The Caraway Co. 54 Barndoor
JoelH
JoelH is offline
PostPosted: Thu Apr 28, 2011 10:00 pm    Post subject: The Caraway Co. 54 Barndoor Reply with quote
Picked this up from a nice gentleman about an hour away from me. Far as I know, It's been sitting since the late 70's maybe early 80's. Looks to be the original motor which still turns over nicely. Has the original crank handle and everything! Very solid bus. The driver's side rocker panel is rusted out on the inner and outer panel, and the passenger's side rocker has some rust also. That is pretty much it for the whole thing. It's amazing. There are a few dents that I think with a little work, could be brought back out. There are some bullet holes in it too. All Character Wink
RED RIVER VW CLUB---www.redrivervwclub.com
'60 DD SWR Panel
http://www.thesamba.com/vw/forum/viewtopic.php?p=2522353#2522353
'62 Gulf Blue Ragtop Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=420720&highlight=
'60 Black RHD Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?p=6478591#6478591
1965 Sea Sand L568 Notchback
http://www.thesamba.com/vw/forum/viewtopic.php?p=8307805#8307805
PostPosted: Thu Apr 28, 2011 10:06 pm    Post subject: Reply with quote
Very cool, nice score.
I like the flat top fuel pump in there too.
Rick
Rick is offline
PostPosted: Thu Apr 28, 2011 10:07 pm    Post subject: Reply with quote
Shocked That things looks straight! Almost too easy. Nice score! What do the logos say?
JoelH
JoelH is offline
PostPosted: Thu Apr 28, 2011 10:13 pm    Post subject: Reply with quote
it's something like.... Caraway Co
Business Gifts Cards Calendars Novelties
don't know exactly, but yeah, something along those lines. They're more prominent on the passenger side then the driver's side. I also think there is something across the back. I might do a little rubbing on it to see if I can get them to show up a little better. any recommendations on what to use? wet sand paper grit, anything?
'60 DD SWR Panel
Rich's 50
Rich's 50 is offline
PostPosted: Thu Apr 28, 2011 10:27 pm    Post subject: Reply with quote
Sweet find, good luck with it
Jer*Fab
Samba Welder Dude
Jer*Fab is offline
PostPosted: Thu Apr 28, 2011 10:36 pm    Post subject: Reply with quote
nice Dude! ive been waiting to post up pics of this sweet bus!! congrats!!
51 RHD Split
54 Barndoor Shop Single Cab
Also Narrowed Bug and Bus Beams!
Follow us on FaceBook and Click the "Like" Button or Instagram
JoelH
JoelH is offline
PostPosted: Thu Apr 28, 2011 10:39 pm    Post subject: Reply with quote
thanks Jer. once I get time, I'll get some more detailed pictures posted up. This thing is just amazing though.
'60 DD SWR Panel
Trevor P
Trevor P is offline
PostPosted: Thu Apr 28, 2011 10:44 pm    Post subject: Reply with quote
Nice score.
I like the custom door knob they added to the cargo door. Wink Same thing was done to my Kombi before I got it.
53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
kruno
kruno is offline
PostPosted: Thu Apr 28, 2011 11:32 pm    Post subject: Reply with quote
Shocked
this bus seems very usable with a small investment
'58 bug
'54 barndoor
'79 bay window
'05 renault modus Smile a little gallic gay car
toXic rust
JoelH
JoelH is offline
PostPosted: Fri Apr 29, 2011 4:43 am    Post subject: Reply with quote
it's super rust free. When I get a chance, I'll get some pictures from up underneath. There's a couple of spots, but nothing major to worry about.
'60 DD SWR Panel
SloMo
SloMo is offline
PostPosted: Fri Apr 29, 2011 5:09 am    Post subject: Reply with quote
very nice find!!
Braukuche
Braukuche is offline
PostPosted: Fri Apr 29, 2011 6:20 am    Post subject: Reply with quote
Business Gifts Cards Novelties
Don't use sand paper it will remove too much paint. Trying using oven cleaner, if that doesn't work, try lacquer thinner, if that doesn't work try something more aggressive like paint stripper. The idea is to start cautiously on an area that is less visible or will need to be cut out anyway and when you get the right mix of material and time then attack the rest of the bus.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
Ragtop
Ragtop is offline
PostPosted: Fri Apr 29, 2011 7:23 am    Post subject: Reply with quote
Very nice find Cool
BulletBus
BulletBus is offline
PostPosted: Fri Apr 29, 2011 7:50 am    Post subject: Reply with quote
Well, clearly that poor bus has spent too much of it's life in the frozen tundra. Might I suggest sending it South for some much deserved sunny, warm weather? My concern is mearly for the bus. Smile
53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen.
Jake Martinez
The VW Kid
Jake Martinez is offline
PostPosted: Fri Apr 29, 2011 8:01 am    Post subject: Reply with quote
good find
58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote:
buslife wrote:
10 inch narrowed beam
Congrats, that's going to look like shit.
uberwagen
uberwagen is offline
PostPosted: Fri Apr 29, 2011 8:38 am    Post subject: Reply with quote
Was the signwriting originally on top of the touquise paint, and has since been rubbed / weathered off?
Is there any dove blue under the tourquise? or was this a primer delivered bus?
If the original writing has weathered off the suface of the bus, your only hope of seeing it again will be to remove some of the remaining paint around the edges of where the letters were.
The theory is that the paint under where the letters where is thicker that the paint around it, having being protected by the letters for years before the letters actually dissapeared. you may only be left with primer around the letters when you are done, but it still looks cool when done.
I would suggest using a fine wet sandpaper as it gives you ultimate control of how much material you remove. if you spray on stove cleaner, or apply stripper it could remove more than you want, and may not discriminate between overspray and signwriting.
Here is an example of a bus where the writing had weathered off the original paint, and was recovered by sanding around the letters:
cdennisg
cdennisg is offline
PostPosted: Fri Apr 29, 2011 9:27 am    Post subject: Re: the Caraway Gifts 54 Barndoor Reply with quote
JoelH wrote:
Well done, Joel. That area was once my old stomping grounds as a delivery guy and deer hunter. Guess I missed it. Wink
Looking forward to more pics and details. Any history from the PO? Where did he get it? Any location on the logos?
P.S. Is your inbox full yet?
whit
whit is offline
PostPosted: Fri Apr 29, 2011 10:24 am    Post subject: Reply with quote
i know its not for sale but what do you reckon it would be worth in todays market?
djfordmanjack
djfordmanjack is offline
PostPosted: Fri Apr 29, 2011 10:25 am    Post subject: Reply with quote
That Panel is such a nice find ! OMG....incredible ! Good luck with the resto and enjoy this clean bus. I love the whitewalled Firestones pie-crusts btw. Most beautifull tire ever come out of the mold. Hope it can be saved for wall art. Wink
54 Oval project
62 Dickholmer, Seeblau L360
cdennisg
cdennisg is offline
PostPosted: Fri Apr 29, 2011 10:32 am    Post subject: Reply with quote
$65K. US dollars, not that Canadian stuff. Very Happy
Page 1 of 8
