Sodo Samba Member
Joined: July 06, 2007 Posts: 9616 Location: Western WA
Posted: Fri May 06, 2011 10:22 am Post subject: Vanagon front motorcycle carrier |
For folks who want to carry a small motorcycle on the front of a Vanagon, here is a rack that I have built. I've been using it for a couple years to carry a 160 lb "Trials" motorcycle. (~80 lbs per wheel). If I step on this rack, with all of my weight on one of the support (~160 lbs) it does not flex. 160 lbs on one support is 2X the load of the motorcycle that I normally carry.
Here is what the support structure looks like on each side. It's bolted to the flange of the Vanagon frame. If you remove the Vanagon bumper, it gets much easier to attach structure to the Vanagon frame. This doubled steel structure is incredibly strong. You can see farther down the line mine is bent. Anyone whose tried to straighten this flange will know how strong this flange is. Don't drill your holes thru the spotwelds.
The rectangular tube is 2" X 1" X .065" thick steel. The part bolted to the VW crimp edge is 3/8" thick, and the strap going rearward is a 1" x 1/4" steel. But in any case it's been tested for over 2 years carrying a 160 lb motorcycle. It's lightweight but evidently strong enough. It would be easy to make it stronger. For example using a doubled-1" square for the 2x1 rectangle, or use a thicker wall would be about 2X stronger.
The 'platform' is built of 1 x 1 x .065 square tubing.
The front motorcycle carrier needs an upright. I started with it on the Driver's side as in this photo but moved it to the passenger side (as the arrow suggests). The clamp joint in the picture is sufficient but I will rebuild it with a stronger, wider clamp soon.
The motorcycle is tied to the rack, and to the upright using TWO ratcheting cargo straps in an X pattern, wrapped around the upright.
The little bike in this photo is only 55 lbs. and does not need another strap at the top. Look again at the TOP photo of this post. There is a single BLUE strap to the Westfalia top that pulls the bike "back" lightly. It does not pull very hard on the camper fiberglas top, only steadies the motorcycle to prevent oscillation.
_________________ _________________
....KTMs, GasGas, SPOT mtb |
peasant Samba Member
Posted: Fri May 06, 2011 11:11 am Post subject: |
very nice looking, thanks for the write-up. first I have to find a small/light enduro _________________ 89 wolfsberg weekender carat
89 Westfalia |
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Fri May 06, 2011 11:30 am Post subject: |
Thanks a bunch. Do you find any cooling issues hanging a bike up in front of your radiator?
I think a set up like this will fit the bill perfectly for my CT70. |
Californio Samba Member
Sodo Samba Member
Posted: Fri May 06, 2011 1:25 pm Post subject: |
Havent noticed any cooling issues, even towing the trailer. But I'm in WA not AZ. FYI the CT-70 weighs 144 lbs. _________________
Zanza Samba Member
Joined: May 28, 2008 Posts: 63 Location: Switzerland - Europa
Posted: Wed Aug 22, 2012 3:24 am Post subject: |
Great idea (but I'm afraid that in Europa it'll not be allowed to do this).
It makes a long time that I have the idea to put a same stuff on my Westfalia California _________________ '92 Westfalia California full camper - 2.5l gasoline - 5 speed - 223'600 km
Moderator on Buspirit, the french speaking Eurovan forum
Visit my website, dedicated to the Westfalia California |
kevtherev Samba Member
Joined: December 23, 2007 Posts: 897 Location: the 51st state
Posted: Wed Aug 22, 2012 5:33 am Post subject: |
Yeah summat to do with maiming and killing pedestrians.. |
danfromsyr Samba Member
Posted: Wed Aug 22, 2012 5:39 am Post subject: |
you Europeans probably shouldn't be hitting them in the 1st place. ;-p
maybe the pedestrians should wear safety gear and colors.. _________________
Abscate wrote: |
Posted: Wed Aug 22, 2012 1:26 pm Post subject: |
danfromsyr wrote: |
maybe the pedestrians should wear safety gear and colors.. |
Unfortunately we live on an overcrowded island, which is infested with health and safety zealots who look after the retards... thereby spoiling the fun of the greater population who have some common sense and road sense. |
CaptTurbo Samba Member
Joined: February 24, 2012 Posts: 93 Location: SW Florida
Posted: Wed Aug 22, 2012 1:45 pm Post subject: |
Sodo, that sure is a sweet BMW you have on the trailer. I have a '93 R100GSPD and a 2001 R1150GS in mt shed. sweet bikes but yours is over the top! I haven't even set my Syncro up to tow from the rear yet. I guess I should look into some mods! |
Sodo Samba Member
Posted: Wed Aug 22, 2012 2:10 pm Post subject: |
CaptTurbo wrote: |
Sodo, that sure is a sweet BMW you have on the trailer. I have a '93 R100GSPD and a 2001 R1150GS |
Yes Cap'n the HP2 is like those 2 bikes as one! I don't often carry 3 bikes, this one case was headed out for 10 days riding out of one Westy camp. _________________
zeekiel Samba Member
Joined: September 27, 2011 Posts: 153 Location: South Lake Tahoe, Colorado
Posted: Wed Aug 22, 2012 3:41 pm Post subject: |
you have all the goodies have fun. _________________ 85' Westy GL /w 2.1L Swap |
