The Stupid Question Thread
Page: Previous  1, 2, 3 ... 344, 345, 346 ... 513, 514, 515  Next
maz-o
maz-o is offline
PostPosted: Sat Oct 14, 2017 11:27 am    Post subject: Re: Electric wiring for newbie Reply with quote
Tcash wrote:
maz-o wrote:
How do I know which alternator/generator I have and if it's wired up correctly?
Look for a part number on it.
Which one do you have?
[img][/img]
Good luck
Tcash
Thanks that was helpful! Couldn't see a part number but it's definitely an externally regulated one, with the tripple connector going to the regulator, and the single connector going straight to the battery... But that can't be the correct wiring, right..??
busdaddy
busdaddy is offline
PostPosted: Sat Oct 14, 2017 11:43 am    Post subject: Re: Electric wiring for newbie Reply with quote
[img][/img]
Good luck
Tcash
Doesn't sound right, you'll have to add a regulator if all you have now is a single blue wire from the bus. Any regulator from a type 4 powered bus will work with that alternator, or a 74-75 beetle regulator (same as the bus unit with an added plug and $ on the price). The terminal numbers are on both plugs, match them up with a harness you fabricate.
Слава Україні!
maz-o
maz-o is offline
PostPosted: Sat Oct 14, 2017 1:16 pm    Post subject: Re: Electric wiring for newbie Reply with quote
busdaddy wrote:
[img][/img]
Good luck
Tcash
After googling for a while I actually found the diagram for my exact setup from this page: http://www.vw-resource.com/alternator_wiring.html
So here's my final stupid question (for now): What good does that regulator do since it doesn't regulate the current going into the battery or the electrical system of the car?
Thanks again
busdaddy
busdaddy is offline
PostPosted: Sat Oct 14, 2017 1:26 pm    Post subject: Re: Electric wiring for newbie Reply with quote
maz-o wrote:
busdaddy wrote:
[img][/img]
Good luck
Tcash
[img]pic[/img]
Thanks again
But it does, more specifically it controls how many volts the alternator puts out, unregulated an alternator can easily make 30 or more volts.
With no regulator connected the alternator won't produce anything so you can run the engine with no worries, but it won't charge the battery.
Слава Україні!
maz-o
maz-o is offline
PostPosted: Sat Oct 14, 2017 1:41 pm    Post subject: Re: Electric wiring for newbie Reply with quote
A-Ha! I for some reason thought the regulator had to always be placed between the battery and the alternator. In this setup it kind of "dangles on the side". Well it was the stupid questions thread after all. Thanks everyone!
Wildthings
Wildthings is offline
PostPosted: Sat Oct 14, 2017 2:10 pm    Post subject: Re: Electric wiring for newbie Reply with quote
With a DC generator the regulator senses both voltage and current and adjusts output accordingly, but with an alternator the regulator only senses voltage. With a generator the regulator also prevents backflow, while the diodes in the alternator provide this function.
white74westy
white74westy is offline
PostPosted: Tue Oct 17, 2017 2:54 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Can anybody tell me what size nuts and bolts are needed to attach the bowed (curved) piece of aluminum, to the front of a late bay pop top? I apologize for the crappy photo!
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Wed Oct 18, 2017 6:13 am    Post subject: Re: The Stupid Question Thread Reply with quote
Wildthings wrote:
secretsubmariner wrote:
Will a 32/36 dfav Weber progressive carburetor work with the distributor bearing the part number 021 905 205 P?
asking for a friend Embarassed
The 021-905-205P and the 022-905-205S would be the preferred distributors.
A very belated thank you, Wild Things. Very Happy
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
Terminatez
Terminatez is offline
PostPosted: Thu Oct 19, 2017 1:52 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I removed the iginition lock cylinder from my 72 bus.
I have to move it around this weekend..
Could the steering lock without the cylinder installed? Is there a way around this?
I was sending my cylinder out to get it rekeyed.
1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote:
I don't think I've ever seen an engine in worse shape.
Tcash
Tcash is offline
PostPosted: Thu Oct 19, 2017 2:47 pm    Post subject: Re: The Stupid Question Thread Reply with quote
See the metal thing in the middle. That is the lock mechanism and would need to be held in the unlocked position.
http://www.specialpatrolgroup.co.uk/spooky/barrel/barrel.html
The key number is on the side of the ignition lock you have in your hand.
Good luck
Tcash
Terminatez
PostPosted: Thu Oct 19, 2017 3:30 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hmm okay. That probably explains why I found a screw screwed into the nylon piece as I was removing the cylinder. It was probably holding the lock in place to prevent it from locking the steering wheel.
KentABQ Premium Member
KentABQ is offline
PostPosted: Thu Oct 19, 2017 6:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Almost every day, I search the Samba classified for listing of new Bays. And I'm not even remotely in the market to buy another one. It's interesting, though, to see the variety, and to appreciate the (extremely lucky) deal I got on eBay.
Does anyone else also check out the new postings regularly, even though you're not in the market? Question
busdaddy
busdaddy is offline
PostPosted: Thu Oct 19, 2017 6:26 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I used to, but recently I've pushed myself away from the bar. Too many projects and not enough room, time or money to get them all done, I can use the space more than another project right now. If I don't look I'll never know what I'm missing Wink
There's also the harsh realization that for all I've spent on cheap projects over the years that still need completion I could have just bucked up for 1 or 2 really nice finished vehicles and be driving it right now. I just don't have the spare time I did when I was in my 20's, life keeps getting in the way, not complaining because I love it, just time to face the music and reorganize my priorities.
But at the same time most of those projects have appreciated in thier "as is" state just sitting there more than any financial investment me or almost any one I know has going currently. Some laugh at me for keeping those "stupid old VW's" around, but as long as I bail out before the bubble bursts I'll be the one laughing. But the storage space they use could be earning just as much if I wanted to put up with strangers in my barn too, hmmm.....
Слава Україні!
KentABQ is offline
PostPosted: Fri Oct 20, 2017 5:58 am    Post subject: Re: The Stupid Question Thread Reply with quote
Since Stuart isn't around anymore to contribute to his Stupid Question sticky, I feel it's my duty to fill his shoes. And I've got looooots of stupid questions bouncing around in my empty tin can of a head...
For example:
Most pics I see of busses owned by people who are fans of originality position their side mirrors vertically rather than horizontally. In that position, it takes advantage of seeing more vertically, but less horizontally. When I'm driving, I'd prefer to see more of the vehicles next to me rather than seeing how tall they are. Smile
Since the Germans are known for favoring function over form (after all, that's how the Vanagon was developed, right?), why would they position the mirrors vertically?
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
danfromsyr
danfromsyr is offline
PostPosted: Fri Oct 20, 2017 6:41 am    Post subject: Re: The Stupid Question Thread Reply with quote
quoted for truth. with a yard full of projects the last 2 VWs I bought are running/driving/decent looking. I just want to spend more time enjoying them than building them. yet I can't let go of the backlog of project builds I've acquired over the 20yrs..
maybe it's that in mid-life I've lost too many friends too early in their own lives who never got to reach their goals..
there's a different outlook on a hobby at 45 vs 25.. and lets hope I'm enjoying it at 65.. too many roads to dive and vistas to see..
Abscate wrote:
cv66seabear
cv66seabear is offline
PostPosted: Fri Oct 20, 2017 7:19 pm    Post subject: Re: The Stupid Question Thread Reply with quote
For example:
Hey Kent,
Funny, but I had mine horizontrally, and found I actually see more of what I want with them vertically. I thought I was seeing more horizontally, but I didn't see as far back. I'm 6'2, so maybe that is different as well.
OK stupid question time: (BTW my starting and rough running seems to have come from a poor negative ground on my starting battery).
In order to tune up a Type IV FI, what will I need as far as tools/equipment? I have plenty of sockets and wrenches, do I need a dwell tach and a Timing light?
Kent
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
Wildthings
PostPosted: Fri Oct 20, 2017 8:28 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Collin (Amskeptic) runs his mirrors at a 45° angle, don't remember is he runs them top outward or top inward.
steverock
steverock is offline
PostPosted: Sat Oct 21, 2017 12:28 pm    Post subject: Re: The Stupid Question Thread Reply with quote
So I can't seem to find the answer to my specific question and kinda what I'm seeing is that it will work.
A family member has a 1972 bus that is doa. They were told they need a new engine (not gear heads and live a couple hours away so I can't confirm the problem). I have a 1974 standard beetle that I am in the middle of restoring with a good engine. What I want to do is swap the long blocks. What do I need to do to the type I long block to get it to work correctly with the type I?
If I had the bus with me I would just figure it out but I will have to prepare the type I engine at my house then drive several miles to install it into the bus and driving back and forth to change minor things isn't really an option.
Thanks for your help!
busdaddy
busdaddy is offline
PostPosted: Sat Oct 21, 2017 12:36 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Unless the bus is a European delivered model originally equipped with a 1600 swapping a Beetle motor into it is a big job, have a look at this: https://www.thesamba.com/vw/forum/viewtopic.php?t=483408
Слава Україні!
jack-o-van
jack-o-van is offline
PostPosted: Mon Oct 23, 2017 12:39 am    Post subject: Re: The Stupid Question Thread Reply with quote
No nuts - you can't get at the other side of the holes in the bus top. I used sheet metal screws. Splurged and got stainless. Not sure what metric original size was, I think I used #6 x 1/4 or 3/8. You want them to go through the holes in that aluminum channel you have without binding, then screw into the matching holes on the top of your bus.
Page 345 of 515
