74 cali Samba Member
Posted: Thu Oct 10, 2013 9:31 am Post subject: |
Joel wrote: |
On all ignition switches I've got after 70 the terminal is S rather than SU and is positive when the key is in not ground.
I know that this thread is a few months old, but that is good to know. I have a 74 which I assume has a 74 switch and was confused about the wires to the switch. I believe the back of my switch has an "S".
http://www.thesamba.com/vw/forum/viewtopic.php?p=6870081&highlight=#6870081 |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Thu Oct 10, 2013 3:45 pm Post subject: |
According to all sources the 73 onwards cars with alternators all had the S wire which is positive with the key in.
Every 71-73 Aussie made bug I've pulled apart has been the same but apparentnly North American 71-73 generator cars have the negative output.
I think it is possible to reconfigure the switch so they can do either or.
There is a plastic cap inside the center of the ignition switch where the key barrel center pushes in and it depends where that is placed as to what the the buzzer wire output is.
On the top side it makes the buzzer contact ring (in the pic below) touch the center battery feed so its positive, the cap on the bottom isolates it from the battery feed and instead contacts it with the base of the key barrel so it grounds instead.
It's only a matter of using a meter or test light to find out which way it is.
A-Wild Samba Member
Joined: January 14, 2013 Posts: 48 Location: Edmond, OK
Posted: Mon Dec 18, 2017 8:13 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Has anyone seen this set up? I expected to see slide terminals. Instead soldered connections. _________________ 1971 Clementine Orange VW Convertible
1971 Karmann Ghia Coupe - Bahia Red |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Mon Dec 18, 2017 8:24 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
A-Wild wrote: |
Has anyone seen this set up? I expected to see slide terminals. Instead soldered connections. |
What year is yours? Older have switch like that, to 1971 for sure, maybe 1972.
I'm from Pittsburgh myself, still reeling about what makes a touchdown a touchdown !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Mon Dec 18, 2017 8:36 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
'71 was the last year that the wires were soldered to the bottom of the ignition switch. From '72-on they used male spades at the bottom of the switch and a multi wire female plug at the ends of the wires.
If one of your wires is black/yellow (X) then it is a '71 ignition switch. Prior to '71 there was no black/yellow wire coming from the ignition switch.
It looks like your ignition switch fell apart. _________________ AshMan40
A-Wild Samba Member
Posted: Mon Dec 18, 2017 9:13 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
ashman40 wrote: |
It looks like your ignition switch fell apart. |
Yeah it's a 71 Vert. I'm embarrassed to say how it " fell" apart but here I am. Not having much luck finding that piece on line. Any ideas? _________________ 1971 Clementine Orange VW Convertible
A-Wild Samba Member
Posted: Mon Dec 18, 2017 9:15 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Cusser wrote: |
A-Wild wrote: |
[img]https://www.thesamba
I'm from Pittsburgh myself, still reeling about what makes a touchdown a touchdown !!! |
It's a 71 Vert. Yeah not a great finish last night! I'm from Elizabeth originally. _________________ 1971 Clementine Orange VW Convertible
Posted: Tue Dec 19, 2017 6:41 am Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
A-Wild wrote: |
Yeah it's a 71 Vert. ... Not having much luck finding that piece on line. Any ideas? |
You need the entire ignition switch (electrical) along with the pigtail of wires.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111905865F
An option that I was considering before I got rid of my Beetle.... using a '72 ignition switch:
And adding push on female spades to the ends of the existing wires. This save the trouble of running wires and makes use of a less expensive ignition switch ($13 vs. $35). You'll want to individually heat shrink tube the ends of the non-insulated crimp on terminals (you won't have the space to use the cheap insulated terminals). If you don't have access to these crimp on terminals then just go with the correct '71 ignition switch.
My suggestion is to add a HSR when installing an aftermarket ignition switch. This will extend the life of your new ignition switch. _________________ AshMan40
Cusser Samba Member
Posted: Tue Dec 19, 2017 7:07 am Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
$35 from WW ? Get it !!!
I replaced this part on my own '71 convertible at least 2 decades ago. My recommendation is DON'T get lazy and just crimp the wires to the old wires under the dash !!! FEED the new wires through the grommet and attach to the original male terminals/connectors.
The 1971 part is a one-year for beetles. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Dec 19, 2017 12:22 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
FYI, I also found the '71 ignition switch on EIS Part's site for $29:
http://www.eisparts.com/111905865F.html
I think that is where I bought mine from years ago. I installed it w/o the HSR thinking it was new and would last decades like the original one... as mentioned at the start of this thread, it stopped working a couple years later. Cleaned up the internal contacts, added an HSR and it ran for many more years until I got rid of the car. It never failed to crank.
Go for the WW one and maybe you will get lucky. I do like the quality of WW parts. But I would STILL install a HSR. _________________ AshMan40
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Tue Dec 19, 2017 12:27 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Try Rock Auto, I recently bought this style ignition switch and, although not a Bosch or Hella switch, it had a metal housing, not the plastic ones shown in the pics above. Quality was good too for about $35. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Wed Dec 20, 2017 3:27 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
I have the later model switches in stock, 111905865F. They are NOS German.
http://www.vwnos.com/ignition-switch _________________ www.vwnos.com [email protected]
heimlich VWNOS.com
Posted: Wed Dec 20, 2017 3:29 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Ashman,
Nice writeup. I don't throw away any of my used parts anymore. People figure out how to rebuild them eventually. _________________ www.vwnos.com [email protected]
sb001 Samba Member
Posted: Wed Dec 20, 2017 7:45 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Cusser wrote: |
I'm surprised those refs made it out alive _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Cusser Samba Member
Posted: Wed Dec 20, 2017 9:37 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
sb001 wrote: |
Cusser wrote: |
I'm surprised those refs made it out alive |
Apparently no coach or Steeler called for the timeout either. During the review. Steelers coaches were discussing that either it was touchdown or that ball might be on the 6-inch line and with 10 seconds run off, and were preparing Steelers for that. NO ONE foresaw that it would not be ruled a catch, when so may similar plays have been ruled touchdowns, Go to steelers.com to see the links and the explanations. I guarantee that if it had been Gronkus, would've been confirmed a touchdown in 15 seconds. All that time and announced "confirmed" as no catch, ridiculous..
SAD day for sports and for NFL, that's for sure. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Thu Dec 21, 2017 3:17 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Very good write up.
The Steelers call was textbook. They lost. Rule needs to change when breaking the plane but the refs technically got it correct.
I would suggest taking this to another thread but really, the NFL is less entertaining than this awesome write up. _________________ 1979 Bug project |
heimlich VWNOS.com
Posted: Mon Jan 15, 2018 3:06 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Along with the NOS ones, I've new Chinese ones for $18. For the ones I have, there are some pieces you can use on them as replacement parts for your original. PM or email me and I can set you up. _________________ www.vwnos.com [email protected]
heimlich VWNOS.com
Posted: Wed Feb 21, 2018 8:58 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
I've seen a number of ads lately of folks selling the 111 905 865 F NOS switch for quite a bit of money. I want to point out that I've seen a number of these switches and all of the plastic housings crack from age. There is a spring that sits behind the housing which exerts pressure on the plastic and cracks it. I see them sold "as is" so they might not take them back.
I replace the plastic on the ones I sell so they come in good condition. If you decide to purchase a NOS switch do make sure you ask the seller if the housing is cracked. _________________ www.vwnos.com [email protected]
heimlich VWNOS.com
Posted: Wed Feb 21, 2018 9:20 pm Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
Here's a picture of where they crack. They are repairable.
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Feb 22, 2018 9:23 am Post subject: Re: Dissecting the ignition switch electrical (wordy w/ pics) |
The original style one could come loose at the crimps like this on my car
Cleaned and recrimped:
Working well for over a year now. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
