norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Wed Apr 27, 2011 7:39 am Post subject: |
[email protected] wrote: |
I make lifetime wiper blades using your old cores if anyone is interested. or if anyone has any old wiper blades i buy them or we can swap |
i saved my old ones. i was trying to figure out a way to replace the rubber. how do you make lifetime blades? |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Tue Apr 26, 2011 3:06 pm Post subject: |
I make lifetime wiper blades using your old cores if anyone is interested. or if anyone has any old wiper blades i buy them or we can swap _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
90runner Samba Member
Joined: July 24, 2006 Posts: 118 Location: Vancouver Island, British Columbia
Posted: Tue Apr 26, 2011 9:33 am Post subject: |
I had a whole box of SWF blades at work I was saving from the Iltis's and some idiot threw them out while I was away. I still want to kill him. _________________ 74 Thing stock lots of rust figured someone needed to save it. |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Mon Apr 25, 2011 10:06 am Post subject: |
took me a while to figure it out, yes my wipers hit the hood when lowered.
I studied and studied till the thought hit me, I wonder if it is the height of the arm assembly. kept looking at shaft exposure or bushing housing thickness etc
That definitely appears to be the case. I have the Thing Shop replacement arm/blade unit.
for now, will keep the hood up. definitely do not see much rain (as fair weather driver)
first time searched, good information here |
Posted: Mon Mar 14, 2011 4:39 pm Post subject: |
thats good.
a friend of mine had the same type of wiper mod as you do. he couldnt drop his windshield so i avoided that plan.
either way, i got some new blades now that will probably last me 5 years at least |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Mon Mar 14, 2011 4:34 pm Post subject: wiper blades |
no problems with the windshield brother ron domeck has them on all his things runs with the windshield down all the time dennis domeck |
Posted: Mon Mar 14, 2011 4:13 pm Post subject: |
does your window fold down without the wipers scratching the hood? |
Posted: Mon Mar 14, 2011 4:10 pm Post subject: wiper fix |
easy fix use a bosch wiper blade adapters in box slide on drill one pop rivet now you can use inserts great hold wipes great and cheap dennis domeck |
Posted: Mon Mar 14, 2011 2:01 pm Post subject: |
well, i got them today. shipping time was ok. a little slow for priority shipping from LA to Sacramento but not horrible.
as far as the quality. meh, not bad. i had to do a little light tweeking for them to sit flat on the windsheild and i crimped the pivit on it because the blade was pretty sloppy.
hey, for 26 bucks, i cant complain. i rarely use my wipers anyway so i just needed something on there just in case.
i was wrong about them looking like my SWF blades. i had the original style with the bow attached to the blade. these are just a mounting pivot directly on the blade housing |
Posted: Mon Mar 07, 2011 8:10 am Post subject: |
i rarely use my wipers anyway, i liked the idea of the RPM blades look like the original SWFs that are on there now. i didnt want to have to hack and cut.
a fellow thing owner i know has his wiper arms modified to accept FLAPS style blades and he cant put his windshield down because they hit the hood if he does. and nobody wants that |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Mar 07, 2011 7:59 am Post subject: |
I just replaced mine with TTS unit. Very nice fit and went right on. Yes they are pricey but after buying two different units at the FLAPS that had poor fit and didn't look right I got tired of screwing around with it and bit the bullet.
There are plenty of other things on the car to keep me busy without having to re-engineer the wiper arms. Should be set now for any replacements. _________________ Ghia Owner Emeritus |
kubelmann Samba Member
Posted: Sat Mar 05, 2011 6:50 pm Post subject: |
This style wiper blade was produced "for" Mercedes and had a part number that relates ti the UniMog. The UniMog, Illtis and Thing use the same wiper arms. I got a huge supply of the blades, arms, and rods for the source that provided these parts to the Canadian Govt prior to them disbanding their fleet of the aforementioned vehicles. I recently found a pair of the modified Thing arms that a person had welded the hooks to allow a modern wiper blade to fit at low cost. BUT!! remember one "thing" the Thing wiper motor is not able to move extra weight of modified blades so the lighter "military" Will be much better for your entire wiper system. I have run this style blade for years with much better wiper performance. |
Lettuce Samba Member
Posted: Sat Mar 05, 2011 2:34 pm Post subject: |
I just use generic wiper blades form the store.... drill a hole in the plastic adapter they come with and bolt them on. My wiper arms have holes in the end, so it works fine.
or make some beetle arms shorter and use new blades. |
Semper_Dad Samba Member
sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Sat Mar 05, 2011 12:20 pm Post subject: |
One of the po's had a brilliant idea.... They took the newer hook and welded it onto the end of the arm. Walla, nice wiper blades that can be bought at any store.... Great Idea as long as your not hooked on perfect restoration |
SilverThing Samba Member
Posted: Sat Mar 05, 2011 12:16 pm Post subject: |
I personally got my hands on a set of thingshop's replaceable insert blades. I have been able to get replacement blades for them at just about any place that carries inserts. I don't think they look out of place either. http://www.thethingshop.com/WIPER-BLADES-W_-RUBBER-INSERT/productinfo/181955TTS-S/ _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Sat Mar 05, 2011 10:25 am Post subject: |
I think the part number reference is meant to imply that these RPM wipers are a substitute for those part numbers, and not stock wipers themselves. |
Posted: Fri Mar 04, 2011 7:50 pm Post subject: |
I will have a full report when they arrive. Hopefully, they arent the the same one Mink is talking about.
Sorry I didn't post a link. I figured they would be easy to search for. Wish us luck |
Posted: Fri Mar 04, 2011 7:35 pm Post subject: |
sam_w wrote: |
Item Specifics
Availability: In Stock, Usually ships within 1-2 business days
Condition: New
Brand: RPM
OEM: 181 955 425 B/181955425B
These do correlate with the Thing parts manual page 77 |
Part number appears to be correct, but the "B" designation indicates a black and not aluminum color. I doubt the seller knows the difference. The parts diagram also shows a different type blade.
My Thing has different looking blades with a single spring type arm. Looks more like the one in the parts diagram
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Fri Mar 04, 2011 7:14 pm Post subject: |
Item Specifics
Condition: New
Brand: RPM
These do correlate with the Thing parts manual page 77 _________________ 63 singlecab
73 thingster
74 Thing |
