tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Tue Mar 15, 2011 1:27 am Post subject: |
[quote="RockStock"]1) Dehne
oval56 wrote: |
and a picture from the backside? |
2) Motometer
micro9301 wrote: |
Email Mark Merz. I could be wrong, but I think his Swedish 54 dlx has a dealer installed fuel gauge, and I think it is even documented in the paperwork. |
quote]
thanks so if the length of the cable is availibel, i can build some...metal version, correct bezel, faceplate... _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Tue Mar 15, 2011 6:42 am Post subject: |
oval56 wrote: |
thanks so if the length of the cable is availibel, i can build some...metal version, correct bezel, faceplate... |
What about a sender? (for the tank). Could you use a beetle mechanical sender? _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Tue Mar 15, 2011 9:06 am Post subject: |
I have a guage and sender that would most likeley be usable in a barndoor, although not correct. It's for an oval hump style tank, but the mount is on the filler neck. One small hole drilled in the neck for mounting. Like I said, not correct, but in 1959, after driving your bus for 5 years, and you got tired of wondering if you had gas or not, this did the trick.
_________________ Stop dead photo links! Post your photos to The Samba Gallery! |
rikki james Samba Member
Posted: Tue Mar 15, 2011 10:31 am Post subject: |
Pure fuel gauge porn! (and just what I need). _________________ www.buseswithattitude.co.uk |
oval56 Samba Member
Posted: Tue Mar 15, 2011 2:54 pm Post subject: |
Scotty wrote: |
oval56 wrote: |
What about a sender? (for the tank). Could you use a beetle mechanical sender? |
absolute no problem, early dehne sending unit is perfect for:
www.dbkvw.com |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Tue Mar 15, 2011 3:08 pm Post subject: |
twinwindows wrote: |
I already talked to the king of the repro Dehn gas gauges. He and I agree that there would not be enough sold to even cover the tooling to make them. I was going to send him the very same one in the picture above as a sample. |
Do you still have it? If so let's give Oval56 the cable length and get these repo'd |
RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Tue Mar 15, 2011 3:35 pm Post subject: Beck |
I`d like to see the instructions on installing the Beck gauge |
only pics i have of the instruction sheets
need to contact cabriothusiast for the larger original pics!
http://www.thesamba.com/vw/classifieds/detail.php?id=706804 _________________ -StockRocks-
Posted: Tue Mar 15, 2011 3:47 pm Post subject: Dehne |
oval56 wrote: |
Fitting location
Deluxe has the fourth window...
I guess the cable would travel down between the third & fouth window? Or after the fouth?
Dehne installed in the ex-Todd 54 deluxe...instruction sheet seems to indicate it should sit further forward?
Maybe it had to sit back because of the deluxe 4th window issue?
Measuring on my deluxe I reckon the length from the top of the gauge (if located in the forward position) to the sender would be 3700-3800mm....allow another 350mm for a deluxe for it to travel beyond the 4th window...maybe this would be easier on the cable curvature _________________ -StockRocks- |
Posted: Tue Mar 15, 2011 4:08 pm Post subject: |
RockStock wrote: |
Deluxe has the fourth window...I guess the cable would travel down between the third & fouth window? |
did a bit more diggin
looks a little awkward travelling through the catch
should be able to get a good measurement using these pictures as an aid
or maybe the current owner can help _________________ -StockRocks- |
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Tue Mar 15, 2011 5:35 pm Post subject: |
I'm ready. I want one! Following this thread closely.... _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
oval56 Samba Member
Posted: Tue Mar 15, 2011 10:52 pm Post subject: |
it is no problem to make one... i can do it with the early sending unit i pictured.
what i need is the exact cable length from end of the tube tp beginging to the aluminiumtube....
if am i right, the aluminizmtube from gauge body to tube is around 180mm... the rest is same shit like original dehne thats not a problem...
i can do a small batch of 10 for barn samba or bus, but cablelength is the main issue.
the point is the sender, there are to styles availible, the early one i posted, and tha later one with the casted housing.... the casted housing version is at the moment my big problem, becaus i still wait for the castings i ordered 3 month ago.... the gauges itself could be ready in 2 or 3 weeks if needed. the sendingunits will take a bit time at the moment... _________________ www.oval56.com
www.dbkvw.com |
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Tue Mar 15, 2011 11:25 pm Post subject: |
Are you talking about making this gauge? Also if you notice there is a small bracket the holds the cable and makes it turn straight down towards the tank. I`m thinking installing one in a non barndoor the cable may need to be longer cos the Barndoor tank sits higher versus the later years where the tank sits lower. _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
Posted: Wed Mar 16, 2011 12:24 am Post subject: |
With a repro of the Dehne, I can see an issue of getting the cable to move freely without binding in the tube, due to the excessive length. I'm sure resolving this issue took a lot of trial and error when the originals were built. _________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
EverettB wrote: |
I like your fork. |
oval56 Samba Member
Posted: Wed Mar 16, 2011 12:27 am Post subject: |
Are you talking about making this gauge? Also if you notice there is a small bracket the holds the cable and makes it turn straight down towards the tank. I`m thinking installing one in a non barndoor the cable may need to be longer cos the Barndoor tank sits higher versus the later years where the tank sits lower. |
jep, but i need details on cablelength for barn or later, and also a blueprint of the extra clamp and the triangle on the back to make it 100%
will post some pictures tonigt of the gauges and sendingunits i make at the moment... the thing is, it is easy to convert a split od oval metal dehne gauge to a barn or samba gauge... if i get the details cabellength _________________ www.oval56.com
www.dbkvw.com |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2172 Location: Graz, Austria, Europe
Posted: Wed Mar 16, 2011 3:13 am Post subject: |
RockStock wrote: |
One should be able to hide the cable within the pillar ( the 3rd from B pillar, in front of the last window) before installing the headliner with some small holes cut on top and into the engine compartment.
The cable looks more than out of place in a perfectly restored Dlx IMO. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
oval56 Samba Member
Posted: Wed Mar 16, 2011 6:28 am Post subject: |
tstracy39 wrote: |
With a repro of the Dehne, I can see an issue of getting the cable to move freely without binding in the tube, due to the excessive length. I'm sure resolving this issue took a lot of trial and error when the originals were built. |
jep you are right...
i did some dehne gauges which were used in airplaines (piper) with 2,5m cables... teh normal cable is not working, so i tried a other way and that works okay.... the best way is tu use the really early sending unint, there you have mor chances to get it right adjusted after installing. _________________ www.oval56.com
www.dbkvw.com |
52 deelux Samba Member
Posted: Wed Mar 16, 2011 9:08 am Post subject: |
Having seen this I thought I'd have a go at producing it with an broken bug Dehne face I had.
Not exact, and could be improved upon if producing many,
[img]http://cid-daea1cd271d16e63.photos.live.com/self.aspx/fuel%20guage/100%5E_1854.JPG#resId/DAEA1CD271D16E63!266[/img]
[img]http://cid-daea1cd271d16e63.photos.live.com/self.aspx/fuel%20guage/100%5E_1854.JPG#resId/DAEA1CD271D16E63!267[/img]
and in situ.
[img]http://cid-daea1cd271d16e63.photos.live.com/self.aspx/fuel%20guage/100%5E_1844.JPG#resId/DAEA1CD271D16E63!261[/img]
Now can I bring myself to cut my tank? _________________ 52 BD Deluxe
57 Ghia golde
54 Ragtop |
Posted: Wed Mar 16, 2011 10:39 am Post subject: |
Here you go Five2,
Also if you notice the light bulb holder is smaller or shorter on the real deal probably due to the placement of the gauge so it wont hit the roof part ? _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Posted: Wed Mar 16, 2011 10:57 am Post subject: |
so that's a Beetle one, revised for Bus
have you extended the cable yet?
my tank has already been cut at some point...
regarding routing, it'd be nice if just the face & surround showed?
bracket under headlining, all cable/conduit...not sure if this is really feasible
the instruction sheet shows the cable in a dotted line..maybe solid on the rear curve...before it hits the kombis rear card
maybe this is showing it virtually all behind the headlining?
bit of a clunky install compared to the Beck & MotoMeter?
'bit of an issue routing from that dash, Jorg'
'tell you what - lets stick it high up top left, sideways'
just adds to the coolness though?
& where do you route the wire for the map light?
anyone seen a 50s bus with an original Dehne gauge installation?
searched the Gallery, nothing
regarding cheaper alternatives, an early Ghia fuel gauge (57/58/59) would probably sit well on the dash? Similar to the MotoMeter
