The Surviving 1967 VW Bug Registry
Page: Previous  1, 2, 3 ... 65, 66, 67 ... 79, 80, 81  Next
Mbillions_slammed67
Mbillions_slammed67 is offline
PostPosted: Fri Apr 07, 2017 11:14 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
61SNRF
61SNRF is offline
PostPosted: Thu Apr 13, 2017 11:31 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
swharris wrote:
bill may wrote:
swharris wrote:
Dean1 wrote:
Your '67 should have a "H0" case. However, your air cleaner is correct.
Thanks!
the plastic nipple added to top of air cleaner is california add on. bill may
Was that done at the dealer or factory for CA delivery? Would that be original for a original '67 CA dual snout air cleaner? Looks like they used the og air cleaner on the later '68 swap H motor I have. l
No, not factory installed.
These were installed on older cars in the late 70's early 80's when the State of California required a retrofit NOX reduction device (essentially an EGR system) in order to get your vehicle registration or transfer the title upon sale.
By the late 80s new Ca smog laws came into effect and pre-75 cars were given an exemption from bi-annual inspections. Most people ripped the device off and trashed them, but the hole that was drilled into the top of the air cleaner is near irreversible.
-Bruce
An ounce of prevention is worth a pound of cure.
compdrag
compdrag is offline
PostPosted: Tue Apr 18, 2017 10:45 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
As you can see I deleted photos. I had to the file size was just getting to big. Sorry I lost the main file for awhile and just got it back today.
Thanks to the newest members:
VeeDub13
Piperj
Mbillions slammed67
VWlad
MasterMaker
Updated:
Andrewlandon67
Deleted
VOLKSWAGNUT
Thanks for keeping the registry alive! Very Happy
61 Type 1 Patina
61 Type 1 Convertible
68 Type 2 Rivi
Mbillions_slammed67
PostPosted: Thu Apr 27, 2017 7:38 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Who out there is working on their 67 this week?
I replaced, axel boots, axel seals, trans fluid, oil change, new fuel lines, new fuel filter, adjusted steeeing box, carbs cleaned. She is running better than ever. Super pumped after testing today. Thought I'd share.
I don't pay others to pay with my car. I do all my own work, just FYI.
pondoras box
pondoras box is offline
PostPosted: Fri Apr 28, 2017 6:39 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
I am putting in a new pan head on my 67 does that count?
I have the old cut out the new one positioned in and measurements checked, double checked, checked again, then rechecked and its tacked in.
I will check everything again to make sure nothing moved and weld it in this weekend.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk
majorjim
majorjim is offline
PostPosted: Wed May 03, 2017 5:31 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
I'm new to The Samba and I want to add my '67 VW Beetle to the registry, but I'm not even sure I'm posting this message correctly...
majorjim
majorjim is offline
PostPosted: Wed May 03, 2017 5:33 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Ok, looks like I figured out how to post a message/reply. Now,can someone tell me how to add my '67 beetle to the registry?
PostPosted: Wed May 03, 2017 10:17 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
In the very first post of this thread, you send a PM to that user there to have him add it.
2chico6
2chico6 is offline
PostPosted: Fri May 12, 2017 5:08 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Hi can someone pls help - I have a 67' - however my engine code shows SFF - I also only have brake light switch - does that make any difference w.r.t. model and engine capacity?
beetleporsche1967
beetleporsche1967 is offline
PostPosted: Fri May 19, 2017 7:23 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
My twins. Both started life as 67's
311tls
311tls is offline
PostPosted: Thu Jul 13, 2017 2:10 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Our 67. It's a Cali car, one family, two driver car (grandad and grandson). Original paint except front passenger fender. Never welded, not a bit of rust anywhere, looks like it's been garaged since new, just scratches and dings from 50 years of use. Now living in the UK.
Edit- I'm struggling with the photobucket link!
favguy
favguy is offline
PostPosted: Thu Jul 13, 2017 3:58 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
I think photobucket are about to hold you to ransom Sad
67ctbug
67ctbug is offline
PostPosted: Thu Jul 13, 2017 5:59 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Yeah, no photo. Start using the gallery here. Unless you pay $300, you can't use photobucket.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
311tls
311tls is offline
PostPosted: Fri Jul 14, 2017 2:34 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Cheers guys, yes it looks like I'll need to find another photo host!
pjalau
pjalau is offline
PostPosted: Sat Jul 15, 2017 6:40 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
My turn:
Chassis: 117841023
Model: LHD 1500
Colour: L620 Savannenbeige
Pictures will be posted here:
https://www.flickr.com/photos/pjalau/albums/72157686066845955
Currently not running, but will be soon I hope:
The Squirrel - a 1967 VW Bug by Peter Alau, on Flickr
Story thread is here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=682592
swharris
swharris is offline
PostPosted: Sun Jul 16, 2017 11:47 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
pjalau wrote:
My turn:
Chassis: 117841023
Model: LHD 1500
Nice! Shasta? What, no old joints found in there? I would have expected at least a few old roaches. Haha. What did you have to give for such a find?
pjalau
pjalau is offline
PostPosted: Tue Jul 18, 2017 11:03 pm    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Shingletown actually. And super conservative family, so no old roaches, just one big-ass black window spider.
This one cost me... $25.00. That is not a typo. They basically gave it to me.
67ctbug
67ctbug is offline
PostPosted: Wed Jul 19, 2017 1:28 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
I wish I had the luck of other people. I could never find a bug that cheap. I found a '75 super that was junky and he wanted $2500...
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
Sqrbckguy38
Sqrbckguy38 is offline
PostPosted: Fri Jul 28, 2017 8:05 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Greetings fellow Vw fiends, I've tried sending a message to the guys in the op, but no response for a while. I posted in another sticky up here about the 67 I picked up. Just wanted to know what else I need to do to add this little guy. I've added some of the pictures to this reply. Wasn't $25 dollars, but still a steal. I'm now the second owner.
Was about to get sent to a crusher, so of course I had to save it.
It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal
pjalau
pjalau is offline
PostPosted: Fri Jul 28, 2017 11:07 am    Post subject: Re: The Surviving 1967 VW Bug Registry Reply with quote
Good save!
Page 66 of 81
