Fuse issues with SA grille & headlight relay?
jalexis
jalexis is offline
PostPosted: Thu Mar 24, 2011 12:16 pm    Post subject: Fuse issues with SA grille & headlight relay? Reply with quote
Hi all,
About a year ago I did the South African grille and headlight relay upgrade to my '91 Westy. The process was pretty straightforward, and all appears to be working fine under normal circumstances. However, on two separate occasions, I've had one or both high-beam fuses burn out. In both cases it has been after the high beams have been on continuously for approximately 10 minutes.
I've done a bit of research, but haven't found any references to changing the fusing for the relay upgrade. Has anyone else run into this? The behavior makes me think that it's an issue of running too much current through the fuses, rather than a short. The installation seemed hard to screw up, but maybe I've done something wrong? I'd be really grateful for any input on this.
Just signed up on the Samba today after a few years of occasional lurking. I've got a '91 Syncro Westy with a 2.5 Subaru engine and lots of the "standard" upgrades, looking forward to contributing here.
blakeck2
blakeck2 is offline
PostPosted: Thu Mar 24, 2011 12:19 pm    Post subject: Reply with quote
Did you change the Fuses to 20amp? Did you add an extra ground to the light harnesses? If both have been done, Its the bulbs themselves causing the excessive draw, Ive ran into the problem a couple time
1986 Vanagon Syncro GL, westy interior, GW 2.4 and all locked up
1973 Thing
View user's profile Send private message AIM Address Facebook Classifieds Feedback
dhaavers
dhaavers is offline
PostPosted: Thu Mar 24, 2011 2:25 pm    Post subject: Reply with quote
My headlight relay kit said to add 5A to the stock fuses when running the high wattage bulbs.
So far no problems here...
86 White Westy Weekender
"The WonderVan"
jalexis
jalexis is offline
PostPosted: Thu Mar 24, 2011 2:31 pm    Post subject: Reply with quote
OK, I think that must be it, I'm still running 10A fuses. Maybe I missed some fine print somewhere, but I did go back and try to find fuse references and didn't see any.
In any case, thanks for the help guys. I guess I'll start with 15A and see how that goes.
