j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri May 13, 2011 1:28 pm Post subject: Burley 16" rear control arms - arrived! |
I thought you guys might like seeing what else Burley is building for me.
He sent these progress shots this week.
His 16" control arms. Flanges shaved off, and reinforced.
Those were pretty rough looking OEM 14s when they left my house via UPS.
Shock brackets will be upgraded to his syncro brackets.. but cut down to remove lower portion that would otherwise hang low.
Should gain about 1" clearance at the front corner, only a couple mm before.
Going for powder coat next week.
Will provide a write up on my install on a 2WD Westy, running 29" tires.
Stay tuned. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Jedi Samba Member
Joined: October 23, 2007 Posts: 734 Location: Cool California
Posted: Fri May 13, 2011 1:54 pm Post subject: |
_________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11998 Location: Santa Cruz, CA
Posted: Fri May 13, 2011 3:08 pm Post subject: |
That gusset plate on the side is new. I like it better that just the back welded then smoothed out design for strength.
Now it looks extra pimpy too |
timbo Samba Member
Joined: April 20, 2006 Posts: 194 Location: Port Moody BC Canada
Posted: Fri May 13, 2011 3:10 pm Post subject: |
Niiiiiiiiiiice ! Burley is the man!
Ive got a month or so on a set of his lifted UCA's and luvin the van more very day!
Thos arms look suuweet! _________________ 1988 Vanagon GL/ 1991 2.2 Subie power
"Never tell a lie and you'll never have to play dumb" Anthony Kiedis |
insyncro Banned
Posted: Fri May 13, 2011 4:02 pm Post subject: |
Them's Burley. |
Williamtaylor33 Samba Member
Joined: September 07, 2007 Posts: 1545 Location: Arkansas
Posted: Fri May 13, 2011 4:27 pm Post subject: |
Your gonna have one awesome 2wd when your done. _________________ 89 Bostig powered syncro westy |
andy syncro-nutz Samba Member
Joined: August 22, 2010 Posts: 539 Location: Upper Ottawa Valley
Posted: Fri May 13, 2011 4:32 pm Post subject: |
Nice job! |
1621 Samba Member
Posted: Fri May 13, 2011 5:47 pm Post subject: |
Those do look very nice. I'm really digging Burley's work!
J Dirge - What's the plan for your van? What's the benefit to having 16's on a 2wd? Will you need to trim the sheetmetal? With the Syncro.org springs being slightly lower than the stock Syncro springs, will the lower perch be aligned with the upper perch?
Sorry for all the questions - but the project looks extra cool and I'm looking for some details. Thanks! _________________ '85 Westy |
Posted: Fri May 13, 2011 6:55 pm Post subject: |
No worries on questions.. Post more.
Happy to help.
Sooo...
I had gone to 16" wheels in order to fit G60 brakes over 288 disks up front..
15s would have worked. Ha-HAH!
But now I have room for 312s.. (Thats for another time.)
Then I chose 225/75r16 tires, in part, to help bring SVX rpms into range for HYW cruising. The tire (BFG Radial Long Trail load range D) turned out be a very pleasant surprise. They handle great. They are quiet and have very nice road manners. And they do OK on dry off-road.
Then I discovered that my van no longer fit in thru my garage door... but thats another story.
The real problem now was that with 29s there was zero room for snow chains.. and airing down would have been risky.. That was not going to be acceptable.
I considered shaving the flanges on my own.. but that only buys 3/8-1/2".
Still not enough room for cables.
Anyway.. As I edge closer on the SVX, the added benefit of 29" tires was +2" of honest-to-god clearance.. and that means I can run the SVX cast iron headers.. which should please the BAR ref for CA smog.
So one day I am trading emails with Burley about the tire carrier and this came up.. and a few minutes later IMPULSE BUY..
I figure that, I may as well go the whole 9 yards.
16, no flange, reinforced, and strengthened shock bracket.. In the end it is not that much more money for the added cool stuff.. and it gives me a hell of a lot of flexibility as this project evolves.
I had decided long ago to over-build due to some of my van's use.. Heavy towing, big loads.. and some dirt. It will likely get 930s at some point and a TBD when the trasnmission is rebuilt.
The spring perches should be fine.. Burley knows this is 2WD. And those remain in place, just a new welded bead around the edges to beef it up.. I *may* have a slightly different spring action now, though, because the wheel sits 1/2-5/8" aft of OEM. A longer lever.
That spring issue remains to be seen. I am not married to these syncro.org springs. They work fine. It sits at 18" now. If they need to be swapped for something that can handle all the added weight (the SVX, the tire carrier, and up to 300lbs of tongue weight), then I'll cross that bridge when I get there.
As it stands the combo of these springs and the Monroe Sensatracs seems to be a reasonable blend. A little harsh when empty.
As far as the 16s vs 14s. Most of the arm remains the same as OEM.. and aligned as if it were a 14er. The arm is the same shape, overall same geometry.. Burley gets the added space by removing 3/8" of that flange forward.. and the remainder comes from moving the bearing housing flange off back..
If you look closely you can see the flange is no longer centered on the geometric shape of the bearing housing. So that may impact CV angle.. but I have no idea if that will cause a problem. I am hoping it remains in range.. but if not.. I'll move the engine and trans aft when the SVX is built.
I should add.. I would not ask just *any* shop do this 16" arm.. NO WAY!
You can imagine the mess if it were not constructed properly... using proper jigs, etc.
Pretty cool.
Fun project... gotta say, that a vast majority of decisions were made based on what I learned here on this site.
And Burley? What can I say.. its like the guy reads my mind.
Scary cool stuff he builds, too. Its low on flash and high on function.
But now my boat is being neglected.. just not enough days in the week. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Fri May 13, 2011 8:45 pm Post subject: |
inspiring _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
madspaniard Samba Member
Posted: Fri May 13, 2011 9:43 pm Post subject: |
lots of fun,
as it always happens with these vans and us crazy upgraders, we start by upgrading just one thing, which leads into another, and another, and "while I'm doing this why I don't also do this..." I always say the fun is in the chase, not in the prize.
Great work by Burley. Jim, thanks to your posts I'm now thinking about Burley bumpers, Burley spare tire carriers, Burley UCAs, _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
vannin Samba Member
Joined: January 07, 2011 Posts: 89 Location: N.S.W. Australia
Posted: Sat May 14, 2011 3:32 am Post subject: |
Nice cant wait to see the whole project
Nik |
r39o Samba Polizei
Posted: Sat May 14, 2011 11:41 am Post subject: |
j_dirge wrote: |
That spring issue remains to be seen. I am not married to these syncro.org springs. They work fine. It sits at 18" now. If they need to be swapped for something that can handle all the added weight (the SVX, the tire carrier, and up to 300lbs of tongue weight), then I'll cross that bridge when I get there. As it stands the combo of these springs and the Monroe Sensatracs seems to be a reasonable blend. A little harsh when empty. |
That is my spring and shock combination in the rear for my 85 Westy. About 18.25 inches including a small plate to combat Westy lean. It does push the van up. The Sensatracs added around a good inch of lift for me, as I recall.
The harsh, for me, comes over speed bumps. DAMN! What a LOUD thud I get over speed bumps. Scary. But, that is the only fault I find.
j_dirge wrote: |
If you look closely you can see the flange is no longer centered on the geometric shape of the bearing housing. So that may impact CV angle.. but I have no idea if that will cause a problem. I am hoping it remains in range.. but if not.. I'll move the engine and trans aft when the SVX is built. |
This angle issue may be offset by the geometry as the axles are not perpendicular to the transmission in a 2WD 14 inch setup. Burley will know ALL about this, I just noted it the other day while my 90 was on the hoist. My Master VW mechanic buddy (with decades of Vanagon experience) said they are all like that. Always been offset. I am guess that is how they could lengthen the arms and still be OK. But, I am not 100% on all that stuff.
This longer trailing arm / more room for chains topic is yet to be addressed by me. I want to see how things work out with my current setup after the new Suby EJ22 is dialed in.
Keep having fun! _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
snoop Samba Member
Posted: Sun May 15, 2011 9:59 am Post subject: |
r39o wrote: |
This angle issue may be offset by the geometry as the axles are not perpendicular to the transmission in a 2WD 14 inch setup. |
Not sure that this will be useful, but just in case it is...near bottom of page is "Three Dimensional Angle Calculator". Would be nice to know what the stock 3-D angle value is...any volunteers?...in order to quantify the magnitude of deviation our mods impose. Wonder what problem would present and at what angle would it...? Also wonder what 3-D angle a stock 16" syncro presents?...any volunteers for this too?
http://vw.zenseeker.net/Wheels-LengthenedTrailingArms.htm
Much thanks j_dirge, great documentation of your very cool modification program...it's inspiring thoughts that would make mrs. s very nervous _________________ 87 Westy Camper |
Posted: Sun May 15, 2011 1:02 pm Post subject: |
OK.. That site just punched scary visions of 230hp long-travel 2WD buggy Vanagons into my other-wise traditional thinking brainium.
I am sure to blame you when Mrs. D gives me "the squinty eye".
I love youse guys! _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
SWbySWesty Samba Member
Joined: July 01, 2010 Posts: 327 Location: Adventureville, CA
Posted: Mon May 16, 2011 3:26 pm Post subject: |
subscribed. _________________ 1986 Westy - Billie Jean
A Westy with a Jeep heart (Pura Vida)
www.theadventurebrigade.blogspot.com - Latest update: Johnson Valley - Nov 22, 2011 |
Posted: Tue May 17, 2011 9:16 pm Post subject: |
More..
The beefed shock brackets.
I hear there's maybe another Samba-man getting these arms? _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Thu May 26, 2011 6:29 pm Post subject: |
Arrived.
Stoke! _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Thu May 26, 2011 6:47 pm Post subject: |
The shaved off flange area..
danfromsyr wrote: |
insyncro Banned
Posted: Fri May 27, 2011 5:23 am Post subject: |
Any chance you could weigh one for me.
Very curious as to how much with or without the bearing carrier.
dylan |
