sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Sun Apr 24, 2011 9:22 am Post subject: Hand Crank Tin? |
Is there a special tin for a hand crank starter with a pivoting cover for the required hole?
Picture courtesy of an ad in Thing parts.
_________________ 63 singlecab
73 thingster
74 Thing |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sun Apr 24, 2011 10:46 am Post subject: |
Yes there is it has a flap on a hinge built in _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Semper_Dad Samba Member
sam_w Samba Member
Posted: Sun Apr 24, 2011 12:26 pm Post subject: |
I see the hinge is on the flat/horizontal part of the rear engine tin. Is this OEM correct, or just a individual fix.
there is no reference to the starter handle in the parts manual PDF. _________________ 63 singlecab
73 thingster
74 Thing |
SilverThing Samba Member
Posted: Sun Apr 24, 2011 1:34 pm Post subject: |
sam_w wrote: |
there is no reference to the starter handle in the parts manual PDF. |
There is, but it is not pictured. The handle is listed under the jack, tools section 82 as part number 181 012 312 'Starting Handle M63.' The nut is in section 4 crankshaft, connecting rods, bearings as image 15 part number 122 105 261 'Starting dog.' The rear engine tin is part number 181 119 523H, but I am unsure whether that is the one with the starter hole and flap or not. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Posted: Sun Apr 24, 2011 1:45 pm Post subject: |
SilverThing wrote: |
sam_w wrote: |
There is, but it is not pictured. The handle is listed under the jack, tools section 82 as part number 181 012 312 'Starting Handle M63.' The nut is in section 4 crankshaft, connecting rods, bearings as image 15 part number 122 105 261 'Starting dog.' The rear engine tin is part number 181 119 523H, but I am unsure whether that is the one with the starter hole and flap or not. |
Just guessing here but I think the 181 specific rear tin is one without fresh air holes. I'm also guessing that any rear tins for crank equipped vehicles were just "modified" at the factory and not givien a specific part number. Looks like a pretty easy modification. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Sun Apr 24, 2011 1:50 pm Post subject: |
Semper_Dad wrote: |
sam_w wrote: |
You will have to ask this guy. It's his picture
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=4867
Starter handle is part of the M63 package |
it's original. although it's probably from a splitscreen army bus cos of the heater tube holes. my 72 thing didn't actually have a crank. |
BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Sun Apr 24, 2011 4:49 pm Post subject: |
I just bought a new crank hole cover from the Czech Republic. I think all I'll have to do is weld it onto the tin, and cut a hole for the crank
As you can see in the photo, I picked up the "keyhole" plate for the rear sheetmetal too.
[img][/img]
BNMike |
Posted: Sun Apr 24, 2011 4:56 pm Post subject: |
BNMike wrote: |
[img][/img]
BNMike |
Thanks Mike. I think that picture clears up a quite a bit.
I believe the 181 crank had an additional pin on the end.
BTW,....what's the other parts?
Looks like some sort of a quick release bracket next to the green can rack. No idea what the other parts are. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
BNMike Samba Member
Posted: Sun Apr 24, 2011 7:37 pm Post subject: |
Hi Semper_Dad......
The four round parts are headlight mounting "sockets" and their re-inforcing plates. The more-or-less square part with the round hole is the re-inforcing plate for the Notek light mounting. The quick-release bracket is for the MG34/42 "Gurttrommel" (aka, ammunition belt drum) carrier.
These parts are for my "quasi Kubel", Hermann
BNMike |
Posted: Mon Apr 25, 2011 7:44 am Post subject: |
the army ones just had a hinged flap. not like any of the ones in the pictures _________________ Michael Basso
CALL 518 630 0173 |
Posted: Mon Apr 25, 2011 8:20 am Post subject: |
[email protected] wrote: |
the army ones just had a hinged flap. not like any of the ones in the pictures |
Hinged flap on the tin?, or the body?
BNMike wrote: |
Hi Semper_Dad......
BNMike |
You definitely live in a rougher neighborhood than I do. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Mon Apr 25, 2011 8:50 am Post subject: |
on the tin, what good would a hole in the body do?
the crank handle itself was mounted inside the engine compartment btw _________________ Michael Basso
CALL 518 630 0173 |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Mon Apr 25, 2011 10:31 am Post subject: |
No Hole needed in the body. The crank handle passes under it.
And for what it's worth, I believe the crank handle mounted to the inside of the decklid. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
BNMike Samba Member
Posted: Mon Apr 25, 2011 10:39 am Post subject: |
Semper_Dad[quote="BNMike wrote: |
Hi Semper_Dad......
BNMike |
You definitely live in a rougher neighborhood than I do. [/quote]
Not Really....just a Free State
BNMike |
BNMike Samba Member
Posted: Mon Apr 25, 2011 12:06 pm Post subject: |
uberautowerks wrote: |
And for what it's worth, I believe the crank handle mounted to the inside of the decklid. |
Uber.....
I guess if the crank passes below the Thing body, I'll have to fab up a bracket to hole the "keyhole" plate
BNMike |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Mon Apr 25, 2011 12:46 pm Post subject: |
Semper_Dad wrote: |
I believe the 181 crank had an additional pin on the end. |
How can we find that out for certain? In the classifieds right now I can find them with or without the pin. |
Posted: Mon Apr 25, 2011 12:57 pm Post subject: |
You're right (as usual), the crank does passes under the rear body apron then through the rear engine tin. BNMike, I guess you have "extra parts".
I have a picture of a crank handle stowed in the engine lid but don't know if it's correct.
BNMike Samba Member
Posted: Mon Apr 25, 2011 1:21 pm Post subject: |
Semper.....
Ya, I've got the "keyhole" plate, which serves as the "outer bearing" when cranking. It bolts to the rear panel on an "early" real Kubel.
If you have a stock rear bumper on a Thing, it's already got the keyhole cut in it I don't have the stock bumper, so I need to "create" an outside bearing location. A bracket to hold the plate will work just fine
Cutting the hole in the engine tin will be easy, account the "flap" will give me that location.
My crank is a replica bus crank bought from a Samba advertiser. The nut I have has no recess for the Thing "pin", so it should work just fine. If it doesn't...I'll "make it" work
BNMike |
