SatireChuck Samba Member
Joined: November 13, 2009 Posts: 63 Location: North Arkansas
Posted: Sat Jul 28, 2018 6:36 am Post subject: Re: The Stupid Question Thread |
Hey gang,
I joined up several years ago and have lurked without posting. Reading the amazing advice and looking at the incredible talent of everyone here has been fun. I’m a Pastor in Jonesboro Arkansas and was just given a fixer-upper 1971 VW Van. It has *no engine* and sat for 30 years in one place! It has a little rust here and there (mostly the front panel) but I’m surprised at the condition. I’m very excited to spend the next couple of years restoring her in my garage! She’s my first VW. 💜❤️💙
Here is my first stupid question: how much are complete VW van engines to purchase? Is there a rough estimate so I can start shopping?
Here is my second stupid question: I would love to turn her into a Manual Transmission. How can I do that? I’m not knowledgeable about transmissions.
Thank you kindly for all your help and advice. I sincerely appreciate it!
-Brother Chuck
_________________ ***
“All we have to decide is what to do with the time that is given us.” -Gandalf
Brother Chuck’s VW’s:
1968 VW Beetle
1971 VW Bus (Currently under restoration) |
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Sat Jul 28, 2018 9:56 am Post subject: Re: The Stupid Question Thread |
Here's a stupid question for you all.
Why does my new head studs kit have 3 of the middle length (upper outer) and 9 of the longer one (bottom 8 ).
does the 9th long one replace one of the middle length ones, and if so which one?
1600 (AS) dual port rebuild.
SiameseCitys Samba Member
Joined: December 31, 2017 Posts: 19 Location: Raleigh, NC
Posted: Sat Jul 28, 2018 12:02 pm Post subject: Re: The Stupid Question Thread |
I wanted to not bother the board with, what I think, is such an extra stupid question, but I can’t find ANY documentation for this.
Primer: I got my ‘78 champagne edition bus from someone that didn’t know anything about it. There was no owner’s manual. I bought spark plugs the internet told me would fit. They didn’t. I downloaded a scanned owner’s manual, i bought the spark plugs usted in there, they were the same size as the previously purchased ones. I had auto zone order the ones their computer said were a crossover from the one I have... they arrived and were also not right.
As you can see, it’s a very wide thread, and not as long as some of the ones I’ve seen listed as “fits” my bus. Everything I’ve read has thread diameters at 14mm for my bus, with a thread reach of 19mm. But when I take a ruler to my spark plugs it’s more like 16mm and 17 or 18mm respectively.
Any guidance on what my options are? Can I shop for spark plugs by size anywhere? I’ve heard that CEs had “Porsche engines” should I look to for a different engine type to figure out my spark plug needs? The only vintage Volkswagen mechanic I’ve found stopped working on (or dealing with, I don’t remember the exact phrase) VWs that are newer than ‘72.
Any resources, suggestions, or straight up answers are appreciated.
Thanks guys. |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Sat Jul 28, 2018 2:01 pm Post subject: Re: The Stupid Question Thread |
SiameseCitys wrote: |
Thanks guys. |
That looks like it had a helicoil installed to repair stripped threads in the head. _________________ 1988 Ford Festiva L
1965 Honda 50 "Super Cub"
2016 Miami Sun Trike |
Posted: Sat Jul 28, 2018 3:28 pm Post subject: Re: The Stupid Question Thread |
BSQUARE wrote: |
That looks like it had a helicoil installed to repair stripped threads in the head. |
Wow, you’d think one of the 5 people I’ve spoken to at auto part stores would recognize that. Thank you.
So when I tried to use my replacement plugs they just kept spinning, does that mean I have to add helicoil to all my spark plugs to match the width of these old ones? |
Posted: Sat Jul 28, 2018 4:04 pm Post subject: Re: The Stupid Question Thread |
BSQUARE wrote: |
Yes.
I've had success with the "Time-Sert" and "Keen-Sert" brands from the local auto parts store. They're a sleeve (as opposed to a coil, like a helicoil), that's threaded inside and out.
On second glance, yours looks like the Time-Sert. _________________ 1988 Ford Festiva L
Ride_On Samba Member
Joined: August 27, 2015 Posts: 385 Location: Ottawa, Canada
Posted: Mon Jul 30, 2018 10:22 am Post subject: Re: The Stupid Question Thread |
SatireChuck wrote: |
Here is my second stupid question: I would love to turn her into a Manual Transmission. How can I do that? I’m not knowledgeable about transmissions. |
Can't really help you on the auto -> manual swap, but we sold our complete 77 2L fuel injected engine and 4sp 091 transmission complete (including FI and ECU) for $1500 last fall.
Keep an eye on the classifieds... good luck! _________________ 1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG) |
Target Samba Member
Joined: August 09, 2017 Posts: 60 Location: Los Angeles
Posted: Tue Jul 31, 2018 11:02 pm Post subject: Re: The Stupid Question Thread |
Hey everyone.
I'm working on wiring up a relay that needs signal from a switched source. The kit says the wire is only rated for 10 amps, which I believe means I can't use #9 from the fuse block (because it's 16 amps). I was wondering if anyone could tell me another good 8 amp switched source. Kit says I'm supposed to tap into the hot side of the terminal, but these fuses can't really be tapped.
I'm seeing a black and yellow wire that has power in run and the black ignition wire that has power in start and run. |
Danwvw Samba Member
Posted: Wed Aug 01, 2018 5:23 pm Post subject: Re: The Stupid Question Thread |
Target it will be ok there, Fuse may not protect relay but who cares about a relay. I would just run of the 30 wire and if you want a fuse use an inline 8 amp fuse for it.
Is it your fuel relay? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
airschooled Air-Schooled
Posted: Wed Aug 01, 2018 11:29 pm Post subject: Re: The Stupid Question Thread |
Target wrote: |
Hey everyone.
What year Volkswagen bus are we working on? The fuse layouts changed throughout the years.
If there is nothing else on that fuse, feel free to change it to an 8-amp white fuse.
If you would like to piggyback onto existing circuits, or "tap" in, then use some of these on the new components to avoid changing your vehicle's factory wiring:
Good luck!
www.airschooled.com |
smitty1976bus Samba Member
Joined: January 21, 2013 Posts: 369 Location: Cape Cod
Posted: Thu Aug 02, 2018 9:08 am Post subject: Re: The Stupid Question Thread |
Hello everybody!
Have a 1978 2.0L EFI Westy. Had the Injector resistor block fail on me (engine wouldn't start, new pack fixed the problem), so I switched it out with a back up unit. Now the bus is jerking and bucking ever so slightly when I lightly accelerate, starts around 2k rpm. The pack I had on my bus was part # 022 906 079, and the replacement is part # 0 280 159 001. Question, are these different??
Thanks! I can't seem to find many specs on these packs. |
Posted: Thu Aug 02, 2018 6:45 pm Post subject: Re: The Stupid Question Thread |
At the ECU plug, terminal 10 connected to 14/15/32/33 (one at a time) with an ohm-meter should give you 7-9 ohms. This will test the wiring from resistor pack all the way through the fuel injectors. When you’re taking the reading, get be meter to stabilize and have a helper gently prod the wires and connectors to see if the meter flickers, indication a possible dirty connection.
If your resistance lands in that ballpark, broaden your search to include nearby items. Did you bump a hose off the plenum in your work? Knock the TS2 wire out of connection?
Let us know how it goes!
Posted: Sat Aug 04, 2018 7:36 pm Post subject: Re: The Stupid Question Thread |
Please don't hate on me for asking this. I know someone will. I've seen those lovely wooden steering wheels and I was thinking of buying one. But they are literally between $400 and $500 dollars.
Are there any that are slightly more affordable you all can recommend please? I'm afraid of buying one then finding out that I paid way way way too much. I came to the experts for help!
Thank you kindly!
---Brother Chuck
1968 VW Beetle
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Mon Aug 06, 2018 6:33 am Post subject: Re: The Stupid Question Thread |
smitty1976bus wrote: |
Hello everybody!
They are all the same. If the resistance checks out, and these really don’t wear out, your problem lies elsewhere. However here is a small upgrade for making the wire last...
https://www.thesamba.com/vw/forum/viewtopic.php?t=660153&highlight= _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
heerojyuy Samba Member
Joined: November 26, 2006 Posts: 244 Location: Oregon, USA
Posted: Wed Aug 08, 2018 1:14 pm Post subject: Re: The Stupid Question Thread |
When adjusting valves on rigs with hydraulic lifters, do you do so at TDC or 7.5 BTDC? From the sound of my engine, I am guessing that it must be TDC 😅😅😅 _________________ 1979 Volkswagen Bus - Daily Driver
2000cc
FI |
xyzzy Samba Member
Joined: March 24, 2014 Posts: 229 Location: Encinitas, CA
Posted: Wed Aug 08, 2018 1:45 pm Post subject: Re: The Stupid Question Thread |
heerojyuy wrote: |
When adjusting valves on rigs with hydraulic lifters, do you do so at TDC or 7.5 BTDC? From the sound of my engine, I am guessing that it must be TDC 😅😅😅 |
TDC and then determine if you are on #1 or on #3 _________________ -----
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia |
Posted: Wed Aug 08, 2018 1:50 pm Post subject: Re: The Stupid Question Thread |
heerojyuy wrote: |
Anything within 90° +/- of TDC is fine. |
Posted: Wed Aug 08, 2018 11:21 pm Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
I don't see this answered, so…
All Type 1 cases made after the late '70s-ish have what's called a "deep studded #3" cylinder spigot. If you're looking at the left side of the case, where cylidner #3 lives, you will notice the top left stud hole is actually set a few inches deeper into the case to prevent common cracking on older cases.
Single port engines use long on bottom, short on top, and long in the deep #3 top left. Dual port engines use long on bottom and deep #3, short studs in the top center studs closest to the intake manifold, and medium-length studs on the top outer studs except the deep #3. So looking at a dual port 1-2 (right side) head would look like this:
Looking at the left side of the dual-port head looks like this:
Good luck!
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Thu Aug 09, 2018 9:48 pm Post subject: Re: The Stupid Question Thread |
A couple weeks back we were commenting on dual carbs fitted from CB Performance. I was very interested as they looked to be able to bolt on the 74 linkage and be used conventionally. Does anyone remember who was installing those and what the thread link is?
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Aug 10, 2018 6:23 am Post subject: Re: The Stupid Question Thread |
As long as I'm geeking out with installing new gauges, I'm thinking about adding a tach. ISP West sells a nice looking one...
https://www.vwispwest.com/jzv/prod?itemId=55454
...but it is only the tach and mounting hardware. I haven't found a site for the pickup coil (?). Anyone know where to find one and where it gets installed/attached? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
