markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Fri Mar 18, 2011 3:22 pm Post subject: Who needs a Ladder - "the stripper pole" |
It's Friday.
The concept is to use two 4' pieces of PVC pipe to make a long telescoping pole allowing the user to reach the roof rack. The base pole would be 2" in diameter, the upper pipe/pole is 1-3/4" in diameter. Holes drilled (horizontally) in the ends would allow a user to insert dowels to hold the poles together in the extented position. Another set of holes and dowels would allow the user to place foot pegs/dowels pretty much anywhere they wanted, but most likely below or at the point where the two poles overlap. The top of the pole is simply bungeed to the roof rack cross bar that hangs over the side of the van, creating some stability. The pole could be broken down and storred easily.
I think this would let some one get 4' of height to reach the assorted roof racks.
Crazy? _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
fastwagens Samba Member
Joined: March 01, 2004 Posts: 1028 Location: Michigan (The other west coast)
Posted: Fri Mar 18, 2011 3:48 pm Post subject: |
Crazy! |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6243 Location: Portland OR
Posted: Fri Mar 18, 2011 3:49 pm Post subject: |
Yes. It sounds crazy. I found one of these and use it occasionally. I actually cut it in half and just use one side leaned up against the van. It folds to about the size of a 4" length of PVC pipe and straps up top or fits in the box.
http://www.amazon.com/Double-Sided-Compact-Folding...amp;sr=1-2 _________________ 89 Westy 2.1 Auto |
1621 Samba Member
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Fri Mar 18, 2011 4:08 pm Post subject: |
I would be very worried about the pvc splitting at the dowels once weight was applied.
I can imagine it now; about 3 feet off the ground, lifting something off of the roof rack, balancing awkwardly as the pvc flexes and twists when
BLAM!! The thing explodes.
A 1 foot sliver of pvc slides into your calf and up past your knee, just under the skin. CRACK, that's the sound of your ankle snapping when it hits the ground at some weird angle. But don't worry, you won't feel the pain for long because that thing from the roof rack is just about to land on your head knocking you senseless. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Mar 18, 2011 5:29 pm Post subject: |
yah mahn, loco.
I think PVC and wood dowels will not last in the long term.
I saw a sweet ladder at Mogfest 2010.
It was made of welded tube steel or aluminum. It separated into 2 parts for storage. Very simple and stout. I think sturdy is what you want in a ladder.
Hey, you have a machine shop at your disposal, right? make one of these and I will buy it in a flash.
(Hey lookie, I actually found a photo!)
_________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6349 Location: Honolulu,Hawaii and France
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Fri Mar 18, 2011 8:42 pm Post subject: |
What about something like this?
_________________ 91 CARAT |
