wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Sun May 15, 2011 5:18 am Post subject: Vacuum leak question |
Was doing some tune up work on the 82 Westy yesterday and noticed that when I pinched the vacuum hose that runs between the s boot and the black breather unit that pugs into the hole on the top of the block - my engine vacuum kicked up 2 inches and the idle smoothed out noticeably.
Need to know if anyone has experienced this phenomenon, is this a normal occurance, etc...
To me gaining a solid 2 inches of vacuum at idle tells me something aint right. That extra 2 inches should be there all the time I would think.
Thanks _________________ 1982 Westy
2004 KDX200
2008 Kawasaki KLR 650
1979 Yamaha DT 175
1995 Toyota 4Runner |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun May 15, 2011 7:44 am Post subject: |
My uneducated observation -- if you could put you hand partially blocking the air intake wouldn't that increase vacuum? Could that effect be the same as what you're seeing (as the part you describe sounds like it is sucking crankcase fumes)? |
Posted: Sun May 15, 2011 8:04 am Post subject: |
You may have an air leak into the crankcase that is causing a lean run condition. Maybe a shot valve cover gasket. |
Posted: Sun May 15, 2011 12:59 pm Post subject: |
Wildthings wrote: |
nah..new gaskets in place.... _________________ 1982 Westy
2004 KDX200
1979 Yamaha DT 175
