left_coast*9 Samba Member
Joined: March 02, 2009 Posts: 740 Location: Puyallup, WA
Posted: Tue May 03, 2011 3:36 pm Post subject: Used dual Dellorto 45DRLAs |
Guys, I'm considering picking up a set of used dual Dellorto 45 DRLAs for sale. They come with linkage, manifolds with air cleaners. Seller has no idea of the jetting, emulsion tubes, vents, etc. He says he got them from a friend who ran them on a trike; apparently he personally witnessed them running great with that setup; they have been 'gone through' in the last few years and are in what he calls 'cherry' condition. We all know how the story goes…blah blah blah, let's leave it at that.
I've searched in the classifieds and see several sets for sale in the $700-900 range. I know what NEW IDFs, HPMXs, IDAs cost, including those that are rebuilt, even out of the box, by reputable professionals like Air Cooled Engineering. My intention is to have Art at ACE rebuild these, so I only care that all parts are there and that they're rebuildable. I've done some searching in multiple threads, like the one below:
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...dual++dell
By the way, my intended use for these carbs is a brand new 2110 or larger engine, actually it will most likely be a 2276cc moderate street motor with Engle 120 or FK8-style cam, S. Tim's stage 1 or 2-style heads, A-1 exhaust, all going into a 57 ragtop bug (per my build thread below ) I don't want to go the IDA route.
Asking price is $500. My understanding is that it's important to ensure all the parts are there, b/c parts can get spendy quickly on Dells. Assuming all parts are there, that they are in good shape, and considering I will turn around and spend $400+ to have ACE rebuild these, is this a good deal? What would you be willing to pay? I know guys are all over the map when it comes to carb preferences. I also know that a lot of guys swear by these 45 Dells. One other basic question: how can I tell these are 45s and not 40s, etc? Is there a casting on the carb that would reveal this? Yah, I know, I'm REALLY new. Thanks all. _________________ Jet City 1957 VW Oval Rag Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=408791
1965 Sea Blue Beetle Sedan
http://www.thesamba.com/vw/forum/viewtopic.php?t=472827&postdays=0&postorder=asc&start=0 |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Tue May 03, 2011 3:48 pm Post subject: |
$500 for a set of Dell 45's is a steal! There small bosses on the sides of the barrels down by the mixture screws and vacuum port. It will say DRLA 45 on one and Dellorto on the other. Smart move to have ACE look at them. They will set you up with proper vents and jetting for your application - no need to speculate on that here. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Fri May 06, 2011 6:14 am Post subject: |
Well, picked them up last night. I would not call them cherry, but I suppose they're in good shape. All parts seem to be there. I have not had a chance to go in and look at the internals yet.
All the indentifying info is on the diaphram side of the carbs. The motor's left side carb has a small stamped metal tag on it that says "R6217". Then to the left of that stamped in the casing of the carb body says: "Dellorto Made in Italy". To the right of the tag also stamped in the casing: "DRLA 45S". The other carb's little metal tag says "R6218". It has the same "Dellorto Made in Italy" stamp. On the right of the tag is stamped: "DRLA 45D".
The air cleaners seem to be in real nice shape, as do the filters. How'd I do? Here's some pics:
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Fri May 06, 2011 8:20 am Post subject: |
They look dandy to me....just what I'd expect from a nice well used set of 45's. Good luck and happy driving.
BTW....is that 'left Coast" as you face North or South? _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Fri May 06, 2011 8:44 am Post subject: |
Sending them to ACE right off the bat is a good idea. My carbs I bought used for $300 (carbs only, no manifolds, air cleaners, etc) and looked really nice and clean. Irregardless, I went through them and installed a rebuild kit as per the seller's recommendations.
Once on the engine, they turned out to have a wicked leak. As soon as the engine was turned off, gas would pour out onto the butterflies through the progression ports in the throats. Probably could have saved myself a fair amount of time and frustration if I'd just sent them out to be professionally redone to begin with, but I was hoping to save some coin, as money is certainly not described as "no object" in my shop. Lol. |
Posted: Fri May 06, 2011 9:24 am Post subject: |
left_coast*9 wrote: |
Thanks Bugnut, good to know. Even tho a Dell 45 rebuild kit is only like 40 bucks or something (per carb) vai CB Perf., I am more inclined to spend $400 and have them rebuilt, set up, bench tested and working perfectly on my 100% brand new engine. Once I get the engine, that is. LOL |
I bought my rebuild kits from the guy in Italy who has tons of Dellorto stuff on Ebay. They were $40 for the pair, plus shipping, as I recall.
I wish I'd gone to Art sooner as I'd likely have the engine running and in the car by now... ah well, live and learn. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri May 06, 2011 9:36 am Post subject: |
Gabriel aka alfa1750 has top notch rebuild kits. Ships fast even considering hes in Italy. I have never been disatisfied with his products or service and I will be a lifetime customer for my vw life.
Leftcoast consider yourself somewhat fortunate. The condition of your carbs arent that bad. Average outer condition actually and mostly aesthetic mostly. Ive certainly rebuilt and cleaned much much worse! I like to send before and after pics to requesting customers. Sometimes leaves em speechless. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Fri May 06, 2011 9:51 am Post subject: |
jfats808 wrote: |
Leftcoast consider yourself somewhat fortunate. The condition of your carbs arent that bad. Average outer condition actually and mostly aesthetic mostly. Ive certainly rebuilt and cleaned much much worse! I like to send before and after pics to requesting customers. Sometimes leaves em speechless. |
Yeah, exactly. Mine looked beautiful visually and turned out to be complete shitpiles inside, apparently. Lol. |
Bigg Tim Samba Member
Joined: February 26, 2008 Posts: 47 Location: Phoenix, AZ
Posted: Mon Jan 09, 2012 4:51 pm Post subject: |
I noticed that these carbs don't have the DRLA Vacuum take off union on them. Do you need to have this for the carbs to function, or is it just for what the name implies....vacuum take off for something else?
I have a pair of these and 1 carb has the fitting broken off inside, so if can just tap and plug that port, that would be great. |
catbox Samba Member
Joined: May 16, 2007 Posts: 865 Location: Portland, Oregon
Posted: Mon Jan 09, 2012 5:08 pm Post subject: |
Do you have a picture of this doo-hickey?
I have a set of these on the shelf and am getting ready to go through them in the next few weeks as I wait for other parts to be machined.
Pictures speak to me much better than words sometimes... _________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
kevinhosp Samba Member
Posted: Mon Jan 09, 2012 9:32 pm Post subject: |
Buy a dellorto book and do them youself. It will give you a better understanding on how they work and you will have a better understanding on how to set them up |
Nubby Samba Member
Joined: August 28, 2010 Posts: 605 Location: Down by the river
Posted: Mon Jan 09, 2012 11:13 pm Post subject: |
I found a set of 45's for 500 as well. Lucky I guess. Art told me that they can sell a pair rebuilt for 13-15 hundo all day. He is a really cool guy to talk to and his team is super knowledgeable. |
Posted: Tue Jan 10, 2012 6:22 am Post subject: |
Bottom right nipple on the picture.
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jan 10, 2012 7:32 am Post subject: |
You don't want to use those nipples for vacuum advance. You want to use the one he has the vacuum cap on....... _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Tue Jan 10, 2012 7:54 am Post subject: |
I don't want to use any vacuum source off the carb. Im asking if I need them at all on the carb since I have one broke off on the other carb. Can I just plug that port? |
MURZI Samba Member
Posted: Tue Jan 10, 2012 7:56 am Post subject: |
Yep, they all can be plugged. I'd use Allen set screws. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Tue Jan 10, 2012 9:00 am Post subject: |
Sweet, thanks for the info. |
