tranny fluid leaking!
traviswx1
traviswx1 is offline
PostPosted: Sat Mar 05, 2011 9:42 pm    Post subject: tranny fluid leaking! Reply with quote
So I've been working on the car and ran it for a little bit while it had the ass end on jack stands just high enough to lift the rear wheels off the ground, and it was leaking gear oil out of the nosecone vent. Did I fill it too much? Plus I have an over the tunnel type shifter and fluid got in the car. What would one do if they had a 10 degree mount? do you gotta fill the vent hole? Any info would be appreciated.
69 Baja, 091, 2x3, cage, 1600dp, bj front, and a sh!t load of labor!
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Mar 06, 2011 10:55 am    Post subject: Reply with quote
This is an early version of the vent fitting I install in a bus trans.
The ones I do now I use a 1/4" NPTbushing with a 1/8"NPT fitting to 1/4" hose or larger.
Using a hose attached to the fitting will get the vent higher if you ever decided to drive through high water.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
traviswx1
PostPosted: Sun Mar 06, 2011 1:12 pm    Post subject: Reply with quote
The spot where you have the flat head plug is where it was leaking the oil. I can only imagine how much nit would have leaked if I was at a steep downgrade or something. Looks like a good fix for the prblem I got. I am also running a bus tranny. Did yours leak fluid out before you put the plugs in? Your work looks good! Thanks for the reply!
jsturtlebuggy
PostPosted: Sun Mar 06, 2011 2:02 pm    Post subject: Reply with quote
The spot where the screw head is the stock breather.
When filling the transmission with fluid with 10 degree mount, make sure the transmission is in the car and at the level it is going to be. And then only fill transmission to where it running out of the fill plug. You really do not want to fill it more.
It sounds like there maybe more oil in the transmission then needed if it leaking out vent hole with car setting on level ground.
It is not that much less oil in transmission using the 10 degree mount verses it being level.
The reason for relocating the vent does kept oil from coming out and if the hose is mounted higher there is less chance of getting water into it.
A 5/16"ID hose works well even for a racing buggy with engine that turns over 9,000RPM.
Joseph
Elrod Motorsports
traviswx1
PostPosted: Mon Mar 07, 2011 12:48 am    Post subject: Reply with quote
Thanks the info helped alot.
jsturtlebuggy
PostPosted: Mon Mar 07, 2011 11:00 pm    Post subject: Reply with quote
Your welcome,
Glad I could help you.
Joseph
Elrod Motorsports
