ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6349 Location: Honolulu,Hawaii and France
randywebb Samba Member
Sam Bateman Samba Member
Joined: August 07, 2010 Posts: 101 Location: Arvonia,VA
Posted: Tue Aug 09, 2011 12:57 pm Post subject: Re: Work |
ftp2leta wrote: |
bjrogers86auto wrote: |
I think your site is the sticky Ben! I have been using it for two years now as a reference. I had pictures printed for the intake/fuel line rebuild. I used it for the driveline work. It's like the Wikipedia for Westy's!
Thanks for everything!
Brian |
I miss NS... such a nice place. |
Me too Benny.
I can't believe it's been 10+ years since I've been able to get up there.
Soon... maybe I'll get there again.
I have also used your website as a reference for several projects on my Westy. The abundance of pictures makes it easier for an old mind to understand!
Thank You again for all that you do for the preservation of this vehicle and to help out folks who own them. |
vanjoe Samba Member
Joined: December 25, 2009 Posts: 606 Location: Santa Maria
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Sat Sep 10, 2011 1:07 pm Post subject: |
X2 !!! I got a hot start relay from ThatVWBusGuy - really nice! Postive Bat cable next.
What does anyone think aboutrebuild on starter, new brushes in Alternator?
John |
Posted: Wed Nov 16, 2011 6:21 pm Post subject: |
1. replace the fuel lines - use the right type of clamps
2. Tail pipe: Grey=OK, sooty/oily/greasy??
3. replacing all the rubber brake hoses every 16-20 years is an important safety matter.
4. Check for rust under mat at front seat belt anchor points (remove 17mm bolt to check).
5. Check rear belt anchor points over wheel well. (Both are very common--and hidden--rust spots)
6. Inspect/replace the seals for the hook-ups on the side
Engine Compartment:
1. Check oil cap and dipstick for signs of water. (Oil off-color, brown/grey/white or bubbly)
2. Compression test: (disconnect coil, remove ALL plugs)
3. Spark Plug condition? (OK? Burnt? Oily? Sooty?)
Underneath:
1. Axle beam lubrication points in good shape? Residual grease still there?
2. Axle beam has excess grease showing at both ends of beam (kept greased)?
3. Check for rust on axle beam (screwdriver). Joint with steering box OK?
4. End plates, connection to body OK? Rust apparent anywhere else on beam?
5. Fuel pump not secure – redo the strap.
6. check for leaks at the power steering rack; boot deterioration??
7. steering damper in place? - inspect steering rack boots
8. check for coolant leaks at the rear heater core (with a running engine - sniff for sweet smell of coolant)
9. Condition of engine or trans. grounding cable?
10. Constant velocity joint boots?
11. shocks & struts damp/oil leaks??
12. check the fuel tank for leaks
13. Ball joint boots intact (upper & lower, check carefully)?
14. Tie rods straight? Tie rod end boots intact?
15. Check for fluid leaks after shutdown. (Oil, Trans, Fuel, Differential)
16. replace radiator pressure cap _________________ 1986 2.1L Westy 2wd Auto Trans. |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Wed Nov 16, 2011 7:11 pm Post subject: |
I don't have my van or manual handy: is this vacumn line special or can a piece of rubber hose take its place?? _________________ 1987 Westy |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Wed Nov 16, 2011 7:41 pm Post subject: |
Yes. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Nov 16, 2011 7:47 pm Post subject: |
As in: rubber hose is an excellent upgrade. I'll be doing this. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Wed Nov 16, 2011 8:22 pm Post subject: Re: Vanagon maintenance (1983-2011) |
ftp2leta wrote: |
Automatic:
-Bypass the start wire in the shifter box! YES! join the two big red wire together. |
I noticed this in Ben's original post. I don't believe that I've ever seen this suggested before. What does this fix or prevent from happening? Is there a related thread for this mod? What does it disable?
I absolutely trust Ben's judgement, I just want to know exactly what I'm doing and why.
This is an excellent thread, by the way. Thanks, Ben. You've helped me a ton throughout my Vanagon adventures. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
Posted: Wed Nov 16, 2011 8:23 pm Post subject: |
dhaavers wrote: |
As in: rubber hose is an excellent upgrade. I'll be doing this. |
Nothing special hose-wise?? You know, how the oil tower hose needs to be able to withstand the oil fumes and such.... _________________ 1987 Westy |
Posted: Wed Nov 16, 2011 8:29 pm Post subject: |
SteelB12 wrote: |
dhaavers wrote: |
Nothing special hose-wise?? You know, how the oil tower hose needs to be able to withstand the oil fumes and such.... |
This is what is prescribed. It's nearly impossible to find at a FLAPS.
http://www.van-cafe.com/home/van/page_831_133/3.5mm_vacuum_line_sold_by_meter.html
I'm currently using it with good success. One meter would replace all of the vacuum line and give you some spare to take with you. Cheap insurance.
Anybody have an answer on that automatic shifter question? _________________ "See The Glass As Already Broken."
Posted: Wed Nov 16, 2011 8:31 pm Post subject: |
SteelB12 wrote: |
Standard rubber vacuum hose...nothing but air inside. (until the FPR gushes...)
ID ~1/8"??? <guessing> _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Wed Nov 16, 2011 10:07 pm Post subject: Re: Vanagon maintenance (1983-2011) |
indytriple wrote: |
This is an excellent thread, by the way. Thanks, Ben. You've helped me a ton throughout my Vanagon adventures. |
Ok, lately, no, over the year I have seen so many friend and customers left stranded over a stupid ignition switch or.... a dead contact switch, the automatic van have the ignition going into the SHIFT (DR12) system, basically if your not on DRIVE or NEUTRAL the van won't start. That contact switch is a safety switch embedded into the automatic shifter, of course, over the year thew small metal piece that make the "CONNECTION" is wormed out so it make a bad start connection.
That part can be bought... so you don't have many possibilities here. Bypass this one. Simply connect the to big red wire together.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
cannonfodder4j Samba Member
Joined: October 21, 2010 Posts: 115 Location: Hudson Valley, NY
Posted: Thu Nov 17, 2011 6:56 am Post subject: |
when you say remove rear heater, does that mean replace? or cut out of the circuit? _________________ 1963 Beetle Type I
1964 Beetle Type I
1985 Vanagon GL Subaru EJ22 "Bruce" |
debbiej Samba Member
Joined: December 14, 2008 Posts: 1554 Location: las cruces, nm
Posted: Thu Nov 17, 2011 7:35 am Post subject: |
Ben, thank you for taking the time and care to post this information! It is exactly what vw owners like me need to know. |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Thu Nov 17, 2011 8:03 am Post subject: |
Ben good drawing love the info , but the only thing i can say if you drive a vanagon you should maintain it. There not cheap to keep up so if you cant afford to buy a prius. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
