BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Sat Apr 02, 2011 7:38 am Post subject: Getting yoked |
Does this picture show the proper orientation of a 3 arm yoke for use on a 2.0 L?
I'm asking because I need to drill a hole in mine for the locking pin. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
SGKent Samba Member
Posted: Sat Apr 02, 2011 9:31 am Post subject: |
you will want to drill four holes because there will be times you flip it over while building. For example - I like to set the cylinders straight down then after the head is on flip it over. Same when installing rocker arms.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Apr 02, 2011 6:00 pm Post subject: |
Thanks SGKENT!
I knew you would reply with your insightful wisdom.
By four holes do you mean two matching pairs? If so, got any tips on making the holes line up. For example, did you drill with the yoke in the stand? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
SGKent Samba Member
Posted: Sat Apr 02, 2011 6:22 pm Post subject: |
BUSBOSS wrote: |
Thanks SGKENT!
By four holes do you mean two matching pairs? If so, got any tips on making the holes line up. For example, did you drill with the yoke in the stand? |
There are several ways but I simply put it in all the way, aligned it and then center punched where I wanted the holes. You can use a level if you are a perfectionist. On mine, and I suspect yours, there are buttons of welding on it that have to be ground to fit the yoke of the engine stand. If you don't have a stand yet I suggest the heaviest you can find as a fully dressed late T4 engine with exhaust and flywheel will take a cherry picker to move it. We found a used one-time engine stand locally for $50 and it works outstanding but the legs are too wide for my cherry picker so I have to monkey with things to make it work. Maybe someday I will change the leg design on the cherry picker so the engine stand will fit between it or the stand so it can go under it. The yoke is pretty good steel so keep it oiled or greased while drilling or the drill will dull. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Apr 02, 2011 7:30 pm Post subject: |
Mission accomplished!
Thanks! _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
SGKent Samba Member
Posted: Sat Apr 02, 2011 7:47 pm Post subject: |
BUSBOSS wrote: |
Thanks! |
Doesn't count unless you show us a photo _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Apr 02, 2011 8:58 pm Post subject: |
SGKent wrote: |
Doesn't count unless you show us a photo |
That brings new meaning to Ronald Reagan's phrase: "Trust, but verify."
Here ya go!
1976 Westfalia
SGKent Samba Member
Posted: Sat Apr 02, 2011 10:27 pm Post subject: |
Awesome!!! You will love the stand. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
manikmike Samba Member
Joined: January 01, 2007 Posts: 504 Location: Boston, MA
Posted: Sat Apr 02, 2011 10:52 pm Post subject: |
Hey Volks,
I have a yoke, but no stand - what are you guys using for a stand?
Cheers, Mike _________________ Mike
Boston, MA |
SGKent Samba Member
Posted: Sun Apr 03, 2011 1:20 am Post subject: |
manikmike wrote: |
Hey Volks,
Cheers, Mike |
Sent you a PM. Mine is like this but I use the VW yoke and keep the other yoke off it in case I ever need to build a V8 etc again. There are many styles but I prefer something more robust than the tricycle kind.
Posted: Sun Apr 03, 2011 6:10 am Post subject: |
OK, so it is just a standard stand with a removable yoke - good to know - thanks! _________________ Mike
Boston, MA |
Posted: Sun Apr 03, 2011 9:07 am Post subject: |
manikmike wrote: |
OK, so it is just a standard stand with a removable yoke - good to know - thanks! |
This is the one that I have (1,000 lb capacity). And you are correct, you simply slide out the yoke that it comes with and slide the VW yoke in.
http://www.amazon.com/Powerbuilt-647513-Heavy-H-Frame-Engine/dp/B003UM0SY8 _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
whc03grady Samba Member
Joined: February 07, 2004 Posts: 337 Location: Livingston Montana
Posted: Mon May 30, 2011 9:40 pm Post subject: |
I've never used an engine stand, so excuse the dumb question.
Is the special yoke necessary, or just nice for VW engine work? Is there some reason the yoke that comes with these stands won't work? _________________ 1974 Westfalia "Ludwig"
1971 Squareback "Gertie"
Read about their adventures
blankmange wrote: |
The Bentley assumes that the car is complete. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 30, 2011 9:59 pm Post subject: |
The standard yoke is very difficult to fit to the VW's bellhousing flange and binds on the flywheel. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jun 11, 2011 11:03 am Post subject: |
Okay, my new stand and yoke are in the garage. I have to drill holes in the yoke still. Question: are you supposed to use the regular bolts/studs on the engine to mate it with the yoke, or fit something longer? _________________ 1974 Westfalia "Ludwig"
blankmange wrote: |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Sat Jun 11, 2011 11:21 am Post subject: |
FYI,
A nice feature of the engine stand shown by SGKent, is that you can put a lifting table under it to safely lift and lower a fully assembled engine by your self (the table can roll in and out in-between the stands legs with engine on it…:0)
http://www.germes-online.com/direct/dbimage/50137055/Engine_Stand.jpg _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
Posted: Sun Jun 12, 2011 9:02 pm Post subject: |
Yeah, that's the one I got.
What to make of this? When the yoke is fit flat against the case, the lower hole doesn't line up. Even with maximum compensation via the 'slop' in the upper bolt, it's not enough to get a bolt straight through.
I suppose I'll need to have the lower hole on the yoke embiggened, but at what point is that slice of metal inboard of the hole going to be too thin? _________________ 1974 Westfalia "Ludwig"
blankmange wrote: |
Posted: Mon Jun 13, 2011 6:36 am Post subject: |
Just get a rat tail file and go to work. Embiggened? |
Posted: Mon Jun 13, 2011 7:16 am Post subject: |
Wildthings wrote: |
Embiggened? |
It's a perfectly cromulent word.
I'll do that with the file, thanks. I have a tendency to overthink things. _________________ 1974 Westfalia "Ludwig"
blankmange wrote: |
Posted: Tue Aug 02, 2011 11:14 pm Post subject: |
whc03grady wrote: |
Question: are you supposed to use the regular bolts/studs on the engine to mate it with the yoke, or fit something longer? |
As asked above, What do folks use to mount their engines on these yokes? The standard bolts require some sort of sleeve in order to work. See the pic below:
1976 Westfalia
