billiebear Samba Member
Joined: June 06, 2011 Posts: 8 Location: West Florida
Posted: Thu Jan 21, 2021 4:45 pm Post subject: Re: The Stupid Question Thread |
I was given a "B" case engine that had broken a valve. After removing the broken piston and cylinder, the crank rolled easily, but being an optimist (not), I continued to separate the cases only to find the fuel pump shaft had bent and was no longer touching the Distributor Drive Pinion, also a flat lobe on the offending valve. So I was right.
I am looking at the bearings and the split main has an elephant and the kb stamp, part number is 850717100.25, I am pretty sure it is a Kolbenschmidt.
Can any body translate this for me? VW shops are few and far between in my area.
Thanks |
mewidmer Samba Member
Joined: March 29, 2017 Posts: 8 Location: Los Angeles
Posted: Wed Jan 27, 2021 3:14 pm Post subject: Re: The Stupid Question Thread |
OK - my first (of to be many) stupid question post....
Can someone confirm this is a 009 Distributor? I'm 95% certain, but have realized to never put anything past the prior owner...
The only PN # / Label I could find was EMPI 18/44 - and for some reason, I'm not finding many results when I google/search
Bus is a 1971 Weekender, with Dual Carb ICT (EMPI) setup
Thanks! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Jan 27, 2021 3:16 pm Post subject: Re: The Stupid Question Thread |
mewidmer wrote: |
Can someone confirm this is a 009 Distributor? I'm 95% certain, but have realized to never put anything past the prior owner... |
That's a 009-style distributor. It may work great, or it may be a paperweight. The EMPI HPMX carbs are quite good, but I have not found their distributors to be as precise.
www.airschooled.com |
Posted: Wed Jan 27, 2021 3:28 pm Post subject: Re: The Stupid Question Thread |
mewidmer wrote: |
Thanks! |
Don't have a clue as to how much advance your distributor has. Buses in general require less advance than the same engine installed in a beetle, while many 009 clones have more advance than a real Bosch 009 does. |
Posted: Wed Jan 27, 2021 3:53 pm Post subject: Re: The Stupid Question Thread |
airschooled wrote: |
mewidmer wrote: |
Robbie |
Awesome! I'm leaning toward paper weight vs a super special EMPI 18 of 44 edition |
Posted: Wed Jan 27, 2021 4:53 pm Post subject: Re: The Stupid Question Thread |
mewidmer wrote: |
If you set the max advance to 28-30° btdc, idles between 8° and 15°btdc, and gets going smoothly, I'd run it. Otherwise, start reading up on how to work those carbs with an SVDA, or get a restored 010/019.
allanmcclard Samba Member
Posted: Thu Jan 28, 2021 7:38 am Post subject: Re: The Stupid Question Thread |
So I have a stupid question, how do I know what type of distributor I have because I'm very new to vw and I inherited a 1977 bay window and honestly don't know crap about them. Needless to say I bought an electronic ignition conversion kit and its the wrong one, I'm not sure if jbugs will take it back with it being electronic. Now I do know my distributor has the vacuum pump off the side of it with the little arm running into the distributor. The kit I bought was apparently for the 009, please help if you can thanks. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jan 28, 2021 8:32 am Post subject: Re: The Stupid Question Thread |
allanmcclard wrote: |
how do I know what type of distributor I have |
Post up all the numbers on the side, sample below:
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 28, 2021 8:37 am Post subject: Re: The Stupid Question Thread |
Hi there! Post a picture of what you have:
https://www.thesamba.com/vw/forum/viewtopic.php?t=6
It’s true the points mounting (and replacement electronic bits) are different between the two distributors. Since JBugs doesn’t accept returns on electronics, you might be best finding a local VW club to sell your 009 Pertronix. Trading would be another option as well.
If your ‘77 bus still has the original fuel injection, do not get rid of the vacuum distributor; they pair best together. The best points (and maybe condensers) on the market are Echlin brand, available at Napa auto for $10.
There are two types of classic VW owners:
- Those who learn to adjust points once a year because it’s easy, cheap, and fun.
- Those who learn to instal points on the side of the road when their Pertronix dies.
See you on the road!
Posted: Thu Jan 28, 2021 8:58 am Post subject: Re: The Stupid Question Thread |
mewidmer wrote: |
Robbie |
Thanks - I'll give it a shot! |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Thu Jan 28, 2021 6:13 pm Post subject: Re: The Stupid Question Thread |
- Those who learn to install points on the side of the road when their Pertronix dies.
. . . or those that do neither because they installed Allison/Crane ignition 35 years ago!
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Fri Feb 05, 2021 8:39 am Post subject: Re: The Stupid Question Thread |
So here's a bit of a mystery I'm chasing down currently. And I probably won't do the best job of explaining it.
71 Bus. I don't do a ton of night driving in it (because, you know, pandemic). But a couple times I've been out and needed the headlights, they have occasionally shut themselves off. But they come back on.
I've checked the high/low beam relay both at the turn signal switch and the relay. It's got a good click to it and I haven't observed unusual behavior there. I've used the high/low switch to get the lights back while out driving.
My instinct goes to it being a ground issue or a switch issue. Just parked in the driveway last night, I couldn't get it to happen just trying to jostle the switch (though I suspect the dimmer in the switch could use a cleaning, observing the dash lights...that's a separate issue).
My plan for after work is to pull the headlights and check the ground for each of them (they both have gone out when this happens, so wondering about the odds of both grounds having issues). But I'm curious what others might suggest I check over and test.
Thanks! I'm also planning to take the bus to pick up dinner tonight, so hopefully I can get it to happen again. _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
Posted: Fri Feb 05, 2021 9:17 am Post subject: Re: The Stupid Question Thread |
How old is your ignition switch?, the X circuit may be on the way out. If they do go out again try wiggling the key. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Feb 05, 2021 9:21 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
How old is your ignition switch?, the X circuit may be on the way out. If they do go out again try wiggling the key. |
See, I would not have considered the ignition switch. As far as I know, it's still the original switch. At the very least, the key matches every door on the bus down the code stamped on the handles.
I should go read up on the X circuit. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Fri Feb 05, 2021 9:28 am Post subject: Re: The Stupid Question Thread |
NorCalWeekender wrote: |
busdaddy wrote: |
I should go read up on the X circuit. |
X circuit! Okay, I see it on the wiring diagram. Runs thru the ignition switch to the headlight switch.
I presume the repair (if it's the culprit) is a new ignition switch? _________________ 9th Owner of a 1971 Tintop Westy
Posted: Fri Feb 05, 2021 12:02 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
I presume the repair (if it's the culprit) is a new ignition switch? |
Yes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Feb 05, 2021 12:07 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
busdaddy wrote: |
Yes. |
Duly noted. Thank you! _________________ 9th Owner of a 1971 Tintop Westy
Posted: Fri Feb 05, 2021 6:27 pm Post subject: Re: The Stupid Question Thread |
The ignition switch is separate from the ignition lock cylinder. Either can cause problems with the X-circuit. If the key doesn't return fully to the "RUN" position after starting the headlights may not work even if the ignition switch itself is just fine. If you went to a locksmith, he might well just squirt the lock cylinder with WD40 and send you on your way. |
Posted: Fri Feb 05, 2021 6:36 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
So, then could a worn key also cause the issue?
I'm pretty sure my key returns to RUN just fine, but that's something else to at least be aware of. Thanks! _________________ 9th Owner of a 1971 Tintop Westy
dailyoliver Samba Member
Posted: Sat Feb 06, 2021 12:09 pm Post subject: Re: The Stupid Question Thread |
I have a type 4 2.0l engine and am in the middle of fixing my afterburner (u-pipes) - I know this sounds a bit stupid BUT
ARE THEY INTERCHANGEABLE e.g. can the left fit on the right and vice versa?
It's just that they look the same to me - I know F-Pipes are not but what about the u-pipes??
Thank you - you clever engineering folks - Daily Oliver. _________________ Manual 1978 Westy with 2.0l engine and single Weber 'copy' DFEV progressive carb. |
