bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Mon Mar 21, 2011 2:01 pm Post subject: Driver's Seat Stuck! |
I know it's happened to someone...I moved my seat ahead to search for a dead carcass...(it stinks in there) now I can't get it to slide back.
I am going to look closer tomorrow as I ran short of time today.
Any tips or help or sarcastic suggestions would be appreciated!
And no...I haven't found the stinker yet either!
Brian. _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
Posted: Mon Mar 21, 2011 2:08 pm Post subject: seat |
Thanks, I will take a look tomorrow.
Any idea where the dead mouse is?
hehe.
crowinghen Samba Member
Joined: July 12, 2010 Posts: 423 Location: near Seattle,wa
Posted: Mon Mar 21, 2011 2:15 pm Post subject: Re: seat |
bjrogers86auto wrote: |
hehe.
Brian. |
In one of the pillars?
good luck!
Susie _________________ 1984 Westfalia a work in progress " Butters" |
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1085 Location: San Francisco
Posted: Mon Mar 21, 2011 2:25 pm Post subject: Re: seat |
hehe.
Brian. |
It's in the van. _________________ BenT |
Timwhy Samba Member
Posted: Mon Mar 21, 2011 2:50 pm Post subject: Re: Driver's Seat Stuck! |
Brian. |
Brian use your own advice BFH
I have had my drivers seat get stuck a few times while removing it and when I recently purchased
some seats out of an L. That drivers' side was also stuck. Both seats it was this plastic sleeve that
got caught under the track. Took two of us on the L seat, one pushing and the other hammering
on the lower back of the track. If you go the hammer route make sure that you remove the
plactic from the seat reclining hinge. Also you don't really need to start out pounding the piss
out of the thing. Sorry can't help with the mouse thing, unless you have a dog? _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Posted: Mon Mar 21, 2011 3:39 pm Post subject: seat |
Nope, no dog. Just a flashlight and a sensitive nose. I really hope it's not in the pillar! On a test drive today it didn't get worse when the heat started flowing. A good indicator it's not in the heater.
I do however, have a BFH or two! I shall investigate more tomorrow. The van is still in it's winter home.
I was out today to change calipers, flex lines and dust shields. Have you changed those flex lines? The upper connection on the drivers side? That's just cruel! I won though...with some help from the BFH!
Thanks,
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Mon Mar 21, 2011 4:07 pm Post subject: |
the driver seat of mine got stuck real hard sometimes...
to unstuck, you need a helper. You sit on the seat, pull the lever and push hard on your legs. The helper get behind the seat, grab the lower part of the back and pull hard..
will help a bit if you make some sort of rocking motion...
good luck |
Posted: Mon Mar 21, 2011 4:37 pm Post subject: seat |
The seat seemed to move a few inches back and forth...but stopped solid in both directions.
Thanks again for the help.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Mon Mar 21, 2011 4:46 pm Post subject: |
One of the allen head bolts holding the seat rails to the base backed out and is now stuck in the track. You have to inspect it from the rear of the seat and figure out which rail it is jammed in and try to fish it out.
Good luck. |
Posted: Mon Mar 21, 2011 5:53 pm Post subject: seat |
Man! You can see that from there! Cool!
Thanks,
I'll keep you posted.
Posted: Mon Mar 21, 2011 6:00 pm Post subject: |
I had to squint a little bit, but that is what it looks like from here. |
Blueconundrum Samba Member
Joined: September 07, 2010 Posts: 148 Location: Bozeman, MT
Posted: Mon Mar 21, 2011 8:48 pm Post subject: |
syncrodoka wrote: |
I'm going to second that motion with my laser vision. Happened to me - just keep bashing and jiggling until the bugger pops out or you can roll over it. A two person job. _________________ 1988 Vanagon Syncro EJ22 |
Posted: Tue Mar 22, 2011 9:23 am Post subject: seat |
Well...let me tell you...that was fun. It was the allen bolt. You guys were right.
In order to get it I had to remove the seat and swivel base from the van. The seat is supposed to be removed before you remove the base. It's not fun removing both at the same time. I won though!
Now I have a cleaning job on the carpet to do but the seat works great!
No mouse found.
Thanks for the tip!
Brian _________________ 86 Vanagon GL Westfalia 2.1
Zero419 Samba Member
Posted: Tue Mar 22, 2011 9:35 am Post subject: |
I think there is a cap under the van or in the wheel well so that you can drain the pillar.
Pull that out and maybe try to flush it out with water? _________________ 1987 Westy Auto Bostig 2.0 Ztec |
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Tue Mar 22, 2011 10:10 am Post subject: |
Blueconundrum wrote: |
just keep bashing and jiggling until the bugger pops out or you can roll over it. |
Are you talking about the seat or the mouse? _________________ 1984 Westy with tencentlife power! |
Posted: Tue Mar 22, 2011 11:43 am Post subject: |
MootPoint wrote: |
Are you talking about the seat or the mouse? |
The allen bolt, actually, but congrats on nearly getting soup on my keyboard from making me laugh out loud. _________________ 1988 Vanagon Syncro EJ22 |
Posted: Tue Mar 22, 2011 1:05 pm Post subject: seat |
Better on the keyboard than up your nose....hate that!
B. _________________ 86 Vanagon GL Westfalia 2.1
Posted: Tue Mar 22, 2011 3:41 pm Post subject: |
Blue loctite on those allen bolts before tightening down makes that problem in the future a non-issue. |
Posted: Tue Mar 22, 2011 4:11 pm Post subject: seats |
Unfortunately the loctite wasn't in my bag of goodies but home in my basement. When the van comes home for the season I will do that project one warm and sunny day, especially now that I am so familiar with seat construction. I have a feeling the swivel will need some adjustment anyhow.....
Thanks,
