veskovici Samba Member
Joined: September 11, 2006 Posts: 359 Location: Belgrade
Posted: Fri Mar 04, 2011 2:04 pm Post subject: cargo lock inside |
This is my cargo lock dissembled. I obviously have a missing part (where tooth pick is pointing) And I think it is a sliding part. I can not lock the lock. I would come up with something but can not make a blind ques so if someone could, please, bring a picture of missing part or entire lock.
thanks I _________________ Oval 1954
Barndoor1954
Doubledoorsunroof |
Bergepanzer Samba Member
Posted: Sun Mar 06, 2011 7:46 am Post subject: |
Hi veskovici,
I sacrificed my only 52 deluxe door lock for your question but as it already was very rotted it hopefully helps to get your lock going again!!!
Here are the pics of the disassembly as well of the wanted part. I´m sure it will be no problem for you to scale the measures correctly and to make up a replacement part by the scales given (cm).
The thickness is 2 mm as far as I can measure with all the rust on the surface.
You will make up the part within 20 minutes ))
I would be very happy if you could show the working mechanism here when you have assembled the whole thing.
Regards,
Jurgen
Posted: Sun Mar 06, 2011 11:06 am Post subject: |
Jurgen,
That is very nice of you and your pictures are most helpful. I will make it ( already tried something very very similar) .
Thank you very much and i think this will help to the others as there s no such pic on samba.
regards Ivan _________________ Oval 1954
Barndoor1954
Doubledoorsunroof |
