Notablecarrot3 Samba Member
Joined: January 22, 2008 Posts: 461 Location: Sunny South Of France
Posted: Tue Mar 15, 2011 11:39 am Post subject: Electronic ignition problem? |
Hi guys!
I came back from a weeks skiing holiday and my bug wouldn't start, cranks over strongly but has no life in it whatsoever!
So I was thinking it was my compufire electronic ignition replacement module. I've tried another ignition coil and it's not that.
What would you suggest it is? I just want to be sure before buying a new electronic ignition module!
Thanks
Tom _________________
EverettB wrote: |
Your Donkey has a large head. I like your donkey. |
EverettB wrote: |
Is it wrong to be jealous of their facial hair abilities? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Mar 15, 2011 11:41 am Post subject: |
Put a set of points in and if it works, the module is dead. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 15, 2011 11:42 am Post subject: |
I don't have a set of points to try it, is there any other possible way of testing? _________________
EverettB wrote: |
EverettB wrote: |
vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Tue Mar 15, 2011 4:12 pm Post subject: |
Notablecarrot3 wrote: |
I don't have a set of points to try it, is there any other possible way of testing? |
make sure you have 12V on + side of coil, then touch and release a ground wire to - side. Coil should fire each time you remove the ground wire. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Mar 15, 2011 6:13 pm Post subject: |
As you're finding out you should always keep a set of points as a spare for just in case. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
