Hawai'ian Magnum Syncro M-Tdi
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 11, 2012 10:45 pm    Post subject: Reply with quote
Weird,I didn't receive notice of answers.... I hope you get it sorted out Smile
I dropped a ton of parts to powder coating recently,everything under the van basically Shocked
got them back today,minus the subframe for the front suspension and differential,they missed a few spots Confused
Got the front syncro hubs sleeved for centering the Eurovan rotors too.
Found a pair of Audi 200 Quattro 269x20mm rear rotors ,NOS on ebay,Bradi brand (same as Brembo basically) for less than 60 bucks shipped Cool
For this price,I give up messing around with the Audi V8 rear rotors Rolling Eyes
every washer and bit has been powder coated,tank straps too
I can't wait to assemble all the bits with new bushings and all,I feel like assembly and brand new toy Razz
Oh,wait,it is a brand new toy Twisted Evil
syncrogreg
syncrogreg is offline
PostPosted: Wed Jul 11, 2012 10:58 pm    Post subject: Reply with quote
I'm jealous! Is it expensive?
Gsb
conversions:
www.boxeer.com
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 11, 2012 11:04 pm    Post subject: Reply with quote
1500 for everything I could drop.
It was way cheaper in France ,but they did a good job.
95 bucks a rim,hell,it cost me 60 for 4 in 2008 Rolling Eyes
insyncro
Banned
insyncro is offline
PostPosted: Thu Jul 12, 2012 5:39 am    Post subject: Reply with quote
Looks good Exclamation
Franklinstower
Franklinstower is offline
PostPosted: Thu Jul 12, 2012 10:21 am    Post subject: Reply with quote
Alex,
What calipers are you going to use with the audi 200 rotors?
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Jul 12, 2012 10:09 pm    Post subject: Reply with quote
Thanks insyncro Cool
Hi Paul!
I have VW Passat calipers,mounted originally with the same dimension rotors: 269x20.Don't ask me the model,I can't remember.... I dug a lot on vagcat.com to find them,then bought them used on ebay.
I had to buy a new set of carriers when the machine shop screwed them locally when I tried to fit them with Audi V8 rotors Mad Mad Mad
I hunted down a lot on the casting markings to find compatibilities between caliper carriers Twisted Evil .
I have the thoughts and cross part numbers somewhere on a paper ,I'll put them down the day I will do the job.
That's basically the same kit as everybody else sells.
I got the adapters from Burley,I'll have to modify them for the third time now Rolling Eyes to put them back to original look....
cheers
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Jul 12, 2012 11:10 pm    Post subject: Reply with quote
Got shit done today after work
Front and rear control arm urethane bushings from Burleymotorsport.com
upper control arms with new Febi ball joints and spacer from Burleymotorsport.com
Upper control arm being assembled Smile
Urethane Powerflex bushings from T3technique.com
Upper ball joint spacer form Burleymotorsport.com (now sold by GoWesty.com)
febi ball joints
I used a 1-1/4" brass fitting under the control arm bore because the sleeve sticks out on the other side....
Upper control arm assembled Smile
Old bushings shown
Pressing in the new Febi lower ball joint with a 2" pipe
insyncro
Banned
insyncro is offline
PostPosted: Fri Jul 13, 2012 9:52 am    Post subject: Reply with quote
The new suspension will feel sooo good.
And look pretty darn good too.
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Jul 13, 2012 10:22 am    Post subject: Reply with quote
Thanks !
everything is gonna be brand new,bushings,transmission donuts etc....
The VW donuts I received are actually a little bit thinner than the old ones,that bothers me Confused
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Jul 17, 2012 11:19 pm    Post subject: Reply with quote
I did some paint touch up today and worked on the viscous coupling.
VW syncro stabilizer links replicas made by Burley Motorsport
Painted after mounting the balljoints to cover the non painted areas on the ball joint knuckle thingy
Touched up the front spindles
and rear hub as well Smile
insyncro
Banned
insyncro is offline
PostPosted: Wed Jul 18, 2012 5:14 am    Post subject: Reply with quote
Very detailed Alika.
Impressive Exclamation
Your Syncro is going to be awesome.
Keep up the good work.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 18, 2012 11:04 am    Post subject: Reply with quote
Thank you,much appreciated coming from you Cool
insyncro
Banned
insyncro is offline
PostPosted: Wed Jul 18, 2012 11:11 am    Post subject: Reply with quote
And thank you for posting your progress.
It really is a commitment to do so.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Sep 16, 2012 1:01 pm    Post subject: Reply with quote
Got back from vacation in France.
Brought back the guts of a syncro transmission parted out a while ago,bought in Germany on ebay for the locker differential to convert my front differential.
My brother in France received the box about a year ago,and shipped me what I needed,now I have extra parts on hands Cool
I received the front wheels adapters from T3technique,I 'm waiting for the correct studs now Wink
I'm about to send on the mainland all the chassis hardware to get them electroplated,like new ,or even better Cool Cool
see topic here for info http://www.thesamba.com/vw/forum/viewtopic.php?t=520051
I made a close up video of the hardware with comments so I don't end up with a giant puzzle when they get back Twisted Evil Twisted Evil
I also picked up the subframe that was not enough coated in a few spots,they re-did it :
That's gonna be cherry brah Cool Cool Cool
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Sep 17, 2012 9:19 pm    Post subject: Reply with quote
I just painted the springs Cool
Hodakaguy
Hodakaguy is offline
PostPosted: Tue Sep 18, 2012 1:19 am    Post subject: Reply with quote
Nice Work!
Hodakaguy
My Syncro Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=517384
thummmper
thummmper is offline
PostPosted: Tue Sep 18, 2012 8:36 pm    Post subject: Reply with quote
bravo alika! I will embrace powdercoating on my next one. It seems like a waste of labor to not powdercoat. My rattlecan job isnt worth spit near the ocean.
insyncro
Banned
insyncro is offline
PostPosted: Wed Sep 19, 2012 9:49 am    Post subject: Reply with quote
I just disassemble a Syncro front end and will be powder coating it to do some long term testing vs rust encapsulating paints.
Nothing fancy, silver and black for all suspension parts.
Here are the parts after a Hotsy powerwash.
Sandblasting is next on the list.
Thanks for the inspiration Alika Exclamation
Hodakaguy
PostPosted: Wed Sep 19, 2012 11:50 am    Post subject: Reply with quote
I've been using powder coating for a while now and found it to hold up really well. Make sure it's a UV stable powder, not all powders are created equal.
Hodakaguy
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Jan 14, 2013 7:03 pm    Post subject: Reply with quote
Alright people,here are the news starting back from last November 2012....
Mid November,I received a notice that the property on which the syncro was staying on is being sold.I gotta move it out from there before January 1st 2013....
All the shit always falls in the same time....
Long story short,hell of a busy season at work for me,I had to re-assemble in a rush the syncro to at least put it on wheels.
That really sucks because I was about to ship the hardware to the mainland for electroplating....stressful situation Evil or Very Mad
Rear wheel seal,genuine VW
Rear wheel seal ,vitton with double lip on the outside.Needless to say,I mounted the vitton seal Laughing
VW on top,vitton bottom
Cleaned up rear wheel hub bolts
I had to sand down the Porsche 930 style stub axles,they didn't fit in.
Rear wheel bearings
Inner is FAG Korea (FAG's are Korean? Laughing Laughing Laughing ) and outer is Febi made by INA in Germany Cool
I pressed the front wheel bearing in the spindle,a 3" PVC sewer pipe does the perfect job to hold the whole thing.
I pressed on using a differential bearing cup from a Vanagon,perfect diameter Razz ,just grinded it down on the outside diameter for an easy removal from the spindle.
Circlip in place
A french T3zone member donated to me 2 genuine front VW seals when I was in France Cool ,I ordered the remaining 2 from GoWesty,one of them was a VW seal the other was a DPL brand.
DPL
The related discussion about these seals here :
http://www.thesamba.com/vw/forum/viewtopic.php?t=395577&highlight=front+seal
Installing the front wheel studs
The VW workshop manual is rather retarded on that following point:they make you pressing the hub in the bearing,which is already pressed in the spindle,rather than making you pressing the wheel bearing and spindle onto the hub which I found out is way easier this way.Yes,I rock,I know.... Cool Cool
All you need is a reduced PVC bushing,size 1-1/2"' under the hub.
You press onto the inner part of the bearing.Easy-breezy Razz
Eurovan front rotors with adapter plates from T3technique.
5x112>5x114.3
Assembling the Honda CR-V wheel 16"x6.5", and the bees knees:the hub cap fits Very Happy Now I can really piss off purists without having to give them the finger Twisted Evil
Jaguar XJS calipers are not perfectly centered,but that will do for now,I don't have time to deal with that.They would need to be milled down a little bit
Audi 200 Quattro 269x20 rear rotors
with adapters 5x112>5x114.3
Yayyyy!! The hub cap fits here too Twisted Evil Twisted Evil Twisted Evil
A view of the Porsche 930 style ,108mm stub axle (similar to Syncro 16")
notice the difference in castings between these 2 rear wheel hubs
installing a zerk fitting for greasing the bearings
Cutting spring plates out of cutting board
I didn't have time to thermo modify them.Later.
Insyncro's trick of sliding a piece of hose on the end coil didn't work,not enough room on those SC springs Crying or Very sad
So I lost 5 front wheel studs and I had to find a solution,quick!!
So I drilled the hubs @ 5/8" partially through,thus leaving a little shoulder for the new studs ,which are longer BTW.
I got them on my T3technique adapters,delivered with the wrong studs,Chris sent me the M12 studs later,thus those extra M14 press-in studs left over who saved my ass Surprised
Page 2 of 4
