Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
Posted: Fri Apr 15, 2011 12:08 pm Post subject: gravity bleed |
sometimes, you really can teach an old dog new tricks. So teach me
I've always had another person around to bleen brakes. Dad, brother, Girl Friend, friends, frienamies, etc. Well, now I need to re-do the brakes in my oval, and I've been putting it off for lack of help in my new city
So I see the vacume bleeders, and bleeder valves with check valves in them. And then I see everyone including hot rod guys, saying just gravity bleed them
Is it really as simple as doing all my brakes, adjusting them, cracking open a bleeder, and go hit the bars for a couple hours? I can do that!
Seriously, I need to change front wheel cylinders and shoes all the way around. maybe the rear wheel cylinders too. all the lines are new. What order do I need to do them in? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
VWESCH Samba Member
Joined: March 16, 2007 Posts: 18 Location: BELLEVILLE IL
Posted: Fri Apr 15, 2011 2:00 pm Post subject: |
Generally you start with the cyl farthest from the master. RR, LR, RF then LF. If all the lines are clear{not rusty or swollen shut} then gravity works pretty well. Sorry, but you will not have time to go to the bar. Fill the resevoir and leave the cap off. Attach a piece of clear vinyl hose to the bleeder and open it up. Usually only takes a few minutes for each wheel. Just watch the tube for air bubbles. When the bubbles stop close the screw. Good luck |
GB2S Samba Member
Posted: Fri Apr 15, 2011 8:41 pm Post subject: |
If you're doing the rear, jack up the front. and vise versa.
Geoff _________________ 1963 Ragtop |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Fri Apr 15, 2011 9:03 pm Post subject: |
VWESCH wrote: |
Generally you start with the cyl farthest from the master. |
It doesn't matter where you start. The MC doesn't know how far away the remote components are.
When you gravity bleed, open them all at once. Grab your beer and watch the game. Check the reservoir often, you don't want it to go dry. _________________
Erik G Samba Member
