The Young Dude Samba Member
Joined: July 16, 2009 Posts: 120 Location: California
Posted: Thu May 05, 2011 5:43 pm Post subject: Failed smog, missing EGR? |
All right, I took Stella blue in today for a smog check and failed. hardcore. He said its missing an EGR system Emissions gas recycling? what the heck is that and why do i need it? what can i do to avoid putting one in to get it to pass ? |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Thu May 05, 2011 5:53 pm Post subject: |
You need it in California. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
El_Güero Samba Member
Posted: Thu May 05, 2011 5:56 pm Post subject: |
to answer your question: http://www.youtube.com/watch?v=iducH4Rv9lg
explained by robotic teachers _________________ "Sé que en algún lugar sus dedos pelean con un tornillo" (Remembering Carlos Amat)
"Si quiero estar encabronado
hazte a un lado...cabrón!" |
SGKent Samba Member
Posted: Thu May 05, 2011 8:18 pm Post subject: |
what year is it?
is it manual or automatic?
Is it Federal or California emissions originally (door pillar or shipped to from M-code)?
here is a thread recently on an EGR off a 1978. Not all are the same.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...mp;start=0 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu May 05, 2011 9:47 pm Post subject: |
It's a 1979, automatic transmission and a 2 liter engine with barely 6000 miles on it |
maximan1 Samba Member
Joined: January 07, 2008 Posts: 1354 Location: Anaheim, California
Posted: Thu May 05, 2011 11:51 pm Post subject: |
Facebook me dude, I had to go through all this shit when I smogged my bus. I would say call me, but I just drowned my phone in acetone. We need to figure out what this guy who rebuilt your engine did with the emissions parts, and if worst comes to worst, I'll let you use my emissions parts for your smog test. _________________ 1978 Transporter, 2.0L FI |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 536 Location: Talbott, TN
Posted: Tue May 10, 2011 4:18 pm Post subject: EGR Function and where to buy parts |
The EGR (exhaust gas recirculation) system lowers Nitrogen Oxide emmissions, so called NOX emmissions, by lowering the peak combustion temperature. From what I have read on this and other sites, you will need to have all the components installed to pass a visual inspection during the emissions test, but there is a practical reason to have it functional (that is - lower peak combustion temps = lower cylinder head temperatures = longer engine life)
I have managed to scrape together most of the parts I need to make a functioning EGR system on my 78 2.0ltr Bus, but I still can't find the linkage rod from the valve to the throttle. If anyone knows where I can get one of these, I would be most grateful.
To make a functioning system you will need the following:
EGR filter - available new @ busdepot.com for about $120
EGR Valve - Only available used, but they seem to be plentiful
EGR plumbing - this would be the pipe from the filter to the valve
EGR valve to throttle linkage - should be available used somewhere? |
SGKent Samba Member
Posted: Tue May 10, 2011 7:22 pm Post subject: Re: EGR Function and where to buy parts |
69BahamaYellow wrote: |
You need to test the egr valve to be sure it seals in both directions when closed and doesn't leak air theu the gasket into the plenum.
You will also need to make sure the egr injection tube in the plenum is clear.
If you need gaskets they are $45 a set from top to bottom and I maybe have one set left to sell, however you can reuse old gaskets with red silicone. Make sure the one next to the valve has a metered orifice still.
The new EGR filters are just as empty as the old used ones, at least mine was. You can soak in carb cleaner, wash out and blow out if they haven't rusted thru.
I have no idea of the condition. Also VW76Westy (Raul) may have one.
They do come up from time to time. I just sold my last spare one with a whole EGR setup. Here is one listed in classifieds. http://www.thesamba.com/vw/classifieds/detail.php?id=751272 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Tue May 10, 2011 8:54 pm Post subject: egr |
PM sent to you regarding EGR parts _________________ V.W.owner since 1967 |
Tvättbjörn Samba Member
Posted: Tue May 10, 2011 9:45 pm Post subject: Re: EGR Function and where to buy parts |
What size / diameter is the metered orifice gasket? Mine was plugged with a bolt and the gasket was missing.
thanks
SGKent wrote: |
They do come up from time to time. I just sold my last spare one with a whole EGR setup. Here is one listed in classifieds. http://www.thesamba.com/vw/classifieds/detail.php?id=751272 |
Posted: Tue May 10, 2011 9:58 pm Post subject: egr gasket |
The holes are 9.90mm or 25/64 in. for the EGR TUBE _________________ V.W.owner since 1967 |
Posted: Wed May 11, 2011 5:49 pm Post subject: Re: egr gasket |
Hmm, last night I found a part number on a micro fitch somebody posted on Samba and it says for that gasket 3.8mm right next to the part number. The part number is 039 131 599A
Any idea or comment on it?
old DKP driver wrote: |
The holes are 9.90mm or 25/64 in. for the EGR TUBE |
Posted: Wed May 11, 2011 6:40 pm Post subject: egr gasket |
Yes there are 2 metered sizes 3.8mm and 5.5mm
i measured the egr pipe opening to the valve
try www.autoatlanta.com
they show an 039 131 599A & 021 131 599A
perhaps 1 of them is 3.8mm _________________ V.W.owner since 1967 |
Posted: Fri May 13, 2011 7:34 pm Post subject: |
hey guys she passed smog the second time! thank goodness its over |
SGKent Samba Member
Posted: Fri May 13, 2011 7:50 pm Post subject: |
The Young Dude wrote: |
this year - make sure you find all the parts as they will get harder and harder with time to find.
Quote: |
Yes there are 2 metered sizes 3.8mm and 5.5mm |
one is Federal and one is California. I had the 3.8 mm ones made as part of the EGR gasket kit figuring some one could open the 3.8 mm one up to 5.5 mm. I sent part numbers and where to order them to Ron at Bus Depot and Scott at German Supply. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
shiningstar76 Samba Brewer
Posted: Fri May 13, 2011 9:05 pm Post subject: |
Good luck in California buddy. Fortunately for me I don't think they can even spell emissions in Georgia. _________________ KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it. |
Posted: Fri May 13, 2011 9:10 pm Post subject: |
Which size is the CA version?
SGKent wrote: |
one is Federal and one is California. I had the 3.8 mm ones made as part of the EGR gasket kit figuring some one could open the 3.8 mm one up to 5.5 mm. I sent part numbers and where to order them to Ron at Bus Depot and Scott at German Supply. |
SGKent Samba Member
Posted: Sat May 14, 2011 8:46 am Post subject: |
Tvättbjörn wrote: |
SGKent wrote: |
3.8 mm _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
kmmcdonald Samba Member
Joined: October 11, 2009 Posts: 218 Location: Arizona
Posted: Sat May 14, 2011 9:00 am Post subject: |
My EGR system is missing, also. We are the original owners of our 78 Westfalia, and I do not recall any service facility suggesting to me that it has been removed. So, I can't blame the previous owner.
Where are all of these missing EGR systems going? Why are they being removed?
Keith |
SGKent Samba Member
Posted: Sat May 14, 2011 9:54 am Post subject: |
kmmcdonald wrote: |
Keith |
Since you are the original owner you would be in a better position to know this.
The units inject exhaust gas (inert) which lowers combustion temperatures resulting in less NOX emission as well as an added benefit in an ACVW of lower head temps. The 1979 models I think did away with them and they returned in the Vanagon. Sometimes when the exhaust or EGR filter needed replacement the shop removed them as the owners did not want to pay for the additional parts. Some states had smog exemptions for years when parts costing more than a certain amount were needed to make it smog legal so the car would be waivered. Today that is becoming less and less as states are tightening down on violations, especially in states where air quality fails to meet legal standards. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
