maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Wed Jan 23, 2019 9:15 am Post subject: Re: The Stupid Question Thread |
How significant is the little "cup" part for the rear bump stopper? And are there replacements for it?
I've lost it from one side. Otherwise trailing arm is in perfect condition.
Jack_O_Trades Samba Member
Joined: August 14, 2014 Posts: 188 Location: Bay Area CA
Posted: Wed Jan 23, 2019 10:59 pm Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Jack_O_Trades wrote: |
I did a quick forum search but only came up with a couple of results.
Are there any good options for a rear cargo mat? I have a carpet kit that includes this piece but I was looking for a rubber piece along the same quality as the original VW floor mats. |
I don't have any experience with this exact mat, but WW rubber is usually pretty good. Their front mat doesn't handle curves well, as it's too thick, but the rear mat has no curves, so you should be good. Airtek makes front mats that are thin enough to fit properly, but I don't know if they make a rear.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211863731
I've had great luck with WCM rubber as well, but again I can't speak for this particular mat.
https://www.westcoastmetric.com/i-22966752-211-731.html
Good luck!
Robbie |
Thanks for the links. I was looking for something for the rear-rear area. Adding onto my stupid question, what is this area referred to as? Luggage compartment...? |
airschooled Air-Schooled
Posted: Wed Jan 23, 2019 11:18 pm Post subject: Re: The Stupid Question Thread |
"Rear Luggage Compartment" apparently.
I've never seen a rubber mat available. Anybody else? Stock buses had carpet that stuck to the paint in warm weather unless you spread some talc powder under the carpet pre-melting…
www.airschooled.com |
Brian Samba Moderator
Posted: Thu Jan 24, 2019 10:43 am Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
I've lost it from one side. Otherwise trailing arm is in perfect condition. |
Without it, the arm could travel too far up and cause wear or damage to other components. Doubt they're made new, but worth getting one second hand or cut off from a rusty arm. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
maz-o Samba Member
Posted: Thu Jan 24, 2019 12:11 pm Post subject: Re: The Stupid Question Thread |
Brian wrote: |
maz-o wrote: |
Without it, the arm could travel too far up and cause wear or damage to other components. Doubt they're made new, but worth getting one second hand or cut off from a rusty arm. |
the way I see it, the cup itself is only like 1/8in thick, and the base for the cup still catches the bump stopper, keeping the motion normal. i just wonder if the edges of the cup have significant meaning of catching the rubber stopper or something like that...
this is what it looks without the cup:
and here's a reference with the cup in place. imo, the range of motion isn't really changed at all without it. the only thing missing are the edges.
busdaddy Samba Member
Posted: Thu Jan 24, 2019 1:14 pm Post subject: Re: The Stupid Question Thread |
The cup contains the snubber as it squishes down, when it's missing the arm just sort of stabs into it and could allow more travel. Any flat steel disc bolted or welded there will work. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
maz-o Samba Member
Posted: Thu Jan 24, 2019 4:25 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
The cup contains the snubber as it squishes down, when it's missing the arm just sort of stabs into it and could allow more travel. Any flat steel disc bolted or welded there will work. |
Very true! Thanks for the tip! |
Jlghost Samba Member
Joined: December 07, 2018 Posts: 1 Location: New Mexico
Posted: Thu Jan 24, 2019 7:30 pm Post subject: Re: The Stupid Question Thread |
Anyone know how to open one of these charcoal evaporation canisters?
Zonkey Samba Member
Joined: November 01, 2018 Posts: 21 Location: Elko, NV
Posted: Fri Jan 25, 2019 11:38 am Post subject: Re: The Stupid Question Thread |
Hello! I've had some time to work on my bus and noticed the end of my shift rod looks like it bends to the left.
a.) It's normal
b.) try bending it straight
c.) buy a new one because I'll never be able to bend it correctly.
Thanks guys!
_________________ =================================
1970 Adventurewagon |
Posted: Fri Jan 25, 2019 1:16 pm Post subject: Re: The Stupid Question Thread |
Zonkey wrote: |
a.) It's normal
Thanks guys! |
I'll pick B. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jan 25, 2019 1:48 pm Post subject: Re: The Stupid Question Thread |
Zonkey wrote: |
a.) It's normal
Thanks guys!
Set it on two 2x4 blocks spaced 8-10" apart with the bend upward. Now take another 2x4 and your 3-4# sledge and give it a few firm raps. You may need to have another 2x4 block under the far end of the rod and something heavy laying on the end to hold it down. |
Zonkey Samba Member
Posted: Fri Jan 25, 2019 1:59 pm Post subject: Re: The Stupid Question Thread |
Thanks guys, I was hoping it might be normal, saw a couple of these bent on the internets with people asking the same question as me. I'm guessing it's not factory, that would be strange. I just wonder how this happens, seems to be a common occurance? I will take a "whack" at it with the 2x4 method you suggested Wildthings. Worst case is WW sells them for $118. Thanks again! _________________ =================================
Posted: Fri Jan 25, 2019 3:48 pm Post subject: Re: The Stupid Question Thread |
Zonkey wrote: |
Thanks guys, I was hoping it might be normal, saw a couple of these bent on the internets with people asking the same question as me. I'm guessing it's not factory, that would be strange. I just wonder how this happens, seems to be a common occurance? I will take a "whack" at it with the 2x4 method you suggested Wildthings. Worst case is WW sells them for $118. Thanks again! |
Heat works well to give the metal more give.
Posted: Sat Jan 26, 2019 2:27 pm Post subject: Re: The Stupid Question Thread |
Can the type 4 oil cooler support bracket be installed after the fan shroud is installed?
Posted: Sat Jan 26, 2019 2:49 pm Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Robbie |
Yes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Zonkey Samba Member
Posted: Sat Jan 26, 2019 2:58 pm Post subject: Re: The Stupid Question Thread |
So I straightened the rod with heat as suggested, worked great!
My brother helped me, he's restoring a Honda Pilot?
Next Question, what is this thing? It's in the rear where the eingine door is. it looks like a diaphram of some sort and has an adjustment screw.
Thanks! _________________ =================================
wcfvw69 Samba Purist
Posted: Sat Jan 26, 2019 3:47 pm Post subject: Re: The Stupid Question Thread |
It's an altitude corrector. It's part of the early smog system for buses starting in 1970-1971 when they went to two part. The other part is on the carb and is called a throttle positioner.
Someone else's picture. _________________ Contact me at [email protected]
The Samba member since 2004.
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sat Jan 26, 2019 8:39 pm Post subject: Re: The Stupid Question Thread |
The cable connecting my dashboard heater defrost lever broke off at the ferrule. Is this part still available or is it integral to the cable? I didn't find anything when searching for parts but perhaps I was using the wrong terms.
Maybe it is possible to re-use it by re-crimping somehow (assuming I can get the broken cable end out of it)?
_________________ 1974 Westfalia, automatic, dual-carb |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sat Jan 26, 2019 9:00 pm Post subject: Re: The Stupid Question Thread |
stwesty wrote: |
Unfortunately my friend, that is indeed part of the cable. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
