Desertbusman Samba Member
Posted: Tue Apr 12, 2011 12:11 am Post subject: |
kreemoweet wrote: |
'70 front drum diameter - 250 mm.
'72 rear drum diameter - 252 mm.
'70 front shoe lining width - 45 mm.
'72 rear shoe lining width - 55 mm.
Not even close, dude. |
Party crasher
It would have been fun trying to use fronts on the rear since they are totally different shape anyway. Square hole- round peg type thing.
Amazing what important info can be found in the service manual.
At the same time it seems like some folks said that some of the late backing plates don't have the holes for the retaining pins. _________________ 71 Superbug
71 Westy |
BumbleBus Samba Member
Posted: Tue Apr 12, 2011 7:04 am Post subject: |
kreemoweet wrote: |
Cool. Thanks for the info.
Anyone wanna buy some new '70 front shoes... cheap? |
Posted: Tue Apr 12, 2011 7:06 am Post subject: |
Desertbusman wrote: |
It would have been fun trying to use fronts on the rear since they are totally different shape anyway. Square hole- round peg type thing. |
Yeah well necessity is the mother of all invention don't ya know. Label me dumb, but it's not like I'm the only bay owner that's tried to save a few pennies trying to fit a square peg in a round hole. That's practically a requirement in owning a bus.
Thanks for all the info. Moving on... |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Tue Apr 12, 2011 3:29 pm Post subject: |
after much frustration, and multiple trips to the auto store, I completed the driver's side rear done.
first I looked at the drum, not to bad, cleaned it up a little, and will reuse it.
hard to see but the part number is still visible
I cleaned the inside of the drum, some brake fluid got everywhere so I sprayed it, cleaned it, let it dray and towel dried them
There is still a ton of lining left on the shoes, so they will be reused as well. On the inside of the shoe it says, "made in canada"
I spent forever trying to get them on. I had to walk away and have a beer at one point
Done. I put anti seize on the adj stars before install.
The upper spring is a PITA to get on and work with. I was swearing up and down getting that thing on there
picture before it gets lowered
In all, I hated the job. Took all day to clean, read, figure out how to get the new shoes on. In the end, it probably only took 30 to do the whole job. But whatever, now the passenger side will go much faster. _________________ 77 Westy - Cape Cod Sage
LLAP |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2036 Location: Philly, PA
Posted: Tue Apr 12, 2011 3:59 pm Post subject: |
60vwnewengland wrote: |
Bend those adjuster nut springs into place! |
Posted: Tue Apr 12, 2011 4:09 pm Post subject: |
mattcuddy wrote: |
don't worry I did _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Wed Apr 13, 2011 6:11 am Post subject: |
question! I'm going to get New KYB GR-2's. Do I need the mounting kit for the front as well? I know I needed them for the rear, but do I need the mounting kit for the front? I can't remember.
Thanks! _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Thu Apr 14, 2011 8:19 pm Post subject: |
well.......I did a little more work today. I worked on my adj beam a little
I took the passenger side torsion arms out, and cleaned up the spindle a little
New ball joints from Wolfgang International. $200 with core exchange. Not bad price for me,
And I installed the new KYB GR-2's in the rear!
Can't wait to see what the ride will be like. _________________ 77 Westy - Cape Cod Sage
LLAP |
canes5time Samba Member
Joined: October 25, 2008 Posts: 124 Location: Boca Raton, FL
Posted: Fri Apr 15, 2011 12:24 pm Post subject: |
Are you working on this inside your house? |
Posted: Wed Apr 20, 2011 9:12 am Post subject: |
canes5time wrote: |
yes I am. The girlfriend isn't too happy _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Wed Apr 20, 2011 9:16 am Post subject: |
got some fresh disc brakes from a local shop. They had to blow the box off with the air gun to get all the dust off of them. On the side of the box in large letters it said, "Made in Germany"
LLAP |
Posted: Tue Apr 26, 2011 6:28 pm Post subject: |
did a little more work today. I took Rady's advice and got some stainless steel line from aircooled.net. Should have nice results when done. Should have the job done on friday
LLAP |
Posted: Thu Apr 28, 2011 6:58 am Post subject: |
Quick question. I'm installing new pads in the front calipers. I am retracting the pistons in the calipers. Now the piston that is on the same side as the brake line, does that one retract? I got the otehr piston on the other side to compress, but does the piston on the side with the brake line compress as well? _________________ 77 Westy - Cape Cod Sage
LLAP |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 28, 2011 7:23 am Post subject: |
Yes, it does (or should). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Apr 28, 2011 10:52 am Post subject: |
Quick question. I'm installing new pads in the front calipers. I am retracting the pistons in the calipers. Now the piston that is on the same side as the brake line, does that one retract? I got the otehr piston on the other side to compress, but does the piston on the side with the brake line compress as well? |
If it is not seized this is the tool that will retract both pistons at the same tme.
Posted: Thu Apr 28, 2011 7:20 pm Post subject: |
ToolBox wrote: |
Ya I figured out that I could just use the old pad, and a c-clamp to compress the piston.
LLAP |
Posted: Fri Apr 29, 2011 8:17 pm Post subject: |
finish up a bit today
New adj beam. Lowered 3 or 4 inches
worked on it all day. Started with installing new pad in the calipers, and ended with the test drive.
Question. It feels like the brake booster isn't boosting. To compare, it feels like i'm driving my brother's split window. I have to really put some pressure on the brake pedal. The booster isn't helping in the braking process. Does that sound right?
We've adj. the rear a few times. Changed the vacuum lines up front, and have checked them for vacuum. we can feel air coming from the engine coming out of the hose. The master cylinder seems fine, and the booster worked when we swapped it out. What could be the problem? _________________ 77 Westy - Cape Cod Sage
LLAP |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Fri Apr 29, 2011 10:11 pm Post subject: |
Have you checked your one way valve near the manifold on the brake booster line? Air should only go one way and it needs to be orientated the proper way. |
Posted: Sat Apr 30, 2011 5:22 am Post subject: |
71whitewesty wrote: |
yes. I'm pretty sure that the check valve is working properly, there is air coming out of the hose. A buddy was under there as I rev'd the engine and he put is thumb on the vacuum line, and he said it was working.
Booster... _________________ 77 Westy - Cape Cod Sage
LLAP |
