carb advice needed!!
cviola
cviola is offline
PostPosted: Mon Mar 14, 2011 6:56 pm    Post subject: carb advice needed!! Reply with quote
I obtained a '74 automatic with a single [ict 34 carb. it had not run in five years. I got it running, adjusted valves, and it idles great until it warms up a bit. when i give it gas it will accelerate fine, but when you let off the throttle you can hear a sucking (vacum) noise coming from the carb and it wants o die out.
contemplating switching it back to dual carbs however it is no longer set up for such, nor do I have the original parts/ carbs to do so.
Any suggestions?!?!
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Mon Mar 14, 2011 7:20 pm    Post subject: Reply with quote
Can you get a picture of your current configuration?
Engine/intake/carb etc
from a few different angles? This single weber ICT 34 configuration your saying you are running escapes me...
my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait!
cviola
cviola is offline
PostPosted: Tue Mar 15, 2011 4:48 pm    Post subject: Reply with quote
I have been trying to load the pictures to the gallery but they are to large. I could e-mail them If you want me to. It definately took someone some work to set this one up the way it is. They have a home made adapter plate and are using another manufactured two bolt adapter on top of that.
cviola
cviola is offline
PostPosted: Tue Mar 15, 2011 4:52 pm    Post subject: Reply with quote
sorry to mislead. it is not a weber ict i meant to type pict
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Mar 15, 2011 5:20 pm    Post subject: Reply with quote
Is this a type 1 engine?
