Craigbro Samba Member
Joined: January 26, 2021 Posts: 186 Location: Louisiana, USA
Posted: Wed May 19, 2021 5:44 pm Post subject: Re: Sanding block for curved surfaces? |
For the DIY'ers, I used a $10 garden kneeler from Lowes to make some flexible sanding blocks that work great on the curved surfaces of our vehicles. I just ripped the rubber pad with my table saw and cut to different lengths. It is simi-rigid but more flexible than DuraBlocks and working great on my Karmann Ghia. They are approximately 1.5 inches thick so similar to the DuraBlock size. Very comfortable to work with.
Here's a few pictures of the original pad and some of my blocks.
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Thu May 20, 2021 5:35 am Post subject: Re: Sanding block for curved surfaces? |
Another DIY option is a computer keyboard wrist rest. I have an older one made of a flexible dense rubbery material. it is about 18" x 2.5" and adapts well to all kinds of bends.
...and yet another DIY alternative.
_________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
beetlenut Samba Member
Posted: Thu May 20, 2021 8:47 am Post subject: Re: Sanding block for curved surfaces? |
I made a bunch of different sizes and shapes out of old flip flops. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Thu May 20, 2021 12:37 pm Post subject: Re: Sanding block for curved surfaces? |
Evil_Fiz wrote: |
That's a great video! |
Braukuche Samba Member
Posted: Sun May 23, 2021 11:19 am Post subject: Re: Sanding block for curved surfaces? |
If you use anything less dense that a Duro block keep a light touch otherwise you’ll force the surface into the low spots. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sun May 23, 2021 3:02 pm Post subject: Re: Sanding block for curved surfaces? |
Braukuche wrote: |
If you use anything less dense that a Duro block keep a light touch otherwise you’ll force the surface into the low spots. |
Agreed! I find that with all of the compound curves on the Ghia the "knee board" sanders are able to flex a bit more that the Durablocks and touch the surfaces better. But like you mentioned, a light touch keeps things level. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Wed May 26, 2021 5:03 pm Post subject: Re: Sanding block for curved surfaces? |
W1K1 wrote: |
I use duroblocks and sometimes plastic strips like this https://bkblocks.com/, just not that fancy |
Thanks!
I have seen the acrylic blocks several places and ended up picking up an acrylic sheet at HDepot and some epoxy so that I could laminate it to varying flexibilities. I've just made a couple of firm ones so far. I'll post a picture tomorrow.
Posted: Fri May 28, 2021 2:17 pm Post subject: Re: Sanding block for curved surfaces? |
Craigbro wrote: |
W1K1 wrote: |
Thanks!
I have seen the acrylic blocks several places and ended up picking up an acrylic sheet at HDepot and some epoxy so that I could laminate it to varying flexibilities. I've just made a couple of firm ones so far. I'll post a picture tomorrow. |
