wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Sun Feb 27, 2011 10:41 pm Post subject: Thermostat and housing gap question |
Hi everyone,
I am replacing my thermostat and was just curious about a gap that I saw - I think it is no big deal, but just wanted to confirm. The only reason I ask is because there was what appeared to be a sort of seat for something about the diameter of the small spring loaded cap of the tstat and there is about a 1/2 inch gap between the housing and that little part of the tstat. This gap is present on both the old one and new one.
I'm putting it all together tonight, but not filling it up until tomorrow so I thought I would just check... _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10075 Location: Abiquiu, NM, USA
Posted: Mon Feb 28, 2011 8:54 am Post subject: |
That's the bypass route. When the tstat opens it simultaneously closes that port.. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
jandjleavell Samba Member
Posted: Mon Mar 14, 2011 9:57 am Post subject: |
side, note... which way should the pointy part of the thermostat face, I have seen conflicting diagrams. logically the pointy part should match up with the pointy part of the housing cover. _________________ 86 Vanagon 2wd, wbx 2.1 hardtop
99 Volvo S70 |
wbx Samba Member
Posted: Mon Mar 14, 2011 10:01 am Post subject: |
Well, this is the orientation for a 1.9. Someone with a fancy-schmancy extra .2 liters of displacement will have to answer that one for you.
Oh yeah - and as usual, thanks 10c for the answer! _________________ '84 Westy (first owner).......but my daily driver has pedals
Timwhy Samba Member
Posted: Tue Mar 15, 2011 5:03 am Post subject: |
Yes that is how I have mine, and it looks like it couldn't go any other way. The old one that was in there before I replaced everything was quite a bit larger as far as the bottom spring seat goes and that is what got me thinking the orientation was wrong. Also when I was getting the air out I was shutting it down when the temp needle got just above half way and the thermostat wasn't hot enough to open yet. I have heard that three quarters on the gauge is normal/ok. I was having some bubbling in the expansion tank before i started tinkering/exploring, so hopefully that was because I didn't have all the air out of the system and nothing else more costly. _________________ 86 Vanagon 2wd, wbx 2.1 hardtop
99 Volvo S70 |
