vwtyp3variant Samba Member
Joined: June 26, 2010 Posts: 155 Location: Cluj-Napoca Romania
Posted: Wed Nov 09, 2016 2:48 am Post subject: Re: `70 squareback |
KTPhil wrote: |
Damn fine looking parts!
Where did you find rubber for the diagonal arm bushings? I could only find red urethane a few years ago. |
At my local aircooled parts shop in romania, but i think cip1 or ISP West also has them |
Posted: Wed Nov 09, 2016 2:53 am Post subject: Re: `70 squareback |
glutenfree wrote: |
Where did you get those socket cap (allen head) tin screws? I am digging the color/coating on your manifolds! |
At a local harware store, they are the same dimensions as the original only they are not hex head
The manifolds are the same color as the muffler and heat exchangers, its high temp paint from StoveBright color code 6196 |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Wed Nov 09, 2016 7:39 am Post subject: Re: `70 squareback |
glutenfree wrote: |
You can buy those allen head holts from Mcmaster Carr
Bag of 100 in black oxide in class 12.9 alloy.. $10.26
Bag of 100 in zinc plate in class 12.9 alloy.... $9.30
Also available in zinc flake coated, zinc aluminum coated and blue dyed zinc for slightly more $. Ray |
glutenfree Samba Member
Posted: Wed Nov 09, 2016 10:50 am Post subject: Re: `70 squareback |
M6x10 & M6x15 mm that is depending on where its needed, i used the parts catalog to figure it out |
Posted: Wed Nov 09, 2016 2:12 pm Post subject: Re: `70 squareback |
vwtyp3variant wrote: |
Thanks! I am not sure I will shell out for these this build as I am way over budget already but I will definitely be upgrading to these in the near future. Nothing like using a ball socket hex key versus a flat head driver. _________________ 1971 Fastback Build
VW/Type 3 Parts for sale
Instagram
my Shapeways store |
Posted: Wed Nov 09, 2016 2:59 pm Post subject: Re: `70 squareback |
glutenfree wrote: |
Thanks! I am not sure I will shell out for these this build as I am way over budget already but I will definitely be upgrading to these in the near future. Nothing like using a ball socket hex key versus a flat head driver. |
You can get enough for $10 to build about three engines.
Personally I use 10mm hex cap screws for all my sheet metal. I try not to use allen head for anything they are not absolutely required for.
They strip just as easily as the damn slotted screw types...and even worse if and when they rust and lose a little metal. Though...the ones I listed are a notch better than stock because they are class 12.9 instead of the stock class 8.8.....but its far nice to use a 12 pt socket on a 1/4" ratchet to do all of the sheet metal.
16mm/ 1.0 X 20mm long class 12.9 are a bag of 10 for $4.33 at McMaster Carr.
I simply cut them to length if I need them shorter....in a few seconds with a Dremel and cut-off wheel.
Class 10.9...which is really plenty for sheet metal....are available in 6mm/1.0 X 16 in Black oxide, Zinc, Zinc aluminum and blue-dyed zinc in bags of 50 for $8.21 at McMaster Carr. Ray |
Posted: Thu Nov 10, 2016 1:45 am Post subject: Re: `70 squareback |
8.8 is enough for the engine tins, most of the threads are in aluminium anyway so you won't be tightenig it very hard anyway
Suspension bolts are usually 10.9
Keep in mind that the hardness of a bolt is a double-edged knife, yes its harder but its less elastic so it can break in time from vibrations |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Nov 10, 2016 5:02 am Post subject: Re: `70 squareback |
In the US, you can buy these bolts individually at Ace Hardware. _________________ 71 Elm Green FI A/T Squareback |
Posted: Thu Nov 10, 2016 10:29 am Post subject: Re: `70 squareback |
complete rear suspension mounted , also done some body work and painted the wheel wels in L30A ,as the car will be painted in that color in the spring
Posted: Thu Nov 10, 2016 10:33 am Post subject: Re: `70 squareback |
rebuilt my drive shafts
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Thu Nov 10, 2016 10:54 am Post subject: Re: `70 squareback |
Do not show this photo of those (no doubt greasy) CVs on your wife's nice kitchen floor! |
Posted: Fri Nov 11, 2016 1:19 am Post subject: Re: `70 squareback |
KTPhil wrote: |
they are at my mom`s place
I just found this photo from 1994
me in front of a 68 square in our garage at that time
Posted: Thu Jul 06, 2017 2:17 pm Post subject: Re: `70 squareback |
a bit more progres on my square
front end sandblasted and powder coated
Posted: Thu Jul 06, 2017 2:18 pm Post subject: Re: `70 squareback |
a couple of restored brake parts
assembling the front beam
Posted: Thu Jul 06, 2017 2:19 pm Post subject: Re: `70 squareback |
Posted: Thu Jul 06, 2017 2:20 pm Post subject: Re: `70 squareback |
the car is now on its wheels again, next step is painting the body
