A Bluestar from Germany...
Page: Previous  1, 2, 3 ... , 12, 13, 14  Next
KeaganJDews
KeaganJDews is offline
PostPosted: Sat Jun 18, 2016 4:44 pm    Post subject: Re: A Bluestar from Germany... Reply with quote
I can't wait for more posts on this!!! I own an '89 Bluestar(Wolfsburg Edition) and I'm thinkin' about the 996 gearbox and a 1.8t. But this is a new level of badass.
When are you getting back to work in this beast?
Thanks,
Kage
Forthwithtx
Forthwithtx is offline
PostPosted: Sat Jun 18, 2016 8:13 pm    Post subject: Reply with quote
SyncroGhia wrote:
It's amazing how long the little bits take but it's getting there slowly.
I was in two minds as to whether to lift the lid, add enough to the lid to create space or just cut the hole and plate over the top.
MG
I would be thinking "plexiglas" with that beauty in there.
Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L
SyncroGhia
SyncroGhia is offline
PostPosted: Sat Jun 18, 2016 10:09 pm    Post subject: Re: A Bluestar from Germany... Reply with quote
Thanks,
Kage
As the 996 gearbox already lends itself to the 5 Cyl, V6 and V8 Audi engines re bolt pattern (no adaptor plate needed), I wouldn't bother with the 1.8T 20V. I know of one person who has done the 996 conversion with 1.8T 20V and he had to do a lot of work to just get them to fit together.
I know a lot of people rate the 1.8T 20V and it's a good engine, but there are a lot of other, more tuneful engine out there.
MG
T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
SyncroGhia
PostPosted: Sat Jun 18, 2016 10:11 pm    Post subject: Reply with quote
MG
That had occurred to me also but I plan on putting some sound insulation over the top also and then a factory diesel sound deadening mat as well. I want the van to be quiet inside... not necessarily as quiet outside Wink
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
KeaganJDews
PostPosted: Tue Jun 28, 2016 9:57 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Thanks,
Kage
MG
Are you talking about Patrik's thread? Seen that one and it looks like some work but fabrication is one of my favorites. Maybe I'll skip te gear box...
Thanks for the tips,
Kage
SyncroGhia
PostPosted: Tue Jun 28, 2016 12:08 pm    Post subject: Re: A Bluestar from Germany... Reply with quote
KeaganJDews wrote:
Thanks,
Kage
MG
Kage
Yes Patrik's Tristar airride. Nice bus and mods.
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
SyncroGhia
PostPosted: Mon Aug 29, 2016 11:25 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Not much of an update but I decided to try out some new rims to get myself motivated to do some work on it.
I need to buy some narrower front spacers to pull them in 5mm but otherwise they're on and work.
They're Lamborghini Gallardo wheels.
19 x 8.5 with 235/35R19 and 19 x 11 with 295/30R19s.
Once Busfest is done, I'll be able to get back with the gear shift cables etc.
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
tiggerjpt
tiggerjpt is offline
PostPosted: Fri Sep 23, 2016 5:18 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Following with lots of interest
View user's profile Send private message Send e-mail Facebook Twitter Classifieds Feedback
SyncroGhia
PostPosted: Wed Feb 15, 2017 1:42 am    Post subject: Re: A Bluestar from Germany... Reply with quote
I've been back on with the gear cable and linkage.
Time to get the van up in the air so that I can get underneath it!
And as it's been so long since I looked at this last time, I needed to refresh my memory as to where I'd got to it.
Cables onto the gearbox and shifter in vague position.
Thankfully the upper cable is able to use one of the OE holes in the chassis cross member although I'll have to open it up a bit for the whole cable to pass through once it's connected up to the front section.
Cable on up front...
With both cables on and meeting in the middle... it seems that I have already cut them to the right length Smile
I've also been buying parts for the junction box.
This is one of the four metal cable glands. They're supposed to go up to 10mm but the centre piece only allows up to around 7mm and if you try to open it up anymore... this happens Sad
Despite this, I tested the sealing end (thick rubber grommet) by tightening down the nut hard and it holds the cable no matter how hard I try to pull it out. I have been in touch with the seller and we'll see how it goes. If it starts to slip, I'll re-visit this.
I really want to use the 996 shifter but not cut the floor apart. My first thought was that I'd just have to bolt it down and cut a slot in the floor for the cables to pop through but it just seemed messy and a bodge. I also didn't want to open up the original hole in the floor for the shifter mounting.
So, I looked at the 996 shifter and the T3 setup and figured that with some trimming, they might match up - ish!
Deep breath....
I've gone and done it now. No going back!
Stock base plate, a Ł15 part.
Time to get the hacksaw out.
With a bit more trimming, the 996 shifter housing sits inside the T3 base plate... oh, yes I did have it 90o out!
With a few screws to hold it in place...
The screws are enough to hold it for the moment and I'll look at bonding the two together for a finished article.
Maybe someone will take the idea and make up a frame that will accept the 996 parts and fit straight into the VW T3?
In the van...
With the Tristar gearlever boot fitted, you can't tell that it isn't stock.
And from underneath...
I need to trim the cross member just behind it so that the cables will sit flat against the floor and then attach the rear section of the shifter to the floor so that the cables clip in from underneath.
I've ordered some more material to start making the junction box so I'll post photos up as I go on.
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
japio
japio is offline
PostPosted: Wed Feb 15, 2017 2:49 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Won´t the throw be way to long?
Ex: 1985 Caravelle 2.5 V6TDi
1988 Camper (homebrew) MV now 1.8T (1996Audi A4)
working on: 1985 Doka 3.0H6 (EZ30R)
SyncroGhia
PostPosted: Wed Feb 15, 2017 3:15 am    Post subject: Re: A Bluestar from Germany... Reply with quote
All the 'bling' blue stuff on this shifter is a short shift kit.
I'm hoping that by the time I extend the gear lever up to a normal T3 length, it'll be about right for normal shifting.
This is a standard 996 shifter.
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
japio
japio is offline
PostPosted: Wed Feb 15, 2017 3:19 am    Post subject: Re: A Bluestar from Germany... Reply with quote
If the White plastic piece for the sideways cable is longer at the bottom too, you might have this luck. Wink
SyncroGhia
PostPosted: Wed Feb 15, 2017 3:22 am    Post subject: Re: A Bluestar from Germany... Reply with quote
That is one of the things on my mind. It may not be longer and therefore the sideways throw will be too much.
If this happens, I will look at modifying the housing to move the support for the white piece out and extend the inner section to match, so reducing the movement.
I'll find out soon Wink
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
xoo00oox
xoo00oox is offline
PostPosted: Wed Feb 15, 2017 7:14 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Nice job! looks like it's going well with that shifter. I am using the same shifter and cables in my Vanagon, It's been in place for the past 3K miles, you are going to love it. I actually look forward to driving in city traffic now. I just put one in my Bay window van project too.
SyncroGhia
PostPosted: Wed Feb 15, 2017 7:21 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Ah that's good to hear.
Do you have any photos of your setup please?
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
xoo00oox
xoo00oox is offline
PostPosted: Wed Feb 15, 2017 7:49 am    Post subject: Re: A Bluestar from Germany... Reply with quote
No pictures of the linkage or how I lengthened the cables, but here is one of the shifter mounted in the Bay van. I did similar with my Vanagon, it's nice having the shifter right beside you rather than the long reach toward the dash. I did have to drill holes for the cables to go through the floor though. That's really cool how you used the stock shifter base. I destroyed two complete sets of shifter cables trying to learn how to lengthen them right. I extended the shifter to bring the shift knob up to a good position, this does lengthen the throw, but there are other pivot pieces in the linkage that can easily be modified to correct the side to side and front to back throw.
xoo00oox
xoo00oox is offline
PostPosted: Wed Feb 15, 2017 7:52 am    Post subject: Re: A Bluestar from Germany... Reply with quote
here's another to get an idea of the length of the shifter.
SyncroGhia
PostPosted: Wed Feb 15, 2017 7:53 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Great to see it being used.
If you have a chance, I'd be interested to see how you've lengthened the cables. I've settled on a design now and have pretty much all of the parts but it always interesting to see how other people approach the same issue.
You can PM me them if you'd prefer them not to be on the net or go any further.
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
xoo00oox
xoo00oox is offline
PostPosted: Wed Feb 15, 2017 8:12 am    Post subject: Re: A Bluestar from Germany... Reply with quote
here's the Vanagon using the Porsche shifter.
japio
japio is offline
PostPosted: Wed Feb 15, 2017 8:30 am    Post subject: Re: A Bluestar from Germany... Reply with quote
Looks very nice Andrew Applause
Page 13 of 14
