ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sun Nov 04, 2018 10:26 pm Post subject: Re: The Stupid Question Thread |
While browsing the classified I came upon this picture and saw something I've never seen on a bus, some sort of belly pan. Is that stock? What is the name of the part?
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Nov 05, 2018 4:59 am Post subject: Re: The Stupid Question Thread |
That's a BA6 belly pan if I've ever seen one… More info about the heater here, and people who can answer questions better than I…
https://www.thesamba.com/vw/forum/viewtopic.php?t=331276
Interesting, no pictures or part numbers there though…
www.airschooled.com |
JCurry Samba Member
Joined: November 05, 2018 Posts: 1 Location: Bremond Tx
Posted: Mon Nov 05, 2018 12:33 pm Post subject: Re: The Stupid Question Thread |
My wife talked me into buying her a 73 bus. It does not have an engine at this time, and I have been looking for one for awhile, but I seem to get conflicting answers as to what will fit, and what will not fit. I just need something to bolt in and drive, not looks for Subaru conversions or anything like that. Will bug engines go directly into the bus? I have a guy with a 75 bus engine for sale which he says will go in fine, but my buddy says that it will not go.
Please help me out! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Nov 05, 2018 1:26 pm Post subject: Re: The Stupid Question Thread |
JCurry wrote: |
A 75 bus engine (type 4) will go right in, you'll have to modify the fuel tank and install an aircleaner mount to use the FI, or convert it to carbs. Beetle engines (type 1) can be made to fit with a few modifications and special parts: https://www.thesamba.com/vw/forum/viewtopic.php?t=483408&highlight= _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon Nov 05, 2018 6:33 pm Post subject: Re: The Stupid Question Thread |
JCurry wrote: |
My wife talked me into buying her a 73 bus. |
She (wife, not bus) sounds like a keeper to me! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Mon Nov 05, 2018 9:50 pm Post subject: Front license Plate |
I just got an $85 ticket for not having a front license plate. The original one was secured by two screws through the middle of the plate to the front bumper. The plate took a lot of damage throughout the years. Any suggestions for a better mount? (1970 [early bay]).
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Tue Nov 06, 2018 1:57 pm Post subject: Re: Front license Plate |
wihr wrote: |
WW |
Mine is still held on by the screws from 1968. In fact. I can't get one out, so I put the other back in, and it's still there. As it always has been.
Why not the same system that worked for 50 years? _________________ ~Kevin
My 1968 Campmobile |
Zonkey Samba Member
Joined: November 01, 2018 Posts: 21 Location: Elko, NV
Posted: Wed Nov 07, 2018 11:25 am Post subject: Re: The Stupid Question Thread |
I have a 1970 Adventurecamper and have been fixing it up. In the pic it's on a trailer but it runs pretty good (leaky carb, bad breaks) and I have only driven it around my ranch. I've been fixing the brakes. I don't like having to remove a castle nut to service the brakes. I'm guessing this is why VW discontinued it's usage 1971+?
Here's where my stupid questions begin.
PERTAINING TO REAR HUB REMOVAL TO ACCESS BRAKES
1.) What are my options to use something different then the castle nut rear?
2.) Can I use 1971+ rear setup?
3.) Should I just go to some kind of aftermarket disc brake setup? 4.) Should I stop whining and just stick with the castle nut rear?
5.) Is there any advantages to having a castle nut?
Thanks!
_________________ =================================
1970 Adventurewagon |
Posted: Wed Nov 07, 2018 4:47 pm Post subject: Re: The Stupid Question Thread |
Nice looking bus!
I'd be more concerned about fixing that fuel leak and replacing ALL the fuel lines before it caught fire, it won't be so nice anymore if that happens.
Removing the drum isn't a big job if you have the right tools, this makes it easy and can ride along in the bus for roadside use: http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7045
There's not many times that drum has to come off once the brakes are dialed in, count on replacing the cylinders and shoes (& maybe cables) and cleaning everything else up. Adjustments and shoe thickness inspections are done from outside through conveniently placed holes, keep them adjusted and there's no real need to remove the drum regularly. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Nov 07, 2018 6:41 pm Post subject: Re: The Stupid Question Thread |
"WARNING: Cancer and Reproductive Harm"
What did they do, make them out of Uranium??? _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Zonkey Samba Member
Posted: Thu Nov 08, 2018 2:18 pm Post subject: Re: The Stupid Question Thread |
Thanks guys, I'll get better at taking the castle nuts off.
Here's a pic of my wheel. The tire is a 165 sr15 so this must be the wide 5 wheel. After some research, this doesn't appear to be a bus wheel because the valve stem doesn't line up with the lug nut. My tires are old and I want to get all new tires.
Stupid questions.
1.) Am I correct to assume this is not a bus wheel?
2.) Should I replace these wheels with other wide 5 SB wheels OR get some 14" bus wheels or even something else?
3.) What are advantages to 15" SB wheels as opposed to 14" stock wheels?
Thanks!
Posted: Thu Nov 08, 2018 3:54 pm Post subject: Re: The Stupid Question Thread |
Looks like a bug wheel, not nearly as strong as a real bus wheel, narrower too. 14" wide 5 bay wheels aren't hard to find, they are guaranteed to be up to the weight of a fully loaded camper and will play well with transmission ratios and speedometers. Careful when shopping for aftermarket alloys, most are cast not forged and are 15".
Make sure whatever tires you choose have the C load rating or better yet LT. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airkooledchris Samba Member
Posted: Fri Nov 09, 2018 1:50 pm Post subject: Re: The Stupid Question Thread |
JCurry wrote: |
that engine will fit just fine. if you put dual carbs on it, it should be pretty simple to get up and running.
1975 was originally fuel injected, so if it comes with all of the fuel injection stuff - that would be great to install as well (though you will have to slightly modify the gas tank for the return line.) |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Sun Nov 11, 2018 1:18 pm Post subject: Re: The Stupid Question Thread |
when you buy repair panels that have some factory paint on them, is it necessary to strip all of the paint and re-primer? or can you strip just the welding contacts and leave the rest |
Posted: Sun Nov 11, 2018 1:32 pm Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
Which factory?, if it's a used part cut from a vehicle and has strong original paint that's already been stuck for close to 50 years then leave it as a base.
If it's a newly manufactured part coated in something for shipping it's safest to strip and start with bare metal unless the Mfg. specifically states it's OK to use as is. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Mon Nov 12, 2018 8:41 am Post subject: Re: The Stupid Question Thread |
I've found very little info on this Japanese Blaupunkt Tucson cassette I had in my old Bug.
I'll probably put it in the Bus. It has 2 sets of RCA outs, F/R, got it in '83.
I was amazed back then that the Dolby button worked with the radio as well. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Sawspa Samba Member
Joined: May 12, 2012 Posts: 173 Location: South-East Ohio
Posted: Mon Nov 12, 2018 2:37 pm Post subject: Re: The Stupid Question Thread |
Are all the car covers the same? I know thats a stupid question. What I mean is:
I see car covers as cheap as $25 up to $150 on ebay and other places. Some say waterproof/water resistant. Some have zippers. Anybody try these different styles and have any opinions? I live in Ohio, so rain and ice are the norm. Im just trying to keep water out and from laying wet touching the outside. Anyone have any recommendations? _________________ 1978 Westfalia Campmobile 2.0L oversized ham heads and a stepped up cam, running points and a 76 exhaust "Lefty Loosy" |
Posted: Mon Nov 12, 2018 2:45 pm Post subject: Re: The Stupid Question Thread |
Sawspa wrote: |
I see car covers as cheap as $25 up to $150 on ebay and other places. Some say waterproof/water resistant. Some have zippers. Anybody try these different styles and have any opinions? I live in Ohio, so rain and ice are the norm. Im just trying to keep water out and from laying wet touching the outside. Anyone have any recommendations? |
Yes. Go buy a tarpaulin from home depot. Crack one window maybe a half inch. Put two desiccant bead type dehumidifiers in the bug. Car covers a shitty for keeping out the water. If you do get a car cover because the paint is nice - then it acts as a good buffer for the tarp.
Then bungee it all down. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
