Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Mon Jan 23, 2017 5:40 pm Post subject: Re: Beam disassembly / reassembly |
Calling Max.
Any update on how your replacement bearings are holding up? I bought a dozen to and am curious; they look and feel pretty good to me even though they're 'chinese'.
-Brent _________________ 69 Fastback Build
Berg5 Build |
69sback Samba Member
Joined: March 06, 2010 Posts: 216 Location: Somewhere
Posted: Mon Jan 23, 2017 5:45 pm Post subject: Re: Beam disassembly / reassembly |
I put the ISP plastic races in last spring and now i have a wobble back in the steering. I'm guessing they wore out already. I'm going to take it apart in the next month or two and report back... |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Mon Aug 24, 2020 5:49 pm Post subject: Re: Beam disassembly / reassembly |
Brent the chinese bearings held up very well. But I now have another problem.
I had my fastback in a shop for rust repair and the tech had my bean stripped and powder-coated. But he didn't remove the needle bearings first and now they are full of grit (from the blasting) and cooked grease. Ew!
I have more 35x44x20 upper needle bearings from 2016 but I'm going to need to replace the lowers.
Does anyone know the size of those lowers?
Max |
Posted: Thu Aug 27, 2020 1:24 pm Post subject: Re: Beam disassembly / reassembly |
Turns out the lower rollers are the same as for type-1.
New problem. The bronze inner bushings we made in 2016 survived the oven just fine. The lowers did not. From the remains they appears to have been those ISP ones.
Since the outer lower bearings are type-1, are the lower bushings also the same as type-1?
Max |
Posted: Thu Aug 27, 2020 4:04 pm Post subject: Re: Beam disassembly / reassembly |
Don't know the answer yet but Randy Bowen is cutting me a set of bushings from the oil impregnated bronze we had left from making the uppers.
Max |
Posted: Tue Sep 01, 2020 12:44 pm Post subject: Re: Beam disassembly / reassembly |
Done
Randy Bowen comes through again
Cleaned up the trailing arms too
Max |
Posted: Wed Sep 02, 2020 11:53 am Post subject: Re: Beam disassembly / reassembly |
When I pulled the beam apart, this thing was covering one of the bearings. What is it? Should I have four?
Max |
Yabbadubbadoo Samba Member
Posted: Wed Sep 02, 2020 1:12 pm Post subject: Re: Beam disassembly / reassembly |
That's a foreign object. Upper bearings have a thrust bush (I think its made of phenolic resin) and an o'ring around the outside merely as a dust seal. Lowers use a grease seal. Someone might have thrown it in there to act as a thrust bush and take up some play. _________________ Sydney, Australia.
66 Type 3 Fastback |
andybla Samba Member
Posted: Mon Mar 15, 2021 4:15 am Post subject: |
vlad01 wrote: |
I seen these little beauties on fb the other week.
asked the guy if he was planing to make them for others. currently testing them for a year to see how they wear.
How was the wear on these? |
COtype3 Samba Member
Joined: October 13, 2015 Posts: 27 Location: Colorado Springs, CO
Posted: Wed Mar 24, 2021 8:45 am Post subject: Re: Beam disassembly / reassembly |
This has been a great thread, Max thanks, maybe I will see you around the Springs. |
