Sawspa Samba Member
Joined: May 12, 2012 Posts: 173 Location: South-East Ohio
Posted: Mon Nov 12, 2018 2:54 pm Post subject: Re: The Stupid Question Thread |
notchboy wrote: |
Sawspa wrote: |
Are all the car covers the same? I know thats a stupid question. What I mean is:
I see car covers as cheap as $25 up to $150 on ebay and other places. Some say waterproof/water resistant. Some have zippers. Anybody try these different styles and have any opinions? I live in Ohio, so rain and ice are the norm. Im just trying to keep water out and from laying wet touching the outside. Anyone have any recommendations? |
Yes. Go buy a tarpaulin from home depot. Crack one window maybe a half inch. Put two desiccant bead type dehumidifiers in the bug. Car covers a shitty for keeping out the water. If you do get a car cover because the paint is nice - then it acts as a good buffer for the tarp.
Then bungee it all down. |
Thanks. Its a camper bus, and the paint isn’t really that nice. I forgot to ask about the fit as well. But tarps would work too I suppose. I do get in and out of my bus and also drive it occasionally, so Ease of use and access matters. Ive seen some nice ones that look form fitting with zipper doors, but if they aren’t waterproof, whats the point. _________________ 1978 Westfalia Campmobile 2.0L oversized ham heads and a stepped up cam, running points and a 76 exhaust "Lefty Loosy" |
Sawspa Samba Member
Posted: Mon Nov 12, 2018 3:12 pm Post subject: Re: The Stupid Question Thread |
Sawspa wrote: |
notchboy wrote: |
Sawspa wrote: |
I might try a pop up canopy with a large tarp over top of that, which would help make walls. If it can hold ip to the snow it might be like an instant garage. If i do it, i will post a pic. Im sure it will be beautiful.
Thanks. Its a camper bus, and the paint isn’t really that nice. I forgot to ask about the fit as well. But tarps would work too I suppose. I do get in and out of my bus and also drive it occasionally, so Ease of use and access matters. Ive seen some nice ones that look form fitting with zipper doors, but if they aren’t waterproof, whats the point. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon Nov 12, 2018 6:18 pm Post subject: Re: The Stupid Question Thread |
I re-installed the drive train yesterday by myself for the first time. All went well, except for the two bolts that support the rear of the transmission. I was able to get them in the locations, but they are tight and can't get them to catch the captured nuts. I've tried raising and lowering the drive train a little at a time, and threading the bolts but with no success. (The mustache bar and nose cone are both loosely attached.)
Is there a slick trick that someone has for installing those two bolts? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Nov 12, 2018 6:37 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
Is there a slick trick that someone has for installing those two bolts? |
You mean the ones over the bellhousing, right?
Laying under the bus with your head to the front and your feet under the rear bumper has always worked for me, you may have to straddle a jack that a helper operates while you lift or tilt the engine with your knees and feel for when a bolt feels loose and goes in freely. You have to find the extremes of too far down or up and find the middle between them, jack a little and try it, worse?, or better?, if better jack a bit more, if worse let it down a hair. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Nov 12, 2018 6:42 pm Post subject: Re: The Stupid Question Thread |
Thanks BD! I'll give that a try. _________________ -Kent-
---williamM |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Tue Nov 13, 2018 8:42 am Post subject: Re: The Stupid Question Thread |
Sawspa wrote: |
notchboy wrote: |
Sawspa wrote: |
It's good you occasionally use it. Get 2 of the desiccant/dehumidifier packs. Then rotate them every time you uncover the bus to drive it. In between you can 'recharge' the desiccant for the next swap. _________________ ~Kevin
My 1968 Campmobile |
Posted: Tue Nov 13, 2018 8:49 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
KentPS wrote: |
Laying under the bus with your head to the front and your feet under the rear bumper has always worked for me, you may have to straddle a jack that a helper operates while you lift or tilt the engine with your knees and feel for when a bolt feels loose and goes in freely. You have to find the extremes of too far down or up and find the middle between them, jack a little and try it, worse?, or better?, if better jack a bit more, if worse let it down a hair. |
Yup, that did the trick. Thanks again, BusDaddy.
I think my previous problem was trying to lift the drive train from the engine. This time I put a small floor jack under the trans, and slowly lifted from there. Just a couple pumps and both bolts went in.
Now the engine is secure, and time to connect everything else. I'll work on it again tonight after work. Maybe she'll be running by the end of the week? _________________ -Kent-
---williamM |
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Tue Nov 13, 2018 12:02 pm Post subject: Re: The Stupid Question Thread |
Is there some distinction which models had the vertical or horizontal lines on the seat upholstery?
I'm going to reupholster these for my camper converted bus, but don't know which covers to go with...
(they're sourced from different buses since I had a 1+2 bench on a walkthrough body, and wanted 1+1 ones instead) |
Posted: Tue Nov 13, 2018 1:25 pm Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
The white one is from a commercial (kombi, truck, etc..), the red one is from a deluxe (microbus), both look to be in the 68-73 range. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Tue Nov 13, 2018 11:44 pm Post subject: Re: The Stupid Question Thread |
What is the official name for this cover, and the one in the rear? I'm looking for part numbers, but couldn't find anything after quite a while in the fiche…
Thanks!
Robbie
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Wed Nov 14, 2018 4:02 am Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Sliding door catch cover - 221 843 698B
https://www.vwheritage.com/221843698b-sliding-door-catch-cover-right-vw-spare
I don’t have a rear cover in my ‘79 Bus. _________________ 1979 Microbus |
Posted: Wed Nov 14, 2018 11:17 am Post subject: Re: The Stupid Question Thread |
Thank you, Steve!
I recall seeing nice little 10mm bolt head caps on the low-milage late bays I worked on this summer, but I can't remember which early years had the rear cover.
Thanks again,
Posted: Wed Nov 14, 2018 11:33 am Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Thank you, Steve!
Thanks again,
Robbie |
I still have the caps on mine. Let me see if I can read the part number on the inside....
Update: looks like 211 843 689, but the text is tiny. That part # doesn't show up on a Google or VW Classic Parts search either. _________________ 1979 Microbus |
Posted: Mon Nov 19, 2018 9:17 am Post subject: Re: The Stupid Question Thread |
Is there a knack to getting the rubber tube onto the bottom of the window regulator? Heat? Lube? Other?
Mine was missing (surprise, surprise). Found a replacement in classifieds, but struggling to push it onto the regulator.
Also, do all doors (mine's a '79) have the "rear window guide channel" mentioned in the following tutorial? Supposed to be located at the rear of the door, secured by a 10mm head bolt and spring clip.
http://type2.com/rvanness/lock.htm
Posted: Mon Nov 19, 2018 11:04 am Post subject: Re: The Stupid Question Thread |
Sit the end of the tube in boiling water for a minute before installing.
No guide channel on later models, it's mostly an early bay thing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airkooledchris Samba Member
Posted: Wed Nov 21, 2018 11:37 am Post subject: Re: The Stupid Question Thread |
airkooledchris wrote: |
Are there any antenna's made that you can unscrew if you want to go through an automatic car wash?
The typical vertical mount antenna like the dealer installed, as I already have the hole for that drilled in the body. |
Why yes, sir, there is.
It turns out that if you order the following from CIP1.com, you will get an antenna that unscrews from the base as needed, though it isn't promoted as such on the websites:
ACC-C10-3340-CH - CHROME SINGLE BASE SIDE MOUNT ANTENNA - BEETLE 46-79 / BUS 50-79 / THING 73-74 / 80-92 VANAGON |
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Sat Nov 24, 2018 11:17 am Post subject: Re: The Stupid Question Thread |
This may qualify as a stupid question. Is the lip of the fuel filler supposed to be bent? I'm replacing the filler neck seals. I don't see a purpose for it but figured I'd ask before bending it back.
_________________ Tom
1977 Westy. 2.0 Fuel Injected. |
Posted: Sat Nov 24, 2018 11:41 am Post subject: Re: The Stupid Question Thread |
Bend it back, that's wrong as it is now. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Poppy68 Samba Member
Posted: Sun Nov 25, 2018 5:05 am Post subject: Re: The Stupid Question Thread |
This is going to sound stupid but really don't know who else to ask......
Restoring my 68 Baywindow Camper and have bought a lot of new seals. I bought the one piece engine lid seal. My question is if you install the one piece rear engine seal how do you remove the rear apron and engine when you want to do engine work? Will the bottom part of the seal that usually is on the apron be hanging in front of the engine bay blocking the opening?
Any comments are appreciated. |
