusted the throttle switch several times, again made it slightly better, for a short time. Throttle control unit and idle control valve seemed OK.
I finally fixed the 10-year old problem a few days ago by installing a new Go Westy throttle body. In retrospect it was obvious, but it took me 10 years to work it out. $250-odd well spent. No more sitting at the the traffic lights trying to get the engine going, a line of enraged punters building up behind me.
Now I have a fast idle, 1,100 rpm (according to the instrument panel) with the idle adjustment screw all the way in. Thought about it...and realized the seal of throttle body to intake plenum must be leaking air. Did seem a bit loose when I installed it. Planning on sealing it with Permatex...until I searched it and found that I should have used a new throttle body to manifold gasket/seal. I'm a bit sore that Go Westy didn't fill me in on this one. Shouldn't the ($5) gasket be included with a $250-odd part? Or even mentioned in the accompanying installation instructions? Anyway, I expect a new one will fix the fast idle. I'll update this when installed, predictive strength is the hallmark of good science/engineering. |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Fri Sep 14, 2018 9:56 am Post subject: Re: Throttle Body Removal/How to |
Just mention it to GW, I'm sure they'll take the time to update the ad description if they know they can sell additional items. _________________ '90 Syncro Westy w/GW2.5L |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Fri Sep 14, 2018 9:37 pm Post subject: Re: Throttle Body Removal/How to |
If you're down on the coast over the weekend, you're welcome to stop by and we can connect up my redline smoke tester and test for leaks (un-metered air). It'll quickly confirm if there's any air getting past the old gasket or somewhere else. PM if you'd like to try a smoke test. _________________ "Gundy" - '85 Westfalia
