kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun Nov 25, 2018 9:30 am Post subject: Re: The Stupid Question Thread |
Poppy68 wrote: |
if you install the one piece rear engine seal how do you remove the rear apron and engine when you want to do engine work? |
You just don't glue the bottom legs. It will stay in place just fine without glue. In fact, many seals do not need glue
anywhere, they are very snug in their channels. _________________ '67 bug: seized by the authorities
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Sun Nov 25, 2018 9:46 am Post subject: Re: The Stupid Question Thread |
I'm replacing carpet while I wait on filler neck parts. It looks like PO may have added the piece of wood under the sink that rests on top of the carpet padding/wood stuff. Is this supposed to be there or was it added? I never noticed a lip under the carpet. Should I leave It or take it out?
Edit: looks like I'm missing the other half of the subfloor from what I can tell that fits on the passenger side. _________________ Tom
1977 Westy. 2.0 Fuel Injected.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Nov 25, 2018 9:48 am Post subject: Re: The Stupid Question Thread |
Poppy68 wrote: |
This is going to sound stupid but really don't know who else to ask......
Restoring my 68 Baywindow Camper and have bought a lot of new seals. I bought the one piece engine lid seal. My question is if you install the one piece rear engine seal how do you remove the rear apron and engine when you want to do engine work? Will the bottom part of the seal that usually is on the apron be hanging in front of the engine bay blocking the opening?
Any comments are appreciated. |
The OG seal was split dead center of the lower strip, the ends can be pulled out of the apron and left hanging to get the engine out. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Sun Nov 25, 2018 1:05 pm Post subject: Re: The Stupid Question Thread |
You simply remove the seal. You do not glue it in place.
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
Poppy68 Samba Member
Posted: Sun Nov 25, 2018 4:12 pm Post subject: Re: The Stupid Question Thread |
I knew it was simple. Thanks busdaddy and wihr!! |
Koeppler Samba Member
Joined: April 21, 2011 Posts: 481 Location: Aging gracefully
Posted: Thu Nov 29, 2018 8:10 am Post subject: Re: The Stupid Question Thread |
I have to pull the exhaust on a early bay ('69). What all do you guys take off the bus to get at the upper exhaust nuts for #2 and #4? Do you pull the bumper and rear valence? Remove the rear tin? |
Posted: Thu Nov 29, 2018 10:06 am Post subject: Re: The Stupid Question Thread |
Koeppler wrote: |
Remove the body apron and the rear engine tin, you should be able to reach around the bumper no problem. In severe cases put a jack under the engine and loosen/remove the mustache bar as well, those clamps between the heat exchangers and muffler are challenging. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Thu Nov 29, 2018 10:50 am Post subject: Re: The Stupid Question Thread |
Koeppler wrote: |
I enjoy liberal use of an s-wrench when getting early bay exhausts off:
https://www.google.com/search?q=s-wrench&oq=s-...p;ie=UTF-8
If you're removing the entire exhaust system, I recommend removing the heat exchangers first, so the muffler has a liiiiiittle bit more room to wiggle free once you remove the fasteners.
www.airschooled.com |
Posted: Fri Nov 30, 2018 9:35 am Post subject: Re: The Stupid Question Thread |
Thanks for the tips busdaddy and asiab3. I can't remember who I loaned my set of s-wrenches to. I guess I'll have to do it the busdaddy way. |
wcfvw69 Samba Purist
Posted: Fri Nov 30, 2018 5:26 pm Post subject: Re: The Stupid Question Thread |
Koeppler wrote: |
I don't even own S-wrenches and have zero problems removing a stock muffler on my 70' bus. As mentioned, the biggest pain is the 10mm nut's and bolts on the donut clamps. Still easy to do with 1/4" socket set and 10mm wrench. _________________ Contact me at [email protected]
The Samba member since 2004.
D/A/N Samba Member
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Sun Dec 02, 2018 3:30 pm Post subject: Re: The Stupid Question Thread |
Two questions about this steering swing on the beam:
1) It looks pretty shoddy, I assume it's repaired by a previous owner?
2) Are those very noticeable holes supposed to be there? Or should I weld them up?
Thanks
Posted: Sun Dec 02, 2018 3:37 pm Post subject: Re: The Stupid Question Thread |
Don't look like the best welds in the world, but the holes may have been left to drain out the water. |
maz-o Samba Member
Posted: Sun Dec 02, 2018 3:41 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
okay thanks!
so when I pump new grease into the center zerk, will it sip out of these holes? or is it not directly connected to the greased area? |
Posted: Sun Dec 02, 2018 4:27 pm Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
Wildthings wrote: |
okay thanks!
If grease comes out of there you have problems, as WT's says likely to allow water drainage and most likely factory, pretty good, but more good than pretty. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Wed Dec 12, 2018 7:59 pm Post subject: Re: The Stupid Question Thread |
Do these fuel hardiness look like they are in their correct spots?
They seem to be, based off of this diagram.
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Wed Dec 12, 2018 8:53 pm Post subject: Re: The Stupid Question Thread |
Yes, of course you'll find out if you are wrong when you try to fit them, if they cam off that engine they must fit back somewhere. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Dec 12, 2018 9:11 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Yes, of course you'll find out if you are wrong when you try to fit them, if they cam off that engine they must fit back somewhere. |
That's the thing, they didn't come off of my engine (77), they are from a 78-79. I'm upgrading to these to minimize the length of hose being used in order to lessen the chances of hose failure. I'll either be using the hoses German supply supplied in their kit with the ratwell recommended hose clamps or I'll get some Gates FI rated hose. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Wed Dec 12, 2018 9:26 pm Post subject: Re: The Stupid Question Thread |
I would argue that the number of hose to tube joints in the fuel system corresponds to fire risk more closely than the length of hoses. |
airkooledchris Samba Member
Posted: Thu Dec 13, 2018 2:52 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
Under the assumption that more fuel leaking is happening at the hose clamp connections Vs frayed/split/cracked hoses somewhere along the length of hose?
The failures ive found thus far have all been little cracks along the line of the hose and not at the clamping position, but I don't have a large enough sample set to pull from to make a guess one way or the other. |
