motometer thread ?
55oval geek
55oval geek is offline
PostPosted: Fri Feb 25, 2011 10:50 pm    Post subject: motometer thread ? Reply with quote
hi guys i purchase a set of early motometer gages for my 55 oval i need the panel for them but how would i find out if is original or repro ?? let me know if some could help thank you.
With out trucks america stops [email protected]
Jake Martinez
The VW Kid
Jake Martinez is offline
PostPosted: Sat Feb 26, 2011 8:48 am    Post subject: Reply with quote
The panel you are talking about is being reproduced I believe check the classifieds
58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote:
buslife wrote:
10 inch narrowed beam
Congrats, that's going to look like shit.
55oval geek
PostPosted: Sat Feb 26, 2011 10:25 am    Post subject: Reply with quote
i need a original one could you tell the difference from the original to the repro ??. thank you for the reply jake
53 0val
Samba Professor
53 0val is offline
PostPosted: Sat Feb 26, 2011 8:34 pm    Post subject: Reply with quote
They look the same from the front............I doubt you could tell if it was a repro once it was mounted in the dash.
55oval geek
PostPosted: Sat Feb 26, 2011 8:42 pm    Post subject: Reply with quote
thanks for your reply i guess i will think about it. i would think they would have a trace mark to tell the difference but i guess not thank you. [email protected]
anmilsurp
anmilsurp is offline
PostPosted: Sun Feb 27, 2011 5:56 pm    Post subject: Reply with quote
The vast majority of the available panels seem to be repros. Patina can be faked, but if it has patina it's not likely it's a repro. Avoid spending extra money for an "original" panel if it's sight unseen though.
55oval geek
PostPosted: Sun Feb 27, 2011 9:26 pm    Post subject: Reply with quote
Thank you for your reply it helps alot to ask questions I don't want to get ripped off. will see what i could come up with thank you.
insanitize
insanitize is offline
PostPosted: Thu Mar 03, 2011 4:13 pm    Post subject: Reply with quote
Do the repro's have the screw plates for the wiring blocks on them?
53 0val
Samba Professor
53 0val is offline
PostPosted: Thu Mar 03, 2011 8:27 pm    Post subject: Reply with quote
No
