Paddyoh1973 Samba Member
Posted: Tue Jan 16, 2018 8:19 pm Post subject: Re: The Stupid Question Thread |
Hey im new to the forum, i have a 1973 vw bus. Currently, im working on wiring to get this bus on the road. One of the problems im having is with the bus not generating power to the battery. I know somewhere on the bus its draining power so i bought a new wiring harness. But every time i start the bus and drive it, it loses power and i have to charge it. Im pretty sure its nothing on the fuse panel, im almost positive it has something to do with the alternator or regulator. Im not too familiar with these buses, its my first car so im not too sure what the problem is.
Posted: Tue Jan 16, 2018 8:59 pm Post subject: Re: The Stupid Question Thread |
Paddyoh1973 wrote: |
Hey im new to the forum, i have a 1973 vw bus. Currently, im working on wiring to get this bus on the road. One of the problems im having is with the bus not generating power to the battery. I know somewhere on the bus its draining power so i bought a new wiring harness. But every time i start the bus and drive it, it loses power and i have to charge it. Im pretty sure its nothing on the fuse panel, im almost positive it has something to do with the alternator or regulator. Im not too familiar with these buses, its my first car so im not too sure what the problem is. |
The trouble shooting procedures for either an alternator or generator are given in most any manual., but assuming you have a Type 4 engine then you only need to be concerned with the procedures for an alternator. If you don't have a multimeter, now is the time to buy one as without a meter you can only guess as to what is going on. |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Thu Jan 18, 2018 6:56 am Post subject: Re: The Stupid Question Thread |
+1 on Multimeter.
My first suspect is the alternator, but you have to check the battery while it's running, to see if it is charging.
I'd also check the battery ground, just because I've had trouble with mine.
Nice bus, BTW!!! _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
phoneguy Samba Member
Joined: March 14, 2008 Posts: 187 Location: Long Island
Posted: Thu Jan 18, 2018 7:49 am Post subject: Re: The Stupid Question Thread |
You should see between 13.5 and 14.5 Volts (DC) when engine is running. There I saved you from looking it up ! _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Thu Jan 18, 2018 6:23 pm Post subject: Re: The Stupid Question Thread |
Removed my 2 speed wiper switch.. from my 72 bus.
Wondering how the button returns to the off position for the washers.
Does it return to off with the pressure or do you have to pull on the switch for the button to return back to off?
141955517 _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
tonysantacruz Samba Member
Posted: Tue Jan 23, 2018 9:25 am Post subject: Re: The Stupid Question Thread |
So, there's a hole in the intake manifold.
What effect does it have? No clue here. |
Posted: Tue Jan 23, 2018 11:08 am Post subject: Re: The Stupid Question Thread |
tonysantacruz wrote: |
That is your heat riser pipe. If the heat risers are still hooked up at the exhaust ports then not fixing that hole is very apt to kill you and your family, as CO is very bad for your health. |
Posted: Tue Jan 23, 2018 4:23 pm Post subject: Re: The Stupid Question Thread |
Yikes. Thank God the entire system is shut-down. It’s getting fixed pronto. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jan 23, 2018 5:47 pm Post subject: Re: The Stupid Question Thread |
If you can't get your hands on a better manifold (not hard to find in the US, don't know about MX) that can be welded or brazed and patched. Clean out the tube first in case any other holes appear.
Your bus will hesitate and use much more gas than it should if that tube isn't connected to the exhaust so it heats the manifold, even in a tropical climate. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Tue Jan 23, 2018 6:46 pm Post subject: Re: The Stupid Question Thread |
hey that guy has the same work boots as me _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Thu Jan 25, 2018 7:53 am Post subject: Re: The Stupid Question Thread |
As you can probably tell by the pic, the whole fuel gauge part is in a very sorry state: the gels are missing, the paint is all gone. Question, how do you replace the gels? Do I need to strip another bus (long shot) or is there a template you can use to re-create them? |
Posted: Thu Jan 25, 2018 8:07 am Post subject: Re: The Stupid Question Thread |
[img]pic[/img]
Remove the cluster and open it up, they are likely rattling around inside there, good for patterns at the very least.
Be careful with the fine wires on the fuel gauge, hard to repair if you damage one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 25, 2018 9:09 am Post subject: Re: The Stupid Question Thread |
You could probably get a replacement instrument cluster from a place in the states like Busted Bus. I know shipping is rougher for people south of the border, but it would sure save you a lot of time. Also check out the classifieds here on The Samba |
luke9511 Samba Member
Posted: Thu Jan 25, 2018 11:57 am Post subject: Re: The Stupid Question Thread |
when looking for a bus should i look for one with a carb or fuel injection and is one better than the other? |
Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Thu Jan 25, 2018 9:24 pm Post subject: Re: The Stupid Question Thread |
I’m in the process of adding a return fuel line to my stock 74 gas tank, though many won’t touch it to weld on. I have obtained a brand new Enpi gas tank from Jbugs that has both outlets. The Enpi Tank looks well made. My question: Are Enpi gas tanks of good quality, comparable to OEM. Any concerns I should have using the Enpi tank over trying to get my stock tank welded on? |
Posted: Thu Jan 25, 2018 9:31 pm Post subject: Re: The Stupid Question Thread |
I think the difference will just be the thickness of metal used. You can easily hear it when you hit the tank that it's thinner therefor easier to puncture through. This shouldn't really be an issue considering there shouldn't be anything in the tank area to puncture it anyways.
Also, when I had that jbugs tank a while ago... it didn't have the middle wall that I think prevents the fuel from just swaying around when you're driving. I'm not sure if yours has it. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Convoy Samba Member
Posted: Thu Jan 25, 2018 10:12 pm Post subject: Re: The Stupid Question Thread |
Thanks for the reply. I will move forward with the new tank. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Jan 26, 2018 8:12 am Post subject: Re: The Stupid Question Thread |
luke9511 wrote: |
One isn't better than the other, they both have advantages. FI can be hard to troubleshoot, but once it is working it is very low maintenance and drives very nice. Also some parts can be hard to source. Carbs can typically be troubleshot easier, but don't always have as good of performance (depending on engine application etc. On a stock engine with stock carb, they are very comparable to FI) They also require more attention with maintenance and adjustments for Large changes in altitude or fuel quality. Focus on the quality\condition of the body when looking for a bus, finding a working engine is much easier.
Read through this a little, there are some good thought provokers:
http://john-perry.com/images/buyers.txt _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Fri Jan 26, 2018 8:28 am Post subject: Re: The Stupid Question Thread |
luke9511 wrote: |
If you have a head on collision in a 73 and later bus and you have your seat belt on, you have a good chance of walking away from the collision. In an earlier bus your chances are much slimmer. Lots of other stuff improved with time as well. |
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sat Jan 27, 2018 7:11 pm Post subject: Re: The Stupid Question Thread |
What is the thing with three dots on it that spins freely (right side of pic)? This is on the final drive of my 003 automatic transmission (part 011-507-111). I've looked in the Bentley and Dasher manuals and it isn't labeled in any of the diagrams.
Also, there is a rubber part in the picture below by my finger that is labeled in Bentley as "Cap for ventilation drilling". It has a slit that opens at the top when squeezed. I assume this is a diff breather of some sort? The rubber is a bit hard but my google-fu failed me trying to locate a part number.
_________________ 1974 Westfalia, automatic, dual-carb |
