camerahunter Samba Member
Posted: Fri Mar 04, 2011 12:51 pm Post subject: 1973 Ford F250 with 360 engine carburetor help please |
So, I got this old truck that runs great when warmed up. I have been working on it, getting it all dialed in.
The only thing that I cannot figure out is the carb (stock).
It's getting stuck at a high idle.
The remedy is to tap the gas pedal to get it to kick down.
Does anyone know why this is happening and how to fix it?
P.S.
It's the only non-VW vehicle I own. It belonged to my Dad and I want to keep it.
Thank you,
David _________________ 1984 - Daily driver |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Mar 04, 2011 1:34 pm Post subject: |
Sounds normal to me, what do you expect it to do? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 04, 2011 2:04 pm Post subject: |
I am hoping to get it to just idle normally when warm instead of always needing to tap the pedal to get it to kick down.
Even when warm it will be stuck at the fast idle so on flat ground I don't even have to touch the gas pedal to keep it going.
Thank you,
Posted: Fri Mar 04, 2011 3:49 pm Post subject: |
Sounds like the choke isn't opening fully or the stepped cam that the idle screw sits on is sticking. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 04, 2011 5:08 pm Post subject: |
I thin it's the stepped cam sticking.
Do you know how to fix that?
Thank you,
rubber hammer Samba Member
Joined: January 04, 2009 Posts: 77 Location: Edgemont South Dakota
Posted: Fri Mar 04, 2011 6:38 pm Post subject: |
Try backing off the choke a little. |
Posted: Fri Mar 04, 2011 8:12 pm Post subject: |
Yep, twist the choke heater (round thing on the side of the carb, loosen screws first) ever so slightly in the direction the choke opens. A liberal dose of carb cleaner on all the linkage followed by some lube wouldn't hurt either. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Mar 05, 2011 12:51 am Post subject: |
I appreciate the help. I will try that in the morning.
I have to adjust the shift linkage on the Van as well.
Thank you,
