gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Mon May 09, 2011 9:00 am Post subject: My new bus motor |
Hey guys I am planning the rebuild of my 77 westy motor and am looking for some feedback. The idea is to have a Raby CS cam with less expensive heads. I wish I could afford The Raby CS heads, but I'm afraid not...
So starting with a stock 1977 2.0 EFI:
- stock intake/EFI
- CB Performance 044 MAGNUM PLUS heads with 42 x 37.5mm valves
- RAT 9550 cam super kit with the HD springs and rocker shaft etc. -- I would take the dual springs off the CB head and replace with the Raby HD spring...
- Solid Cro-mo push rods (no more hydraulic -- Jake's kit does away with this)
- Mahle piston cylinder stock replacement
- get the crank reground by Rimco, or pick up one of their stock VW
- Any case work would be done by Rimco
- Exhaust -- not sure yet. I want quiet
- everything else I am hoping to reuse/keep stock
Any thoughts or suggestions? Does this sound reasonable? I don't want to cut corners, but I am on a bit of a budget. The main question is whether the head/cam combo will be ok. _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
MJulien Samba Member
Joined: September 04, 2005 Posts: 498 Location: West Michigan
Posted: Mon May 09, 2011 9:34 am Post subject: |
Moly push rods may make the valve train noisier. |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Mon May 09, 2011 9:38 am Post subject: Re: My new bus motor |
gatorjos wrote: |
CB Performance 044 MAGNUM PLUS heads with 42 x 37.5mm valves |
Type I heads on a Type IV engine? _________________ 1966 Karmann-Ghia convertible |
Posted: Mon May 09, 2011 9:42 am Post subject: Re: My new bus motor |
sactojesse wrote: |
gatorjos wrote: |
Type I heads on a Type IV engine? |
Was gonna call CB on that this morning -- never worked on a Type IV before. I assume from your scrunched face emoticon, that's a no-go?
Is there an affordable big valve head out there for the Type IV? I don't think it's worth getting the RAT cam unless the valves are bigger right? _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon May 09, 2011 9:59 am Post subject: Re: My new bus motor |
gatorjos wrote: |
Is there an affordable big valve head out there for the Type IV? |
Not unless you can find a usable 2.0 head, good luck with that. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon May 09, 2011 12:19 pm Post subject: |
Quote: |
The idea is to have a Raby CS cam with less expensive heads. I wish I could afford The Raby CS heads, but I'm afraid not... |
The only way to achieve results that are indicative of the CS, is to spend the required money to purchase genuine CS components.
Its all in the combo, that combo has taken 14 years to develop and nothing about it will ever be cheap. Lots of people have tried to copy the CS, most have ended up with results that are less than favorable, with some of them making LESS power over a narrower power band than a bone stock 2.0 engine.
The only way to come close is to buy CS heads, run my 9550 cam package and set the CR at 8:1, but even then its not a thoroughbred CS. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Mon May 09, 2011 1:27 pm Post subject: |
Understood. I may have to scale back and just do a stock rebuild. I still need to pull the motor to see what I actually have to work with. Pretty sure the heads are toast though... _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
craigman Samba Member
Posted: Mon May 09, 2011 2:04 pm Post subject: |
(Is there an affordable big valve head out there for the Type IV?)
No.
You will find out their is nothing affordable when it comes to the type 4 engine.
Believe me, i have tried. It's too bad, because i think a lot more people would try the type 4 platform. And their is no reason why type 4 parts should be more expensive compared to a type 1. |
Posted: Mon May 09, 2011 3:09 pm Post subject: |
Your options are limited because you live in an area with a biennial smog check requirement and your bus is not smog exempt (1975 and earlier). Thus, you have to go with something that will work w/ your stock fuel injection and catalytic converter. _________________ 1966 Karmann-Ghia convertible |
Posted: Mon May 09, 2011 3:41 pm Post subject: |
sactojesse wrote: |
Your options are limited because you live in an area with a biennial smog check requirement and your bus is not smog exempt (1975 and earlier). Thus, you have to go with something that will work w/ your stock fuel injection and catalytic converter. |
Actually I'm going to be registering this beauty in Florida, so I can pollute to free will. The muffler is only half attached, so I was thinking about pulling the whole catalytic contraption and putting an aftermarket deal on regardless whether I go stock or Raby. That might get me a little performance yeah? _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
Posted: Mon May 09, 2011 5:10 pm Post subject: |
If you have to conform to smog requirements, the CS is out for you.. Its not legal, even if the engine passes the sniff tests and visual inspection.
BTW- Everyone has a different definition of "affordable". Look beyond the initial cost of admission and you'll be ale to see the value per mile. People that only look at initial costs are generally the same people that go buy a car or a house and say "How much will it cost me per month"? They look right past how much it'll end up costing them over the years they have to pay for it. _________________ Jake Raby
