VolkswagenGerry Samba Member
Joined: February 02, 2010 Posts: 220 Location: San Rafael Ca.
Posted: Wed May 29, 2013 11:52 pm Post subject: |
I will post a few questions here as this seems to be the most comprehensive exhaust thread I have found here..
I am going to add a baffle to my tri-mil sidewinder exhaust.
This baffle:
http://www.mooreparts.com/store/product/1043/Baffle-Trimil-Stinger/
Its sounds great wide open and all but over a long drive.. huh what?
Did you say something.. .. so I am hoping the baffle wil help some?
Shall I tack weld it in place inside tube?.. or slip it into exhaust then drill a pilot hole and tap some threads and possibly a allen head BOLT to hold the baffle into tube??
Will the thickness of the pipe combined with the thickness of the baffle insert lip be enough to hold threads??
Or... tack weld a small NUT into baffle lip and secure with a bolt.. same concept as above.. just more threads right?
Side note.. I have a ceramic exhaust and certanly dont want to mess up the finish..
joescoolcustoms Samba Member
Posted: Thu May 30, 2013 3:43 am Post subject: |
Don't weld on the header if you value the finish.
I have used stainless steel rivots in the past with good results. Typically three around the perimeter. This way they can be drilled out and the baffel removed if so desired.
My drag race header had screws holding some parts together and they would need to be tightened every few passes due to vibration. I was turning 8500 rpm, but, over time, on the street it would suck to loose the screw(s) and the baffel shoot out/get ruined. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Thu May 30, 2013 7:54 am Post subject: |
Good idea.. I didnt think of rivits.. |
Vilem43 Samba Member
Joined: June 06, 2012 Posts: 5 Location: Rosenberg, Texas
Posted: Tue Jul 02, 2013 12:52 pm Post subject: |
I came across this discussion, and have a question. I saw where andk5591 had dual cannons with glass-wrapped baffles and they were loud. Was that loudness with the glass wrapping?
I'm running dual cannons and been told wrapping the baffles in fiberglass or steel wool would tone them down some. I'm not after quiet, just want to tone them down a bit. Does this work, and will it do any harm to the engine? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Tue Jul 02, 2013 3:07 pm Post subject: |
The glass wraps help until they blow out. I was getting muffler wrap from motorcycle shops.
Gonna have to remember to take a pic of what I finally ended up with on of these days. And honestly, if performance is the concern, you dont run dual canons anyway.
Also, it depends on what kind of baffles you are using. I got inserts with a perforated tub down the center and wrapped the oustide with the muffler wrap. Took the edge off the exhaust note.
See the thing is that if I cant have a conversation with the person next to me without screaming, its too loud. And after an hour or more, my ears just get fatigued..... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Wed Jul 03, 2013 10:58 am Post subject: |
It sounds like what you did is exactly what I'm after: Just want to tone it down a bit so conversation would be a bit easier than it is now.
Is what you bought at a motorcycle show simply called "muffler wrap" and am I assuming correctly you wrapped the baffle, not the outside of the cannon? And, about how long did it last till it burned out?
I'd love to see your pictures |
Posted: Wed Jul 03, 2013 11:20 am Post subject: |
Yeah - wrap the baffle with "muffler wrap" - its like a fiberglass sheet. Secure it with some wire. Lasted a few months. _________________ D-Dubya Manx clone - 63 Short pan,1914.
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Wed Jul 03, 2013 12:55 pm Post subject: |
You might consider adding a clamp-on Supertrapp disc-only series baffle with 12-14 discs to slightly baffle the noise...
Like this > http://www.ebay.com/itm/SuperTrapp-Disc-Only-Muffl...0940506689
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
GreenImp Samba Member
Posted: Sun Sep 08, 2013 9:41 am Post subject: |
As old as this thread is, it's a great discussion on buggy exhaust options. I wanted to add my experience/opinion to this great list for others to consider. My buggy was a sand rail, but this information would still work on a fiberglass buggy as well.
I was and still am dead set on using dual exhaust for looks and engine access. I couldn't care less about the claimed "power loss". I more than made up for this elsewhere anyway.
At some point in the 90's I think it was, Oregon added sound restrictions for riding in the dunes. I tried a number of different configurations, including the Supertrapp clamp-on "Disc-only" option that didget69 posted above (I used the larger 5" version, and I think I had it welded on though). This sounded great in my opinion and almost made it quiet enough to be legal. For me however, the problem was the additional weight and length. When riding wheelies the Supertrapps would dig into the sand.
The next and best option I tried, was what pitcrew posted above but without the crossover pipes. I simply bought a new set of dual glasspacks, cut off the mufflers and welded on the Supertrapp mufflers (black version). I then added additional clamps to hold the exhaust better during the rough ride. This was by far the best set up I ever used, and I eventually sold the buggy with this still on it over 10 years later.
Here is a picture of the dual Supertrapp mufflers installed. I wish I had a better/closer view of the exhaust, but don't.
dexter69 Samba Member
Joined: August 30, 2013 Posts: 61 Location: spring branch tx
Posted: Tue Sep 10, 2013 6:49 pm Post subject: |
Fricken sweet buggy!!!!!!!!!!!!!
GreenImp wrote: |
fRDD |
don't_bug_me Samba Member
Posted: Wed Sep 11, 2013 12:21 pm Post subject: |
junior55 wrote: |
I always like to post my homemade quads when someone looks for
options to duals.
Performance loss ?
I invite you to test drive these to find it. |
would love to see more pics of this buggy |
donbarnes Samba Member
Joined: February 28, 2011 Posts: 731 Location: Wilmington,NC
Posted: Sat Sep 28, 2013 4:42 am Post subject: |
I'm just going to throw this in so the info will be there for anyone following the thread.. For fans of the dual cannons, dual exhaust etc, someone now makes a stainless set:
http://www.ebay.com/itm/VW-air-cooled-Buggy-dual-e..._958wt_918 _________________ Hater of cheap parts and poor workmanship.. |
Posted: Sat Sep 28, 2013 4:52 am Post subject: |
didget69 wrote: |
... and I hate the 2-bolt muffler flange. Mine are warped...
bnc |
Another way around the warped flange thing is to double up the flange, order some extra flanges and run a solid bead around the outer edge of two them, then sand the weld back smooth.. I've been doing it for years on both VW stuff and the old Mopars that used a flat two-bolt flange and never had one warp after that.. (yeah I know that post was over two years old, but some people like me still look them up for useful info ) _________________ Hater of cheap parts and poor workmanship.. |
Posted: Sat Sep 28, 2013 5:54 am Post subject: |
Dang, that is a cheap price for SS! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sat Sep 28, 2013 6:11 am Post subject: |
As someone pointed out on a different thread, shipping is $99, but that still leaves you only $260 in a complete stainless exhaust if you like duals and if the quality is any good.... _________________ Hater of cheap parts and poor workmanship.. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Sep 28, 2013 9:26 am Post subject: |
I looked at that those recently when shopping for exhaust for my neighbors buggy.. She wants a "shiney motor".....
She wanted another chrome set which I talked her out of, really was contimplating the stainless ones from China on ebay. I asked the seller, and they claim they have baffles built in..
I ended up ordering the ceramic ones.
If somebody buys the stainless or "rustless steel" ones... lets us know how they are, sound, fit, quality, true stainless etc.... _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sat Sep 28, 2013 8:20 pm Post subject: |
... maybe the pallet in the seller's ad foretells the tale of how long the quality lasts?
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Zcarnut Samba Member
Joined: July 16, 2006 Posts: 409 Location: West Palm Beach FL
Posted: Sun Sep 29, 2013 7:12 am Post subject: |
I've used both styles & prefer the first option, as it uses a combination of discs and a glass pack baffle in the housing. Measure the OD of your U-bend to verify if it's 2".
Posted: Sun Sep 29, 2013 10:24 am Post subject: |
I have that first option on my current buggy and it is a lot quiter than I ever expected, but still flows very well.
