MY Ecotec Baja ReBuild
Wheel_Works
Wheel_Works is offline
PostPosted: Sat Mar 05, 2011 7:33 am    Post subject: Reply with quote
I'm gonna set it up like Adrenaline Junky did his, behind the motor. There is a Quad 4 Baja with the Radiator up front like that around here, I just don't want it there. He ran the coolant lines down through the Tunnel, actually pretty slick the way he set it up. Thanks for the Pic though
Wheel_Works
PostPosted: Sun Mar 06, 2011 1:40 pm    Post subject: Reply with quote
porboy wrote:
Conversion looks good. Could you do me a favor and measure from the tranny and or end of the frame horns to the front of the motor? I am building my rear cage now. I have a VW at the moment but want to make sure an ecotec will fit later down the line. Thanks.
Porboy from the The Bell Housing to the end of the Crankshaft (Balancer) is 21.5 " . This Measurement includes the adapter. Hope this helps you out some.
https://www.facebook.com/rdm.ecotecs/
Wheel_Works
PostPosted: Sat Mar 19, 2011 5:39 pm    Post subject: Reply with quote
Just Got the car back from Dan Baudoux Motorsports tonight. Motor cage is done.
He Put a X Brace in the rear added to the Existing Cage. Bar behind the seat for support and to hook the harnesses to and another bar in the windshield area with a /\ going from top to bottom.
tanner_122
tanner_122 is offline
PostPosted: Sun Mar 20, 2011 11:18 am    Post subject: Reply with quote
Wheel_Works wrote:
love that looks like a TT Twisted Evil
might have to borrow that idea for my cage... Cool
cant wait to see some action pics when its done
91 jeep Cherokee "TANK"
dowha
dowha is offline
PostPosted: Sun Mar 20, 2011 11:48 am    Post subject: Reply with quote
Looks Great Applause
Can't wait to see it in person Anxious and try to keep up on the trails... Pray
This might work for the ends of your motor cage... Wink
Found them at Appletree...
TUBE INSERT LED LIGHT
http://www.appletreeauto.com/
X+&*%$#: Ouch
Wheel_Works
PostPosted: Sun Mar 20, 2011 1:57 pm    Post subject: Reply with quote
Thanks John, Thats why we left those tubes open like that was for lights. Just not sure whick ones yet. Quit a few options out there for them. I may even cut them off and cap them dunno yet.
Got door bars in also. Gotta get a wheel quick release now also
carlos_magnum
carlos_magnum is offline
PostPosted: Thu Mar 24, 2011 12:14 am    Post subject: Reply with quote
Awesome. The cage setup looks really tough.
DAVID MANION
DAVID MANION is offline
PostPosted: Thu Mar 24, 2011 12:38 am    Post subject: Reply with quote
what all is done to you tranny or is it a stock 091
Wheel_Works
PostPosted: Thu Mar 24, 2011 1:44 am    Post subject: Reply with quote
Thanks. I need to take some more and better pics of the cage. I think it looks better than my pictures show.
The trans is a built full close ratio 3 Rib that's in it rite now.
Wheel_Works
PostPosted: Sat Mar 26, 2011 3:33 pm    Post subject: Reply with quote
Any Progress on your car ED?
Wheel_Works
PostPosted: Sat Apr 02, 2011 9:03 am    Post subject: Reply with quote
Fuel Tank Mount almost done
Ed ke6bnl
Ed ke6bnl is offline
PostPosted: Sat Apr 02, 2011 9:44 pm    Post subject: Reply with quote
This is some of the work we got done to our ecotec, we got the front end almost all done, not shown is the front shocks in double shear, we need to mount the steering stabilizer, and the tire carrier. Had to leave to move my daughters stuff to an area near San Francisco in my boys toy hauler, After next week we will pull the motor and start the 3x3 arm and conversion to IRS.
First time on the ground in a while. so it is moving along but a lot of work to go, some of it is slowed because of the delay on getting parts. and selling some stuff on the property for some extra funds thanks for asking your is looking great ED
Wheel_Works
PostPosted: Sun Apr 03, 2011 7:19 am    Post subject: Reply with quote
Looking good Ed. I always like to look @ other peoples stuff for ideas and some motivation and even inspiration sometimes. Thinking long and hard about my front end. I wanna stretch it and go coilover.
Ed ke6bnl
PostPosted: Sun Apr 03, 2011 7:41 am    Post subject: Reply with quote
Let me know when you are getting ready to stretch the front, it really makes a difference on the whoops. I will help you with the start and some pitfalls we learned about. I have to say my boys sure works great in the whoops with speed. ED
Wheel_Works
PostPosted: Fri Apr 08, 2011 12:14 pm    Post subject: Reply with quote
Selling Beam/rack mount 4 SAW adjusters, Swat Away leafs, lower supports that go to the pan, arms and Shocks in the Offroad Parts Classifieds. Will mount into a Baja or a rail. Going for it.
Ed ke6bnl
PostPosted: Fri Apr 08, 2011 5:00 pm    Post subject: Reply with quote
What are you doing for gauges for your ecotec motor?? I would like water oil temp, oil pressure, tac and speedo. not sure what I will do to get them though. ED
Wheel_Works
PostPosted: Fri Apr 08, 2011 5:07 pm    Post subject: Reply with quote
@this point running the idiot light. I can ask my guy how to do it if you want.
Ed ke6bnl
PostPosted: Fri Apr 08, 2011 5:13 pm    Post subject: Reply with quote
sure. I would like to get the information from the obd port but not sure of the all the wiring, that was stuff that came with the motor, the wiring harness and the computer flashed for this vehicle, I do have the name of the wiring company. may have to contact them and learn more on the harness. Thanks ED
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Sat Apr 09, 2011 3:53 am    Post subject: Reply with quote
There's only 2 wires that go from the harness to the OBD2 port. On mine, I'm going to run the OBD2 port to the dash, then get a plug in monitor setup. You can get a touch screen one that lets you configure what info you want shown for a few hundred bucks. For $600, you can get one with a backup camera input which will be nice when I'm strapped into my rail and need to see behind me.
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
Ed ke6bnl
PostPosted: Sat Apr 09, 2011 6:17 am    Post subject: Reply with quote
That is a bit steep for the price but do you have a brand name I can research?? thanks Ed
Page 3 of 5
