MY Ecotec Baja ReBuild
riNR
riNR is offline
PostPosted: Tue Mar 01, 2011 3:15 pm    Post subject: Reply with quote
Looks cool! It says, "I'll woop your air cooled a$$!"
aaronhdez
aaronhdez is offline
PostPosted: Tue Mar 01, 2011 3:38 pm    Post subject: Reply with quote
you really should build a new new cage
wheres the netjiot?
Wheel_Works
Wheel_Works is offline
PostPosted: Tue Mar 01, 2011 3:55 pm    Post subject: Reply with quote
You really should build a new new cage
Whole new cage? NOT
What is in there is all Cromolly, we are adding to it though. I'm building a whole new rear cage around the motor. Looking forward to getting that done real soon I hope. I'm adding bar along the bottom of the windshield and putting ^ bar from top to bottom. We are putting bar behind the seats for support and to hook the Harnesses to and @ least a couple rear seat area X brasses in. I'm also adding angle bars in the door area.
dowha
dowha is offline
PostPosted: Tue Mar 01, 2011 4:00 pm    Post subject: Reply with quote
Now is the time to decide...
Come July...You don't want to be the guy who says “I should of......, now I have to tear it all apart" Brick wall
X+&*%$#: Ouch
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Tue Mar 01, 2011 4:19 pm    Post subject: Reply with quote
You also don't want to be the guy who come July, doesn't have a car to drive and wishes like HELL he would drive and enjoy his car instead of making it "perfect".
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
Wheel_Works
PostPosted: Tue Mar 01, 2011 4:35 pm    Post subject: Reply with quote
True Story! Been thinking about this project for a while now.
riNR
riNR is offline
PostPosted: Tue Mar 01, 2011 5:28 pm    Post subject: Reply with quote
Why build a new cage? Am I missing something?
Ed ke6bnl
Ed ke6bnl is offline
PostPosted: Tue Mar 01, 2011 6:03 pm    Post subject: Reply with quote
4.5* LOOKS fine I plant to put my 2.2 in level and run the shifter above the tunnel. Running my boys 2332 vw motor in the tunnel with the 091 was a pain, but working fine with a 7* mount. My ecotec baja just began with the front sheet metal gone and the 6 in over beam in place hope to run some more tubing this week. ED
before build up
start of the front end
Wheel_Works
PostPosted: Tue Mar 01, 2011 6:10 pm    Post subject: Reply with quote
Looks good Ed. Thanks for sharing. My shifter is on top of the tunnel also.
porboy
porboy is offline
PostPosted: Tue Mar 01, 2011 11:15 pm    Post subject: Reply with quote
Conversion looks good. Could you do me a favor and measure from the tranny and or end of the frame horns to the front of the motor? I am building my rear cage now. I have a VW at the moment but want to make sure an ecotec will fit later down the line. Thanks.
Ed ke6bnl
PostPosted: Wed Mar 02, 2011 6:50 am    Post subject: Reply with quote
Wouldn't this figure be different depending on what arms you use?? BUT I do see a lot of buggies where they do not try to get the axles in line when complete. We tried to get the axles at right angles to the tranny causing us to move the engine and trans back a little for the 3x3 arms. ED
Wheel_Works
PostPosted: Wed Mar 02, 2011 11:57 am    Post subject: Reply with quote
I'll measue later tonight and it will depend on arm length where you put it. You should be able to run 3X3's with trans in stock location. I Know several people who do it without issues.
porboy
porboy is offline
PostPosted: Wed Mar 02, 2011 5:18 pm    Post subject: Reply with quote
Thank you. I understand the tranny may have to move to accomodate longer arms. I am just looking for a ball park figure so I can see how much longer the ecotec is than the VW. Again, I appreciate it.
railman416
railman416 is offline
PostPosted: Wed Mar 02, 2011 7:37 pm    Post subject: Reply with quote
Looks real good, I am just in the begining stages of a baja build my self, righ now I'm just accumulating materials and such. I'm from michigan myself and curios if your friend who does the reworking of wire harnesses will do them or anyone and when its done, will you have a check engine light for the dash and an obd2 connector for scanning
I wouildn't be too concerned about how the engine sets if it works the way it is, you can always change it next winter...give ya somethin to do when the snow is on the ground lol. Who supplys those hoods??
thesatelliteguy
thesatelliteguy is offline
PostPosted: Wed Mar 02, 2011 10:53 pm    Post subject: Reply with quote
I think that guy is a spam bot.
Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878
Wheel_Works
PostPosted: Thu Mar 03, 2011 3:08 am    Post subject: Reply with quote
I'm sure he would. Let me ask him today. He's done several.
aaronhdez
PostPosted: Thu Mar 03, 2011 4:20 pm    Post subject: Reply with quote
Wheel_Works wrote:
you should
wheres the netjiot?
railman416
PostPosted: Thu Mar 03, 2011 6:57 pm    Post subject: Reply with quote
ok, great...if he is interested, maybe we can get in touch directly..thanks.
Wheel_Works
PostPosted: Fri Mar 04, 2011 2:46 am    Post subject: Reply with quote
Posted: Yesterday 4:20 pm Post subject:
Wheel_Works wrote:
you should
I'm thinking you should just go away or read the post
bdkw1
bdkw1 is offline
PostPosted: Fri Mar 04, 2011 10:58 pm    Post subject: Reply with quote
Radiator
Or radiator.
It's an Ecotec with an 091, not that hard to do............
Page 2 of 5
