Syncro Puch Badge
Page: Previous  1, 2, 3
nilza
nilza is offline
PostPosted: Thu Sep 24, 2015 3:04 am    Post subject: Reply with quote
still floating around the web somewhere
clift_d
clift_d is offline
PostPosted: Thu Sep 24, 2015 4:15 am    Post subject: Reply with quote
Ooh. Shiney! How would we go about getting hold of one of these?
Also, as you have everything on CAD, it would really simplify installation if you could make a PDF drilling template with badge outline overlaid with the pin locations.
1988 LHD T25 1.6TD Westfalia Club Joker syncro
nilza
nilza is offline
PostPosted: Fri Sep 25, 2015 1:19 pm    Post subject: Reply with quote
Good idea Clift, shouldn't be a drama.
They are getting closer to being available, but I am having a few dramas at the moment in regards to material quality. So at this point chroming is still being looked into, unfortunately this will bring the price above the fast forward product.
clift_d
clift_d is offline
PostPosted: Mon Sep 28, 2015 8:21 am    Post subject: Reply with quote
I like the stainless, but I'm sure there are those that will go for the chrome bling.
Is the idea that these will be fitted using stainless starlock washers, or glued, or both? If they aren't already then perhaps the pins could be sized to work with a starlock washer so that people have the choice - probably 2mm or 3mm would work.
nilza
nilza is offline
PostPosted: Tue Oct 06, 2015 2:35 pm    Post subject: Reply with quote
Currently the pins on the rear are the same placement as the original and are 2mm in diameter. How you fasten them is up to the individual. The tinnerman nuts used on the original are cheap and plentiful, surely there is a stainless alternative. But right now I am concentrating on getting the first batch out the door.
. On that note they are now in the process of being chromed and should be available in the states next month.
The advantage Clift of the 3D print is if you have a specific requirement for say, the size of the pin or placement of the pins (perhaps some numpty drilled holes in you van in the wrong place) in a few minutes that can be altered to suit.
clift_d
clift_d is offline
PostPosted: Wed Oct 07, 2015 7:17 am    Post subject: Reply with quote
Sounds ideal. I'm guessing tinnerman nuts are very similar to starlock washers in the way they work
Any thoughts about availability for the UK?
nilza
nilza is offline
PostPosted: Wed Oct 07, 2015 4:56 pm    Post subject: Reply with quote
Sorry Clift I didn't realise you were in the UK, that should not be a problem really, just a matter of time.
Ideally they need to be purchased in lots of 20 otherwise the price for plating gets out of control in singles. A fellow in the states was just the first to put his hand up to distribute.
Once the details are complete and a true costing can be established, I will advertise in the samba classifieds the single unit cost.
otiswesty
otiswesty is offline
PostPosted: Mon Apr 25, 2016 6:56 am    Post subject: Re: Syncro Puch Badge Reply with quote
Any update on these?
1978 Sage Green P22 Westfalia
Just a regular guy
nilza
nilza is offline
PostPosted: Mon Apr 25, 2016 1:09 pm    Post subject: Re: Syncro Puch Badge Reply with quote
There is a fellow in the states that purchased a pile of these,
His name is Ben, you should be able to contact him
His name on the forum is BenTsyncro, send him a PM.
BenT Syncro
BenT Syncro is offline
PostPosted: Mon Apr 25, 2016 1:15 pm    Post subject: Re: Syncro Puch Badge Reply with quote
I got the message from Otis. I'm traveling this weekend and haven't had a chance to answer all my messages.
BenT
16CVs Premium Member
16CVs is offline
PostPosted: Mon Apr 25, 2016 11:50 pm    Post subject: Re: Syncro Puch Badge Reply with quote
Me thinks there will be an ample supply of them at Syncofest this weekend. A little birdie told me that the plastic gods have been busy.
Stacy
Samba member # 14980
otiswesty
PostPosted: Thu Mar 08, 2018 6:30 pm    Post subject: Re: Syncro Puch Badge Reply with quote
Originals available from the Puch subsidiary in Graz
http://www.puch.at/en/spare-parts/accessories/4638_83668_shop_PUCH-EMBLEM-VW-T3-SYNCRO.aspx?LNG=en
Just a regular guy
bizarre
bizarre is offline
PostPosted: Fri Mar 09, 2018 7:16 pm    Post subject: Re: Syncro Puch Badge Reply with quote
I git one off Nils a while back for my steering wheel
Great quality
B-bear604
B-bear604 is offline
PostPosted: Sun Mar 11, 2018 11:31 pm    Post subject: Re: Syncro Puch Badge Reply with quote
what about http://www.van-cafe.com/adhesive-backed-puch-emblem
Brent H
1991 Westfalia Multivan "Vicki"
1986 Westfalia "Wolfsburg Edition" Lowered, RIP😭
2005 Jetta Wagon TDI
1985 Mercedes 380sl
otiswesty
PostPosted: Mon Mar 12, 2018 12:09 pm    Post subject: Re: Syncro Puch Badge Reply with quote
Yes, I got a couple of those as well. The only thing is that they are missing the mounting pins for those that want the original style.
Just a regular guy
JED THE SPREAD
JED THE SPREAD is offline
PostPosted: Thu Mar 21, 2019 1:29 am    Post subject: Re: Syncro Puch Badge Reply with quote
POW...
https://campervanculture.com/shop/vw-t25-t3-vanagon-syncro-steyr-puch-metal-badge/
Visit CAMPERVANCULTURE.COM real camping and video uploads
Subscribe to Campervan Culture by Email
Follow us on Facebook, Campervanculture.com
Page 3 of 3
